三角HS-18B电磁炉维修:唧唧会响的故障
4040|5
 楼主| hlfok5176 发表于 2007-1-25 19:16 | 显示全部楼层 |阅读模式
开机时一切正常,但是锅放上烧后会唧唧会响,大概间隔10秒钟时间响一次。上面板换了74HC164没用,还有主板2个大功率的集成块用万用表量也好,所有的三极管和二极管都好的。3个芯片对地都不短路,主板跟上面板连线良好。我搞不懂啦,哪里出故障,不会是主芯片吧。请教大虾。多多谢谢了
javie 发表于 2007-1-25 19:17 | 显示全部楼层
好象没有讲清楚什么哦
 楼主| hlfok5176 发表于 2007-1-28 19:17 | 显示全部楼层
解决啦
是一个电阻烧坏了。还有一个扼留圈断了
tyw 发表于 2007-1-28 19:38 | 显示全部楼层
lz的厚道精神值得学习
<br /><img src="https://bbs.21ic.com/upfiles/img/20071/2007128193650564.gif"><img src="https://bbs.21ic.com/upfiles/img/20071/2007128193650564.gif"><img src="https://bbs.21ic.com/upfiles/img/20071/2007128193650564.gif"><img src="https://bbs.21ic.com/upfiles/img/20071/2007128193650564.gif"><br />&nbsp;&nbsp;&nbsp;<img src="https://bbs.21ic.com/upfiles/img/20071/200712819388791.gif">&nbsp;&nbsp;&nbsp;<img src="https://bbs.21ic.com/upfiles/img/20071/200712819388791.gif">&nbsp;&nbsp;&nbsp;<img src="https://bbs.21ic.com/upfiles/img/20071/200712819388791.gif"><br /><img src="https://bbs.21ic.com/upfiles/img/20071/2007128193650564.gif"><img src="https://bbs.21ic.com/upfiles/img/20071/2007128193650564.gif"><img src="https://bbs.21ic.com/upfiles/img/20071/2007128193650564.gif"><img src="https://bbs.21ic.com/upfiles/img/20071/2007128193650564.gif">
