USB 仿真器在下载C语言程序时出现报警信息
1049|1
 楼主| xichengmadia 发表于 2013-12-31 22:31 | 显示全部楼层 |阅读模式
USB 仿真器在下载C语言程序时,出现报警信息:The stack plug-in failed to set a breakpoint on "main".The stack window will not be able to display stack contents.
(You can change this setting in the Tools>Options dialog box  哪位高手给支招?
这个问题有点麻烦啊
