[STM32F3] STM32F373 sdadc采样问题
12475|11
 楼主| wangtezi 发表于 2014-1-13 10:03 | 显示全部楼层 |阅读模式
用STM32F373 的SDADC采样,实测CPU端口上 VREFSD+ 为2.500V,PE8脚和PE9脚的电压分别为 2.292V 和 1.907V,输入模式为SDADC_InputMode_SEZeroReference,放大位数为1,
仿真显示 SDADC_Channel_7(PE9脚)的值为0x4877, SDADC_Channel_8(PE8脚)的值为0x617C,
而实际上根据实测电压值,采样值应为
1.907*65536/2.5 = 24995 = 0xc346
2.292*65536/2.5 = 60083 = 0xEAB3
与实际值相差如此之大,换了两块板也一样
请大家帮忙找找是哪里的问题?
代码如下:
static uint32_t SDADC1_Config(void)
  SDADC_AINStructTypeDef SDADC_AINStructure;
  GPIO_InitTypeDef   GPIO_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  uint32_t SDADCTimeout = 0;
  /* MPX2102_SDADC APB2 interface clock enable */
  RCC_APB2PeriphClockCmd(MPX2102_SDADC_CLK, ENABLE);
  /* PWR APB1 interface clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
  /* Enable MPX2102_SDADC analog interface */
  PWR_SDADCAnalogCmd(MPX2102_SDADC_PWR, ENABLE);
  /* Set the SDADC divider: The SDADC should run @6MHz */
  /* If Sysclk is 72MHz, SDADC divider should be 12 */
  RCC_SDADCCLKConfig(RCC_SDADCCLK_SYSCLK_Div48);
  /* GPIOE Peripheral clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOE, ENABLE);
  /* MPX2102_SDADC channel 8P (PE8)  and channel 8N (PE9) */
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_8 | GPIO_Pin_9;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* Select External reference: The reference voltage selection is available
     only in SDADC1 and therefore to select the VREF for SDADC2/SDADC3, SDADC1
     clock must be already enabled */
  SDADC_VREFSelect(SDADC_VREF_Ext);
  //SDADC_VREFSelect(SDADC_VREF_VDDA);
  //SDADC_VREFSelect(SDADC_VREF_VREFINT2);
  /* Insert delay equal to ~5 ms */
  delay(5);  //5ms
  /* Enable MPX2102_SDADC */
  SDADC_Cmd(MPX2102_SDADC, ENABLE);
  /* Enter initialization mode */
  SDADC_InitModeCmd(MPX2102_SDADC, ENABLE);
  SDADCTimeout = SDADC_INIT_TIMEOUT;
  /* wait for INITRDY flag to be set */
  //while((SDADC_GetFlagStatus(MPX2102_SDADC, SDADC_FLAG_INITRDY) == RESET) && (--SDADCTimeout != 0));
  while(SDADC_GetFlagStatus(MPX2102_SDADC, SDADC_FLAG_INITRDY) == RESET);
  if(SDADCTimeout == 0)
    /* INITRDY flag is not set */
    return 1;
  /* Analog Input configuration conf0: use differential mode and gain = 4 */
  //SDADC_AINStructure.SDADC_InputMode = SDADC_InputMode_Diff;
  SDADC_AINStructure.SDADC_InputMode = SDADC_InputMode_SEZeroReference;
  //SDADC_AINStructure.SDADC_InputMode = SDADC_InputMode_SEOffset;
  SDADC_AINStructure.SDADC_Gain = SDADC_Gain_1;
  SDADC_AINStructure.SDADC_CommonMode = SDADC_CommonMode_VSSA;
  //SDADC_AINStructure.SDADC_CommonMode = SDADC_CommonMode_VDDA_2;
  SDADC_AINStructure.SDADC_Offset = 0;
  SDADC_AINInit(MPX2102_SDADC, SDADC_Conf_0, &SDADC_AINStructure);
  /* select MPX2102_SDADC channel 8 to use conf0 */
  SDADC_ChannelConfig(MPX2102_SDADC, SDADC_Channel_8, SDADC_Conf_0);
  /* select channel 8 */
  SDADC_InjectedChannelSelect(MPX2102_SDADC, SDADC_Channel_8);
        SDADC_InjectedContinuousModeCmd(MPX2102_SDADC, ENABLE);
  /* Select an external trigger */
  //SDADC_ExternalTrigInjectedConvConfig(MPX2102_SDADC, SDADC_ExternalTrigInjecConv_T19_CC2);
  /* Select rising edge */
  //SDADC_ExternalTrigInjectedConvEdgeConfig(MPX2102_SDADC, SDADC_ExternalTrigInjecConvEdge_Rising);
  /* Exit initialization mode */
  SDADC_InitModeCmd(MPX2102_SDADC, DISABLE);
  /* Enable end of injected conversion interrupt */
  SDADC_ITConfig(MPX2102_SDADC, SDADC_IT_JEOC, ENABLE);
  /* NVIC Configuration */
  NVIC_InitStructure.NVIC_IRQChannel = SDADC1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* configure calibration to be performed on conf0 */
  SDADC_CalibrationSequenceConfig(MPX2102_SDADC, SDADC_CalibrationSequence_1);
  /* start MPX2102_SDADC Calibration */
  SDADC_StartCalibration(MPX2102_SDADC);
  /* Set calibration timeout: 5.12 ms at 6 MHz in a single calibration sequence */
  SDADCTimeout = SDADC_CAL_TIMEOUT;
  /* wait for MPX2102_SDADC Calibration process to end */
  //while((SDADC_GetFlagStatus(MPX2102_SDADC, SDADC_FLAG_EOCAL) == RESET) && (--SDADCTimeout != 0));
  while(SDADC_GetFlagStatus(MPX2102_SDADC, SDADC_FLAG_EOCAL) == RESET);
    /* EOCAL flag can not set */
    return 2;
        SDADC_SoftwareStartInjectedConv(MPX2102_SDADC);
  return 0;
void SDADC1_IRQHandler(void)
  uint32_t ChannelIndex;
  if(SDADC_GetFlagStatus(SDADC1, SDADC_FLAG_JEOC) != RESET)
    /* Get the converted value */
    InjectedConvData = SDADC_GetInjectedConversionValue(SDADC1, &ChannelIndex);
                ChannelIndex = ChannelIndex;
 楼主| wangtezi 发表于 2014-1-13 13:41 | 显示全部楼层
呵,仔细查了资料,原来是计算公式不对。
flush0 发表于 2014-3-19 09:26 | 显示全部楼层
遇到了同样的问题,楼主怎么解决的,正确的计算公式是什么呢
cool_coder 发表于 2014-3-19 11:13 | 显示全部楼层
这样算:
1.907*65536/2.5 - 32768 - OFFSET = 49990 - 32768 - OFFSET = 0x4347 - OFFSET
2.292*65536/2.5 - 32768 - OFFSET = 60083 - 32768 - OFFSET = 0x6AB3 - OFFSET
OFFSET在校准结果里找
flush0 发表于 2014-3-19 14:54 | 显示全部楼层
这样算:
2.292*65536/2.5 ...
我看了下官方例程,也要减去32768,可是减去32768的原理是什么,求解。
另外:SDADC的其他两种采集模式又是怎样的计算公式呢,是否还要减去这个32768???
@香水城  SDADC的采样周期计算公式是什么呢?也就是用SDADC采集一个完整的数据需要多少个SDADC_CLK。。。
c914620529 发表于 2015-4-24 09:52 | 显示全部楼层
你好  我问一下  你的这个中断函数读取的对吗   我配置的读取到都是-32768  不知道什么问题  帮我看看https://bbs.21ic.com/icview-926534-1-1.html
h000000o 发表于 2015-12-2 10:47 | 显示全部楼层
请问你的stm32f373用的什么仿真器?还有ulink2可以吗?
 楼主| wangtezi 发表于 2017-3-1 16:54 | 显示全部楼层
我用的是Jlink-V8
Hazelhyd 发表于 2018-4-12 14:40 | 显示全部楼层
请问这个AD的采样速率最大能到达多少呢
antusheng 发表于 2018-4-13 14:50 | 显示全部楼层
原来如此,学会这个操作了。
天灵灵地灵灵 发表于 2018-4-13 18:55 | 显示全部楼层
32这种一大堆结构体变量初始化,看的头晕。
Followers 发表于 2019-7-29 16:21 | 显示全部楼层
OFFSET是在校准结果的哪里查看的
