[STM32F1] 串口2能发送数据不能接收数据
3079|2
 楼主| zhanghuichun 发表于 2014-2-21 22:51 | 显示全部楼层 |阅读模式
最近做个项目需要用到两个串口,在调试过程中遇到问题,望广大好心的高手帮助
奇怪的现象:用到串口1时可以发送数据和接收数据(程序已用串口1验证过),修改为串口2后就只能发送数据不能接收数据!
代码:
int main(void)
        vu16 i=500;
//        gpio_initi();
        NVIC_Configuration();
        USART_Config();
/*        start_gsm();
        Delay(20000000);
        USART_printf(USART2,"AT\r\n");
        Delay(2000000);
        USART_printf(USART2,"AT+CGPSPWR=1\r\n");
        Delay(200000);
        USART_printf(USART2,"AT+CGPSRST=1\r\n");
        Delay(200000);
        USART_printf(USART2,"AT+CGPSIPR=9600\r\n");*/
        while(1)
        i=500;
        if(USART_GetFlagStatus(USART2, USART_IT_RXNE) != RESET)
                      USART_SendData(USART2,USART_ReceiveData(USART2));
                while(i--);
void NVIC_Configuration(void)
        NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);//设置优先级分组形式1,即抢占级占一位,优先级占3位
        /****************UART2全局中断使能***********************/
        NVIC_InitStructure.NVIC_IRQChannel=USART2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
        NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
        NVIC_Init(&NVIC_InitStructure);
void USART_Config(void)
        USART_InitTypeDef USART_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA,ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
//        NVIC_Configuration();
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9|GPIO_Pin_2;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10|GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
        USART_InitStructure.USART_BaudRate=9600;
        USART_InitStructure.USART_WordLength=USART_WordLength_8b;
        USART_InitStructure.USART_StopBits=USART_StopBits_1;
        USART_InitStructure.USART_Parity=USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
          /* Configure the USART1 */
          USART_Init(USART1, &USART_InitStructure);
  /* INIT  USART1 */
         USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Enable the USART1 */
         USART_Cmd(USART1, ENABLE);
         /* Configure the USART2 */
          USART_Init(USART2, &USART_InitStructure);
  /* INIT  USART2 */
        USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
  /* Enable the USART2 */
        USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
          USART_ClearFlag(USART2,USART_FLAG_TC);
          USART_Cmd(USART2, ENABLE);
mmuuss586 发表于 2014-2-22 08:59 | 显示全部楼层
这是我用407写的2个串口初始化程序,可以参考下
void NVIC_Config(void)
  /* Enable the USARTx Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
//初始化串口1
void COM1Init(void)
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_USART2);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_USART2);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
        USART_InitStructure.USART_BaudRate = BaudRate;//波特率设置
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        NVIC_Config();
airwill 发表于 2014-2-22 16:37 | 显示全部楼层
没有看出什么问题, 是不是先检查一下硬件问题, 比如焊接问题
