[AVR单片机] AVR汇编程序
1496|4
 楼主| anne82820 发表于 2014-3-5 15:26 | 显示全部楼层 |阅读模式
LDS     XH,R_nearBlanking                        ; [近端]
                                                LDS     XL,R_nearBlanking+1                        ;
                        MOVW        dw41:dw40, XH:XL                        ; R_nearBlanking
                        LDI     XH, high(D_zoom_dat)                ; 采样缩放系数
                                                LDI     XL,  low(D_zoom_dat)                ;
                        CALL    Sub_16MUL_XvsDw40_toX_1035        ; 16bits乘法运算 X*RAM_dw40 => X  D_zoom_dat*R_nearBlanking
                        LDI     ZH, high(R_SSPADC_BufArea)        ; X-point 起点位置偏移
                                                LDI     ZL,  low(R_SSPADC_BufArea)        ;
                                                ADD                XL, ZL                                                ;
                                                ADC                XH, ZH                                                ;
                        MOVW        ZH:ZL, XH:XL                                ; PT-POINT.[dw4B:dw4A]
                                                LD      XL, Z                                                ;
                                                LD      XH, Z                                                ; max
                                                ;       找最大点
_L_lp_fill_start_2009:        LD      XL, -Z                                                ;
                                                CP      XL, XH                                                ;
                                                BRCS    _L_lp_fill_0731_1044                ;
                                                MOV     XH, XL                                                ;取得最大值
                                                MOVW    VarH:VarL, ZH:ZL                        ;
   _L_lp_fill_0731_1044:CLC
                                                   CPI     ZL,  low(R_SSPADC_BufArea)        ;
                                                BRNE    _L_lp_fill_start_2009                ;
                                                   CPI     ZH, high(R_SSPADC_BufArea)        ;
                                                MOVW    ZH:ZL, VarH:VarL
   _L_lp_fill_0731_1045:ST      -Z, XH
                                                BRNE    _L_lp_fill_0731_1045                ;
                        LDS     XH,R__farBlanking                        ; [远端]
                                                LDS     XL,R__farBlanking+1                        ;
                                                ADD                XL, ZL                                                ;
                                                ADC                XH, ZH                                                ;
                        MOVW    dw4F:dw4E, XH:XL                         ; STOP-POINT.[Dw4F:Dw4E]
                                                ADD                XL, ZL                                                ;
                                                ADC                XH, ZH                                                ;
                        MOVW        dw4B:dw4A, XH:XL                        ; PT-POINT.[dw4B:dw4A]
                        MOVW    dw4d:dw4c, dw4B:dw4A                 ; START-POINT.[dw4d:dw4c]
_L_loop_43A4:           ;                 <<<<<<<<<<<<<<<<<<<<==========================
                                                MOVW    ZH:ZL,dw4F:dw4E                         ; STOP-POINT.[Dw4F:Dw4E]
                                                MOVW        XH:XL,dw4B:dw4A                                ;   PT-POINT.[dw4B:dw4A]  START
                                                CP                XL, ZL                                                ;
                                                CPC                XH, ZH                                                ;
                        BRCS    _L_cont_1247                                ;  [***]HGA-07-11
                                                RET                                                             ;  ****>>>>  PT-POINT.[dw4B:dw4A] >= STOP-POINT.[Dw4F:Dw4E]
                _L_cont_1247:        ;
                        ;       [ 正向-->[to-down] 递减 ]
        _L_loop_fdown_001:  MOVW    ZH:ZL, dw4B:dw4A                         ; PT-POINT.[dw4B:dw4A]  START
                        LD      XL, Z+                                                ;
                        LD      XH, Z                                                ;
                                                CLC        ;
                                                CP      XL, XH                                                ; D[i].vs.D[i+1]
                        BRCS    _L_next_1129_1632                        ; =================>> D[i]<D[i+1] 找到最右最低点
                                                ;       D[i]>=D[i+1]
                        MOVW    XH:XL, dw4F:dw4E                         ; STOP-POINT.[Dw4F:Dw4E]
                                                CLC        ;
                                                CP                XL, ZL                                                ; Note: 此时的Z,已经++1
                                                CPC                XH, ZH                                                ; STOP-POINT.[Dw4F:Dw4E] <> PT-POINT.[Dw4B:Dw4A]++
                                                BRCS    _L_next_1129_1632                        ;==>>
                                                ;       [STOP-POINT.[Dw4F:Dw4E] >= PT-POINT.[Dw4B:Dw4A]+1
                                                MOVW    ZH:ZL, dw4B:dw4A                         ; [dw4B:dw4A]++
                        ADIW    ZH:ZL, 1                                        ;
                        MOVW    dw4B:dw4A, ZH:ZL                        ;
                        JMP     _L_loop_fdown_001                        ; -loop->
_L_next_1129_1632:      ;       [ 正向-->[to-up] 递增  ]
        _L_loop_fup__002:        MOVW    ZH:ZL, dw4B:dw4A                         ;
                        LD      XL, Z+                                                ;
                        LD      XH, Z                                                ;
                                                CLC        ;
                                                CP      XH, XL                                                ;
                                                BRCS    _L_next_1129_43F4                        ;==>>
                                                ;                D[i]=<D[i+1]
                                                CLC        ;
                                                ;                [STOP-POINT.[Dw4F:Dw4E] >= F.PT-POINT.[Dw4B:Dw4A]+1
                        ADIW    ZH:ZL, 1                                        ;
                        JMP     _L_loop_fup__002                        ; -loop->
_L_next_1129_43F4:                                ; 找到一个单调上升的正面
                                                MOVW    dw47:dw46, dw4B:dw4A                ; Pt.Back -- -->找到的极点位置
                                                MOVW        dw49:dw48, dw4B:dw4A                ;
_L_loop_43FC:                        MOVW    ZH:ZL, dw47:dw46                         ;
                        LD      XL,  Z                                                ;
                        LD      XH, -Z                                                ;
                                                CLC        ;
                                                CP      XL, XH                                                ;
                        BRCS    _L_next_1129_442C                         ; #==>> ( D[i-1] > D[i] ) 拐点限制
                                                ;       D[i-1]<D[i].or.D[i-1]=D[i]
                                                MOVW    ZH:ZL, dw47:dw46                         ; Pt.Back --
                        LD      XL,  Z                                                ;
                                                MOVW    ZH:ZL, dw49:dw48                         ; Pt.fore ++
                        LD      XH,  Z                                                ;
                                                CLC        ;
                                                CP      XL, XH                                                ;
                        BRCS    _L_next_1129_442C                   ; #==>> ( D[i-1] < D[i] < D[T] )
        ; #==>> ( D[i-1] = D[i] < D[T] )
                                                ;       D[i] > D[T] 此处只有在平顶波形是出现
                                                ;       D[i] = D[T]
                                                MOVW        XH:XL, dw49:dw48                        ; Pt.fore
                                                SUB                XL, ZL                                                ;
                                                SBC                XH, ZH                                                ;
                                                LDI                ZH, high(D_TOP_numF)                ; (Pt.fore - Pt.Back) <> D_TOP_num
                                                LDI                ZL,  low(D_TOP_numF)                ;
                                                CLC        ;
                                                CP                XL, ZL                                                ;
                                                CPC                XH, ZH                                                ;
                        BRGE    _L_next_1129_442C                   ; #==>> ((T-i) >= D_TOP_num) 距离限制
                                                MOVW    ZH:ZL, dw4D:dw4C                         ; START-POINT.[dw4B:dw4A] <> BACK.PT
                                                MOVW        XH:XL, dw47:dw46                        ;
                                                CLC        ;
                                                CP                ZL, XL                                                ;
                                                CPC                ZH, XH                                                ;
                        BRCC    _L_next_1129_442C                   ; #==>> ( START-POINT.[dw4B:dw4A] >= BACK.PT ) 边界限制
                        SBIW    ZH:ZL, 1                                        ;
                                                MOVW    dw47:dw46, ZH:ZL                        ; Pt.Back.[dw47:dw46]--1
                        JMP    _L_loop_43FC                                        ; -loop->
_L_next_1129_442C:                MOVW    ZH:ZL, dw49:dw48                         ; Pt.fore.[dw49:dw48]
                        LD      XL,  Z+                                                ;
                        LD      XH,  Z                                                ;
                                                CLC        ;
                                                CP      XL, XH                                                ;
                        BRCS    _L_next_445F                                ; ==>> D[i] < D[i+1] 拐点限制
                                                ;       D[i]>=D[i+1]
                        LD      XL,  Z                                                ;
                                                MOVW    ZH:ZL, dw47:dw46                         ; Pt.Back.[dw47:dw46]
                        LD      XH,  Z                                                ;
                                                CLC        ;
                                                CP      XL, XH                                                ;
                        BRCS    _L_next_445F                                ; []==>> D[T] < D[B]
                                                ;       D[T]>=D[B]
                                                MOVW    XH:XL, dw49:dw48                         ; (i-B.PT) <> D_TOP_num
                                                SUB                XL, ZL                                                ;
                                                SBC                XH, ZH                                                ;
                                                LDI                ZL, high(D_TOP_numB)                ;
                                                LDI                ZH,  low(D_TOP_numB)                ;
                                                CLC        ;
                                                CP                XL, ZL                                                ;
                                                CPC                XH, ZH                                                ;
                        BRGE    _L_next_445F                                ; []==>>
                                                MOVW    ZH:ZL, dw4F:dw4E                         ; STOP-POINT.[Dw4F:Dw4E] <> F.PT-POINT.[dw49:dw48]
                                                CLC        ;
                                                CP                ZL, XL                                                ;
                                                CPC                ZH, XH                                                ;
                        BREQ    _L_next_445F                                ; []==>>
                        ADIW    ZH:ZL, 1                                        ;
                        MOVW    dw49:dw48, ZH:ZL                        ; Pt.fore.[dw49:dw48]++1
_L_next_445F:                        ;       切除峰点
                        LD      XL, Z                                                ;
                        LD      XH, Z                                                ;
                                                CLC        ;
                                                CP      XL, XH                                                ;
                        BREQ    _L_next_4485                                ;
                                                BRCS    _L_next_4485                                ;
                                                ;       Data---> to[dw49:dw48]  if( D.[dw47:dw46] > D.[dw49:dw48] )
                                                MOVW    ZH:ZL, dw47:dw46                         ; dw47:dw46
                        LD      VarL, Z                                                ;
                _L_loop_4470:        CLC        ;
                                                CP                XL, ZL                                                ;
                                                CPC                XH, ZH                                                ;
                        BREQ    _L_next_449F                                ;[]
                                                BRCS    _L_next_449F                                ;[]
                        ST      Z+, VarL                                        ;
                        JMP     _L_loop_4470                                ; -loop->>
_L_next_4485:           ;       [dw47:dw46]fr <---Data if( D.[dw47:dw46] =< D.[dw49:dw48] )
                                                MOVW    ZH:ZL, dw49:dw48                         ; dw49:dw48
                        LD      VarL, Z+                                        ;
                _L_loop_448C:        CLC        ;
                                                CP                XL, ZL                                                ;
                                                CPC                XH, ZH                                                ;
                        BRCC    _L_next_449F                                ;[] dw47:dw46 >= dw49:dw48
                        ST      -Z, VarL                                        ;
                        JMP     _L_loop_448C                                ; -loop->>
_L_next_449F:                   JMP     _L_loop_43A4                    ;===>>>>>
                                                RET
本人不会汇编的,懂汇编的帮忙看看的,说说这个程序的思路的,我用用c写出来 ,谢谢哈
qin552011373 发表于 2014-3-5 18:07 | 显示全部楼层
自己不会先看看,画个流程图出来?
 楼主| anne82820 发表于 2014-3-6 10:44 | 显示全部楼层
我就没学过汇编的,看不懂,怎么画流程图的,会画流程图我就知道什么意思的,我就不用问大家了
c8112499 发表于 2014-3-8 23:08 | 显示全部楼层
有点晕啊
IT阿炳 发表于 2014-3-28 18:53 | 显示全部楼层
汇编不懂啊!!!!!!!!!!!!!!!
