- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define MASK 0xf0
- uchar code table[] = {0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71,
- 0xff}; // 段码表
- uchar code table2[] = {0xfe,0xfd,0xfb,0xf7}; // 扫描
- void delay(uint i);
- void display(uchar num);
- void keyscan(uchar * num);
- int main(void)
- uchar num = 16;
- while(1)
- keyscan(&num);
- display(num);
- return 0;
- uchar temp;
- uint i;
- // 扫描按键并比较
- for(i = 0; i < 4; i++)
- P2 = table2[i];
- temp = P2;
- temp &= MASK;
- if(temp != MASK)
- delay(5);
- temp = P2;
- temp &= MASK;
- if(temp == MASK)
- continue;
- i--;
- switch(temp)
- case 0xe0 :
- (*num) = 4 * i + 0;
- break;
- case 0xd0 :
- (*num) = 4 * i + 1;
- break;
- case 0xb0 :
- (*num) = 4 * i + 2;
- break;
- case 0x70 :
- (*num) = 4 * i + 3;
- break;
- // default:
- // break;
- while((P2 & MASK) != MASK);
- delay(5);
- uint j;
- for(;i > 0; i--)
- for(j = 0; j < 100; j++)
- continue;
- P0 = ~table[num];
数码管是共阳极接法,数码管是单独接的 不用锁存器
键盘是4X4的键盘P2.0~P2.3控制行,2.4~2.7是列
上面这个程序,1~3排按了都有反应,第四排按下之后不一定有反应 (有时候有,排除键盘接触不良)
