[文档下载] NANO130KE3BN开发板上使用管角和可用管角功能归纳
2874|9
 楼主| 1656a3375 发表于 2014-4-2 19:36 | 显示全部楼层 |阅读模式
希望为你使用新唐NANO130KE3BN开发板带来方便:
液晶显示占用芯片管角(49)
1.2.3.4--------->>SEG27---SEG24
9.10.11.12.13.14.
15.16.17.18.19.
20.21.22-------->>SEG23---SEG10
37.38----------->>SEG9-----SEG8
44.45.46.47.48.
49.50.51  ------>>SEG7-----SEG0
93.94.95.96----->>SEG39----SEG36
105.106   ------>>SEG35----SEG34
109.110.111----->>SEG33----SEG31
126.127.128----->>SEG30----SEG28
52.53.54.55.---->>COM0-----COM3
62.63.64-------->> V1------V3
56.57 ---------->> DH1----DH2
NC和电源 晶振等管角(44)
5.8.23.25.26.28.39.
40.41.42.43.82.84.
98.104.112.115.119.121----->>NC
(40.41.42.43--->>USB)
27.83.120 ----------------->>VDD
29.30.31.32.85.
86.117.118.124    --------->>VSS
59.60  -------------------->>LCD_VLCD
97------------------------->>VREF
87.88         ------------->>AVSS
99------------------------->>AVDD
125                 ------->>PVSS
24                --------->>LDO_CAP
116                -------->>nRESET
113.114-------------------->>XT1_IN----XY_OUT
06.07---------------------->>X320--X321
板上其它使用管角:(11)
89.90   -------------->>ADC0(AD0)--P90(AD1),接NTC100K两端
58  ------------------>>PE6接二极管
71  ------------------>>PC12(INT0)接按键
80.81 ---------------->>TICE_CLK---TICE_DAT调试口
72.73.74.75.78-------->>触控按键
剩下可用管角和功能:(24)
33 PE12/UART1_CTSn ;34 PE11/UART1_RTSn ;35 PE10/UART1_TXD
36 PE9/UART1_RXD
61 PE5
65 PE4/SPI0_MOSI0 ;66 PE3/SPI0_MISO0 ;67 PE2/SPI0_CLK ;
68 PE1/PWM1_CH3/SPI0_SS0 ;69 PE0/PWM1_CH2/I2S_MCLK;
70 PC13/SPI_MOSI1/PWM1_CH1/SNOOPER/INT0/I2C0_SCL
76 PA15/PWM0_CH3/I2S_MCLK/TC3/SC0_PWR/UART0_TXD/LCD_SEG27
77 PA14/PWM0_CH2/EBI_AD15/TC2/UART0_RXD/LCD_SEG26
79 PA12/PWM0_CH0/EBI_AD13/TC0/I2C0_SDA/CTK10/LCD_SEG24
91 PA2/AD2/EBI_AD11/UART1_RXD/LCD_SEG23
92 PA3/AD3/EBI_AD10/UART1_TXD/LCD_SEG22
100 PD0/UART1_RXD/SPI2_SS0/SC1_CLK/CTK0/AD8
101 PD1/UART1_TXD/SPI2_CLK/SC1_DAT/AD9/CTK1
102 PD2/UART1_RTSn/I2S_LRCLK/SPI2_MISO0/SC1_PWR/AD10/CTK2
103 PD3/UART1_CTSn/I2S_BCLK/SPI2_MOSI0/SC1_RST/AD11/CTK3
107 PC7/DA1_OUT/EBI_AD5/TC1/PWM0_CH1/LCD_SEG17
108 PC6/DA0_OUT/EBI_AD4/TC0/SC1_CD/PWM0_CH0
122 PF4/I2C0_SDA/CTK6;123 PF5/I2C0_SCL/CTK7
niuyaliang 发表于 2014-4-2 20:35 | 显示全部楼层
大哥,看了半天才看懂,是管脚。。。管角啥子呦
123很简单 发表于 2019-7-18 14:54 | 显示全部楼层
你有nano130的例程吗?
734774645 发表于 2019-7-18 15:44 | 显示全部楼层
总结的不错。
598330983 发表于 2019-7-18 23:37 | 显示全部楼层
好帖。
zhuotuzi 发表于 2019-7-19 00:40 | 显示全部楼层
可以作为参考。
yiy 发表于 2019-7-20 20:58 | 显示全部楼层
可用和使用区别?
xixi2017 发表于 2019-7-21 18:58 | 显示全部楼层
一百多个管脚吗
wanduzi 发表于 2019-7-21 21:43 | 显示全部楼层
哈哈,这个看手册不就行了
jasontu 发表于 2019-7-22 09:14 | 显示全部楼层
建议使用pin config作脚位规划,还可以产生出脚位初始化代码。
