FSL_TICS_Robin 发表于 2014-5-30 10:16
这个不会有问题的,我在IAR安装提示中看到过相关问题,只要你别装在一个目录下。 ...
Important information
•Upgrade information
◦Before you install
To avoid any problems, do not install this release in a directory where you have previously installed any older version of IAR Embedded Workbench. It is recommended that you either uninstall an earlier product, or install this release in a separate directory. As before, however, it is possible to install different products, all using the same version of the main application, in the same root directory.
你安装IAR的时候,在Release notes里会提示你的
