发送程序
- USART_InitStructure.USART_BaudRate = 9600;//115200;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No ;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- /* Configure the USARTy */
- USART_Init(USARTy, &USART_InitStructure);
- /* Enable the USARTy */
- USART_Cmd(USARTy, ENABLE);
- /* Set the USARTy prescaler */
- USART_SetPrescaler(USARTy, 0x1);
- /* Configure the USARTy IrDA mode */
- USART_IrDAConfig(USARTy, USART_IrDAMode_Normal);
- /* Enable the USARTy IrDA mode */
- USART_IrDACmd(USARTy, ENABLE);
- while (1)
- USART_SendData(USARTy, i++);//i unsigned char
- delay(1000000);
接收程序
- STM_EVAL_COMInit(COM2, &USART_InitStructure);
- printf("\n\rUSART Printf Example: retarget the C library printf function to the USART\n\r");
- while (1)
- /* Wait until a byte is received */
- while(USART_GetFlagStatus(USARTy, USART_FLAG_RXNE) == RESET)
- count++;
- if(count > 1000000)
- printf("\n\r 等待接收数据 \n\r");
- count = 0;
- /* Read the received byte */
- //ReceivedData = (JOYState_TypeDef)USART_ReceiveData(USARTy);
- REV = (unsigned char)USART_ReceiveData(USARTy);
- //USART_SendData(USARTy,i++);
- //REV = 255;
- printf("\n\r 接收到的数据为:%d%d%d \n\r",REV/100,REV%100/10,REV%10);
- Delay(5000000);
电路图:
现象:
发送端 TXD和RXD都有波形,用示波器,至于TFDU4300有没有将数据发出就没法检测了
接收端都没有波形
USE_STDPERIPH_DRIVER, STM32F10X_CL, USE_STM3210B_EVAL
在官方库的基础上改的
