12864显示汉字问题
1117|2
 楼主| G21372 发表于 2014-6-17 22:54 | 显示全部楼层 |阅读模式
gp, IO, GPIO, pi, TE
以下是12864显示字符的完整代码:
#include"DSP2833x_Device.h"
#include "DSP2833x_Examples.h"
#define          EN         GpioDataRegs.GPBDAT.bit.GPIO33
#define          RW         GpioDataRegs.GPBDAT.bit.GPIO32
#define          RS         GpioDataRegs.GPADAT.bit.GPIO20
#define          uchar         unsigned char
extern uchar menu1[]={"选择电机定时设置"};
extern uchar menu2[]={"开步进电机A"};
extern uchar menu3[]={"开步进电机B"};
extern uchar menu4[]={"开步进电机C"};
void LCDInit(void);
void Write_order(Uint16 order);
void Write_data(Uint16 data);
void delay(Uint16 t);
void configio(void);
//void InitXintf(void);
void display(uchar *hz);
void LCD_DATA(uchar d){
   Uint32 i=0;
   i = GpioDataRegs.GPADAT.all;
   i |= (d<<6)&0x3FC0;
   i = (~((d<<6)&0x3FC0))|(~i);
   GpioDataRegs.GPADAT.all = ~i;
void LCDInit(void)
  delay(500);
  Write_order(0x30);// 功能设定:基本指令动作
  delay(5);
  Write_order(0x0c);//显示状态:开
  delay(5);
  Write_order(0x01);//清屏
  delay(6);
  Write_order(0x02);//地址归位:AC=0x00
  delay(4);
   RS=0;delay(1);
   RW=0;delay(1);
   EN=1;delay(1);
   LCD_DATA(order);
   delay(10);
   EN=0;delay(1);
   RS=1;delay(1);
   RW=0;delay(1);
   EN=1;delay(1);
   LCD_DATA(data);
   delay(10);
   EN=0;delay(1);
   Uint16 i;
   while(t--)
      for(i=0;i<125;i++);
void configio(void)
    EALLOW;
        GpioCtrlRegs.GPAMUX1.all &= 0xc03f;
        GpioCtrlRegs.GPADIR.all |= 0x00003FC0;
    GpioCtrlRegs.GPBMUX1.bit.GPIO33 = 0;
    GpioCtrlRegs.GPBDIR.bit.GPIO33 = 1;
    GpioCtrlRegs.GPBMUX1.bit.GPIO32 = 0;
    GpioCtrlRegs.GPBDIR.bit.GPIO32 = 1;
    GpioCtrlRegs.GPAMUX2.bit.GPIO20= 0;
    GpioCtrlRegs.GPADIR.bit.GPIO20 = 1;
    EDIS;
   while(*hz!='\0')
       Write_data(*hz);
       hz++;
       delay(2);
void main(void)
    InitSysCtrl();
  //  InitXintf();
    InitXintf16Gpio();
    DINT;
    InitPieCtrl();
    IER=0x0000;
    IFR=0x0000;
    configio();
    RS=0;
    delay(5);
    RW=0;
    delay(5);
    EN=0;
    LCDInit();
    delay(5);
    Write_order(0x01);
    delay(50);
    Write_order(0x80);
    delay(5);
    display(menu1);
    Write_order(0x91);
    delay(5);
    display(menu2);
    Write_order(0x89);
    delay(5);
    display(menu3);
    Write_order(0x99);
    delay(5);
    display(menu4);
    while(1);
 楼主| G21372 发表于 2014-6-17 22:55 | 显示全部楼层
想请教一下void LCD_DATA(uchar d)
   Uint32 i=0;
   i |= (d<<6)&0x3FC0;
} 这一小段代码中GpioDataRegs.GPADAT.all的值是多少呀,以及这段代码它实现的是什么功能?这个程序已经困扰我好几天了,跪求高手指点!!!在此先感谢了!
gexingyouxian 发表于 2014-6-17 23:15 | 显示全部楼层
不要光看程序,要对照着硬件。把硬件吃透了,程序看起来也就简单了。
   Uint32 i=0;
   i |= (d<<6)&0x3FC0;
简化后
   Uint32 i=0;
  GpioDataRegs.GPADAT.all = (d<<6)&0x3FC0;
还有就事数据线是GPIOA6~GPIOA13
