使用L3.0.35_4.0.0_130424_source,i.MX6 SDB板
报错问题:
+ make
make all-recursive
make[1]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8'
Making all in tools
make[2]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8/tools'
make[2]: *** No rule to make target `all'. Stop.
make[2]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8/tools'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8'
make: *** [all] Error 2
error: Bad exit status from /opt/fsl/L3.0.35_4.0.0_130424_source/Linux/ltib/tmp/rpm-tmp.39741 (%build)
RPM build errors:
Build time for texinfo: 11 seconds
Failed building texinfo
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
main::host_checks:1447
main:554
Started: Tue Jun 24 23:53:08 2014
Ended: Tue Jun 24 23:53:19 2014
Elapsed: 11 seconds
These packages failed to build:
texinfo
Build Failed |
