5437低功耗降不下去,8.6MA,而且AD数据采集一直不变 急
1486|4
 楼主| liuyuqiong1 发表于 2014-7-14 10:26 | 显示全部楼层 |阅读模式
int main(void)
    WDTCTL = WDTPW + WDTHOLD;                   // 停止看门狗
//    clock_config();                             // 初始化时钟
    adc12_config();                             // 初始化ADC12
    uart_config();                              //初始化UART
    TA1CCTL0 = CCIE;                            // 使能TA1CCR0,比较匹配中断
    TA1CCR0 = 1092;                            // 初始化最大值,发生比较匹配中断频率 32768/32768 = 1Hz
    TA1CTL = TASSEL_1 + MC_1 + TACLR;           // 选择ACLK,最大值为CCR0,清除计数值
    _EINT();                                    // 初始化全局中断
    P1DIR = BIT0|BIT1;  //控制LED1,2 输出
    P8SEL &= 0xFE;
    P8DIR |= BIT0;
    P8OUT &= 0xFE;  //IC9 en 拉低输出2.8V供电
    P7SEL &= 0xFB;
    P7DIR |=BIT2;
    P7OUT |=BIT2;  //p7.2   驱动放大器使能
    P4SEL = 0x00;
    P4DIR |= BIT0|BIT1|BIT2|BIT3|BIT4|BIT5|BIT6;
    P4OUT = 0x20;//使能IO,驱动几个芯片的
    P7OUT &= 0xFB;
    P4OUT &= 0xF9;
    __delay_cycles(5000);
    P4OUT |= 0x06;
//    __delay_cycles(1000);
//    P4OUT &= 0xF9;
//    __delay_cycles(5000);
//    P4OUT |= 0x04;
//    P4OUT &= 0xF9;
//        SelectChannel(0);
    while(1)
            switch(channelset)
              case 0:
                SelectChannel(0);
                 while ( !(ADC12IFG & BIT0) );           // 等待转换完成
                ADC_DATA = ADC12MEM0;
                XZhou_LOW = (ADC_DATA &0x00ff);
                XZhou_HIG = (ADC_DATA &0xff00) >> 8;
                ++channelset;
               break;
              case 1:
                SelectChannel(1);
                YZhou_LOW = (ADC_DATA &0x00ff);
                YZhou_HIG = (ADC_DATA &0xff00) >> 8;
                ++channelset;
                ++channelset;
               break;
              case 2:
                break;
            case 3:
                SelectChannel(3);
                ZZhou_LOW = (ADC_DATA &0x00ff);
                ZZhou_HIG = (ADC_DATA &0xff00) >> 8;
                channelset = 0;
                break;
            default:
              break;
            if(second_flag)
              second_flag = 0;
              tx_buf[0] = 0xAA;
              tx_buf[1] = XZhou_LOW;
              tx_buf[2] = XZhou_HIG;
              tx_buf[3] = YZhou_LOW;
              tx_buf[4] = YZhou_HIG;
              tx_buf[5] = ZZhou_LOW;
              tx_buf[6] = ZZhou_HIG;
              tx_buf[7] = 0xBB;
              tx_buf[8] = crc_xor(tx_buf,8);
              uart_send(tx_buf,9);
       __bis_SR_register(LPM4_bits + GIE);     // Enter LPM4, Enable interrupts
       __no_operation();                       // For debugger
#pragma vector=TIMER1_A0_VECTOR
__interrupt void TIMER1_A0_ISR(void)
    second_flag = 1;
   __bic_SR_register_on_exit(LPM4_bits);             // Enter LPM3  每隔30毫秒1次
程序如上,去掉
这三句话,程序正常运行,电流大概在8.6MA,可以采集到实时数据,并每隔30毫秒串口发出,
但是,加入低功耗,AD采集数据一直不变,且三组数据都是一样的一组,低功耗也没降下电流还是8.6MA请问怎么回事呢?急急~~~~~~~~
vivilzb1985 发表于 2014-7-14 14:43 | 显示全部楼层
这个问题的还是需要看下你的AD采集的,有可能是你的AD还在采集的,你就进入了LMP3低功耗模式。
vivilzb1985 发表于 2014-7-14 14:44 | 显示全部楼层
让系统进入低功耗模式不要让定时进入的,而是让执行完Ad采集的再让进入的即可的。
dirtwillfly 发表于 2014-7-14 15:16 | 显示全部楼层
按照正常的工作顺序:定时唤醒进行采样,采样结束进入低功耗状态。而不是定时进入低功耗状态
你可以观察一下你的AD采样需要多长时间,
shenmu2012 发表于 2014-7-14 23:07 | 显示全部楼层
低功耗的话需要关掉响应的模块外设的,当然还有那些不用的IO口的,最好是设置成输入状态的高阻态的
