[i.MX] ubuntu12.04安装LTIB问题,用的L3.0.35(已解决)
3904|17
 楼主| zjwyczj 发表于 2014-9-3 15:40 | 显示全部楼层 |阅读模式
Processing: elftosb
Build path taken because: no prebuilt rpm,
rpmbuild --dbpath ///opt/freescale/ltib/var/lib/rpm --target i686 --define '_unpackaged_files_terminate_build 0' --define '_target_cpu i686' --define '__strip strip' --define '_topdir /opt/freescale/ltib/usr/src/rpm' --define '_prefix /opt/freescale/ltib/usr' --define '_tmppath /home/chengziji/ltib/ltib/tmp' --define '_rpmdir /opt/freescale/ltib/usr/src/rpm/RPMS'  --define '_mandir /opt/freescale/ltib/usr/share/man' --define '_sysconfdir /opt/freescale/ltib/etc' --define '_localstatedir /var' -bb --clean --rmsource  /home/chengziji/ltib/ltib/dist/lfs-5.1/elftosb/elftosb.spec
Building target platforms: i686
Building for target i686
Executing(%prep): /bin/sh -e /home/chengziji/ltib/ltib/tmp/rpm-tmp.66172
+ umask 022
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD
+ rm -rf elftosb-3.0.35-4.1.0
+ tar -xvvf -
+ /bin/gzip -dc /opt/freescale/ltib/usr/src/rpm/SOURCES/elftosb-3.0.35-4.1.0.tar.gz
drwxrwxr-x root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/
-rw-rw-r-- root/root      1533 2011-03-01 12:05 elftosb-3.0.35-4.1.0/COPYING
-rw-rw-r-- root/root      1884 2011-03-01 12:05 elftosb-3.0.35-4.1.0/ReadMe.txt
drwxrwxr-x root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/bdfiles/
-rw-rw-r-- root/root      3401 2011-03-01 12:05 elftosb-3.0.35-4.1.0/bdfiles/basic_test_cmd.e
-rw-rw-r-- root/root      5404 2011-03-01 12:05 elftosb-3.0.35-4.1.0/bdfiles/complex.bd
-rw-rw-r-- root/root       563 2011-03-01 12:05 elftosb-3.0.35-4.1.0/bdfiles/habtest.bd
-rw-rw-r-- root/root       112 2011-03-01 12:05 elftosb-3.0.35-4.1.0/bdfiles/simple.e
-rw-rw-r-- root/root      2659 2011-03-01 12:05 elftosb-3.0.35-4.1.0/bdfiles/test_cmd.e
drwxrwxr-x root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/
-rw-rw-r-- root/root      2321 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/AESKey.cpp
-rw-rw-r-- root/root      3654 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/AESKey.h
-rw-rw-r-- root/root      2421 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Blob.cpp
-rw-rw-r-- root/root      1553 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Blob.h
-rw-rw-r-- root/root      1360 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/BootImage.h
-rw-rw-r-- root/root      6066 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/DataSource.cpp
-rw-rw-r-- root/root      9216 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/DataSource.h
-rw-rw-r-- root/root      3660 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/DataSourceImager.cpp
-rw-rw-r-- root/root      1036 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/DataSourceImager.h
-rw-rw-r-- root/root      1745 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/DataTarget.cpp
-rw-rw-r-- root/root      3998 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/DataTarget.h
-rw-rw-r-- root/root     10445 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/ELF.h
-rw-rw-r-- root/root     14307 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/ELFSourceFile.cpp
-rw-rw-r-- root/root      6906 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/ELFSourceFile.h
-rw-rw-r-- root/root     46497 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/EncoreBootImage.cpp
-rw-rw-r-- root/root     35659 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/EncoreBootImage.h
-rw-rw-r-- root/root      4653 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/EndianUtilities.h
-rw-rw-r-- root/root      2576 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/EvalContext.cpp
-rw-rw-r-- root/root      2633 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/EvalContext.h
-rw-rw-r-- root/root      1914 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/ExcludesListMatcher.cpp
-rw-rw-r-- root/root      1915 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/ExcludesListMatcher.h
-rw-rw-r-- root/root      3245 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/GHSSecInfo.cpp
-rw-rw-r-- root/root      2135 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/GHSSecInfo.h
-rw-rw-r-- root/root      2511 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/GlobMatcher.cpp
-rw-rw-r-- root/root      1590 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/GlobMatcher.h
-rw-rw-r-- root/root       812 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/HexValues.cpp
-rw-rw-r-- root/root       549 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/HexValues.h
-rw-rw-r-- root/root      2688 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/IVTDataSource.cpp
-rw-rw-r-- root/root     10408 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/IVTDataSource.h
-rw-rw-r-- root/root      1516 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Logging.cpp
-rw-rw-r-- root/root      7048 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Logging.h
-rw-rw-r-- root/root      1185 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Operation.cpp
-rw-rw-r-- root/root      4305 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Operation.h
-rw-rw-r-- root/root      1466 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/OptionContext.h
-rw-rw-r-- root/root      4180 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/OptionDictionary.cpp
-rw-rw-r-- root/root      3236 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/OptionDictionary.h
-rw-rw-r-- root/root       184 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/OutputSection.cpp
-rw-rw-r-- root/root      1896 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/OutputSection.h
-rw-rw-r-- root/root      1557 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Random.cpp
-rw-rw-r-- root/root      1138 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Random.h
-rw-rw-r-- root/root      2251 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/RijndaelCBCMAC.cpp
-rw-rw-r-- root/root      1435 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/RijndaelCBCMAC.h
-rw-rw-r-- root/root      7335 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/SHA1.cpp
-rw-rw-r-- root/root      3735 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/SHA1.h
-rw-rw-r-- root/root      5200 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/SRecordSourceFile.cpp
-rw-rw-r-- root/root      2242 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/SRecordSourceFile.h
-rw-rw-r-- root/root      3210 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/SearchPath.cpp
-rw-rw-r-- root/root      1360 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/SearchPath.h
-rw-rw-r-- root/root      4177 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/SourceFile.cpp
-rw-rw-r-- root/root      4696 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/SourceFile.h
-rw-rw-r-- root/root     17992 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/StELFFile.cpp
-rw-rw-r-- root/root      6620 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/StELFFile.h
-rw-rw-r-- root/root     14292 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/StExecutableImage.cpp
-rw-rw-r-- root/root      9642 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/StExecutableImage.h
-rw-rw-r-- root/root      5980 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/StSRecordFile.cpp
-rw-rw-r-- root/root      3484 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/StSRecordFile.h
-rw-rw-r-- root/root      1617 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/StringMatcher.h
-rw-rw-r-- root/root       842 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Value.cpp
-rw-rw-r-- root/root      4152 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Value.h
-rw-rw-r-- root/root      3369 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Version.cpp
-rw-rw-r-- root/root      1031 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/Version.h
-rw-rw-r-- root/root     15294 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/crc.cpp
-rw-rw-r-- root/root       965 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/crc.h
-rw-rw-r-- root/root      1749 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/format_string.cpp
-rw-rw-r-- root/root       411 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/format_string.h
-rw-rw-r-- root/root       428 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/int_size.h
-rw-rw-r-- root/root     33274 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/options.cpp
-rw-rw-r-- root/root     16656 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/options.h
-rw-rw-r-- root/root     90763 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/rijndael.cpp
-rw-rw-r-- root/root      5729 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/rijndael.h
-rw-rw-r-- root/root      6510 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/smart_ptr.h
-rw-rw-r-- root/root       286 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/stdafx.cpp
-rw-rw-r-- root/root      2238 2011-03-01 12:05 elftosb-3.0.35-4.1.0/common/stdafx.h
-rw-rw-r-- root/root       201 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb.ccscc
-rw-rw-r-- root/root  16092160 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb.ncb
-rw-rw-r-- root/root      3000 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb.sln
-rw-rw-r-- root/root     56320 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb.suo
drwxrwxr-x root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb.xcodeproj/
-rw-rw-r-- root/root     46844 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb.xcodeproj/creed.mode1
-rw-rw-r-- root/root     47231 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb.xcodeproj/creed.mode1v3
-rw-rw-r-- root/root    132838 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb.xcodeproj/creed.pbxuser
-rw-rw-r-- root/root     62729 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb.xcodeproj/project.pbxproj
drwxrwxr-x root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/
-rw-rw-r-- root/root      1958 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/BootImageGenerator.cpp
-rw-rw-r-- root/root      2064 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/BootImageGenerator.h
-rw-rw-r-- root/root     43570 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/ConversionController.cpp
-rw-rw-r-- root/root      5713 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/ConversionController.h
-rw-rw-r-- root/root      9427 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/Doxyfile
-rw-rw-r-- root/root     31194 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/ElftosbAST.cpp
-rw-rw-r-- root/root     31790 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/ElftosbAST.h
-rw-rw-r-- root/root       562 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/ElftosbErrors.h
-rw-rw-r-- root/root      3254 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/ElftosbLexer.cpp
-rw-rw-r-- root/root      2752 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/ElftosbLexer.h
-rw-rw-r-- root/root      8371 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/EncoreBootImageGenerator.cpp
-rw-rw-r-- root/root      1853 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/EncoreBootImageGenerator.h
-rw-rw-r-- root/root      6344 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/FlexLexer.h
-rw-rw-r-- root/root     17088 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/elftosb.cpp
-rw-rw-r-- root/root     11601 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/elftosb2.vcproj
-rw-rw-r-- root/root     65498 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/elftosb_lexer.cpp
-rw-rw-r-- root/root      7107 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/elftosb_lexer.l
-rw-rw-r-- root/root     99126 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/elftosb_parser.tab.cpp
-rw-rw-r-- root/root      4106 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/elftosb_parser.tab.hpp
-rw-rw-r-- root/root     25821 2011-03-01 12:05 elftosb-3.0.35-4.1.0/elftosb2/elftosb_parser.y
drwxrwxr-x root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/encryptgpk/
-rw-rw-r-- root/root     11171 2011-03-01 12:05 elftosb-3.0.35-4.1.0/encryptgpk/encryptgpk.cpp
-rw-rw-r-- root/root      7040 2011-03-01 12:05 elftosb-3.0.35-4.1.0/encryptgpk/encryptgpk.vcproj
drwxrwxr-x root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/keygen/
-rw-rw-r-- root/root      9424 2011-03-01 12:05 elftosb-3.0.35-4.1.0/keygen/Doxyfile
-rw-rw-r-- root/root      7784 2011-03-01 12:05 elftosb-3.0.35-4.1.0/keygen/keygen.cpp
-rw-rw-r-- root/root      9576 2011-03-01 12:05 elftosb-3.0.35-4.1.0/keygen/keygen.vcproj
-rw-rw-r-- root/root       838 2011-03-01 12:05 elftosb-3.0.35-4.1.0/makefile
-rw-rw-r-- root/root      4373 2011-03-01 12:05 elftosb-3.0.35-4.1.0/makefile.rules
drwxrwxr-x root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/sbtool/
-rw-rw-r-- root/root      9424 2011-03-01 12:05 elftosb-3.0.35-4.1.0/sbtool/Doxyfile
-rw-rw-r-- root/root     13027 2011-03-01 12:05 elftosb-3.0.35-4.1.0/sbtool/EncoreBootImageReader.cpp
-rw-rw-r-- root/root      3742 2011-03-01 12:05 elftosb-3.0.35-4.1.0/sbtool/EncoreBootImageReader.h
-rw-rw-r-- root/root     19951 2011-03-01 12:05 elftosb-3.0.35-4.1.0/sbtool/sbtool.cpp
-rw-rw-r-- root/root      9866 2011-03-01 12:05 elftosb-3.0.35-4.1.0/sbtool/sbtool.vcproj
-rw-rw-r-- root/root       692 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_elftosb.bat
-rwxrwxr-x root/root       892 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_elftosb.sh
drwxrwxr-x root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/
-rw-rw-r-- root/root   1054698 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/ProfileSeed.bin
-rw-rw-r-- root/root     51200 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/ProfileSeedFile50k.bin
-rw-rw-r-- root/root      2444 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/hello_NOR_arm
-rw-rw-r-- root/root      1432 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/hello_NOR_arm.map
-rw-rw-r-- root/root      2496 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/hello_NOR_mixed
-rw-rw-r-- root/root      1476 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/hello_NOR_mixed.map
-rw-rw-r-- root/root      2348 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/hello_NOR_thumb
-rw-rw-r-- root/root      1432 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/hello_NOR_thumb.map
-rw-rw-r-- root/root   1292292 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/hostlink
-rw-rw-r-- root/root   1909984 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/player_linfix.elf
-rw-rw-r-- root/root      2884 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/plugin_complex
-rw-rw-r-- root/root      2068 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/plugin_hello
-rw-rw-r-- root/root    156236 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/redboot_gcc.srec
-rw-rw-r-- root/root     38496 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/rom_nand_ldr_profile
-rw-rw-r-- root/root   1451135 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/sd_player_gcc
-rw-rw-r-- root/root    539928 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/sd_player_gcc.srec
-rw-rw-r-- root/root        33 2011-03-01 12:05 elftosb-3.0.35-4.1.0/test_files/test0.key
drwxrwxr-x root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/winsupport/
-rw-rw-r-- root/root         0 2011-03-01 12:05 elftosb-3.0.35-4.1.0/winsupport/unistd.h
-rw-rw-r-- chengziji/chengziji 1689 2014-09-03 15:24 elftosb-3.0.35-4.1.0/stdafx.h
+ STATUS=0
+ [ 0 -ne 0 ]
+ cd elftosb-3.0.35-4.1.0
+ exit 0
Executing(%build): /bin/sh -e /home/chengziji/ltib/ltib/tmp/rpm-tmp.98701
+ umask 022
+ make
make -C bld/linux -f /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/makefile.rules SRC_DIR=/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0 all;
make[1]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/bld/linux'
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/common/AESKey.cpp
In file included from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/common/AESKey.h:10:0,
                 from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/common/AESKey.cpp:8:
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/common/stdafx.h:30:36: fatal error: /usr/include/sys/types.h: No such file or directory
compilation terminated.
make[1]: *** [AESKey.o] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0/bld/linux'
make: *** [all] Error 2
error: Bad exit status from /home/chengziji/ltib/ltib/tmp/rpm-tmp.98701 (%build)
RPM build errors:
Build time for elftosb: 1 seconds
Failed building elftosb
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
 楼主| zjwyczj 发表于 2014-9-3 15:47 | 显示全部楼层
 楼主| zjwyczj 发表于 2014-9-3 15:56 | 显示全部楼层
折腾死了,完全安装文档来的,那个在 Ubuntu 12.04 上用 LTIB 编译 linux BSP
FSL_TICS_Rita 发表于 2014-9-3 15:59 | 显示全部楼层
楼主你好,请问那些需要安装的packages你有都安装吗?
 楼主| zjwyczj 发表于 2014-9-3 16:04 | 显示全部楼层
都有安装的啊,就 aptitude那些是吧,做了脚本都安装了的
FSL_TICS_Rita 发表于 2014-9-3 16:17 | 显示全部楼层
sudo aptitude -y install gettext libgtk2.0-dev rpm bison m4 libfreetype6-dev
sudo aptitude -y install libdbus-glib-1-dev liborbit2-dev intltool
sudo aptitude -y install ccache ncurses-dev zlib1g zlib1g-dev gcc g++ libtool
sudo aptitude -y install uuid-dev liblzo2-dev
sudo aptitude -y install tcl dpkg
sudo aptitude -y install asciidoc texlive-latex-base dblatex xutils-dev
sudo apt-get install texinfo
FSL_TICS_Rita 发表于 2014-9-3 16:19 | 显示全部楼层
还有你安装前有更新 ubuntu packages和Update source list吗?
FSL_TICS_Rita 发表于 2014-9-3 16:20 | 显示全部楼层
如果 你的ubuntu是64位的你还要安装:sudo aptitude -y install ia32-libs libc6-dev-i386 lib32z1。
 楼主| zjwyczj 发表于 2014-9-3 16:43 | 显示全部楼层
Update source list都失败的,不知道怎么回事
如果 你的ubuntu是64位的你还要安装:sudo aptitude -y install ia32-libs libc6-dev-i386 lib32z1。 ...
这一步到是做了
FSL_TICS_Rita 发表于 2014-9-3 17:22 | 显示全部楼层
请问出现什么问题?更新的时候。
FSL_TICS_Rita 发表于 2014-9-3 18:01 | 显示全部楼层
你把你更新的时候遇到的问题发给我,我明天帮你看一下~~
 楼主| zjwyczj 发表于 2014-9-4 12:48 | 显示全部楼层
恩,多谢啦,我现在暂时先不要LTIB了,到时候如果用了在贴出来吧
FSL_TICS_Rita 发表于 2014-9-4 17:28 | 显示全部楼层
好的,有问题联系我哈~~
FSL_TICS_Rita 发表于 2014-9-4 17:30 | 显示全部楼层
楼主你好,要不你先把这个帖子结了,有问题你再创建新帖,我怕到时候你在这里更新我看不到~~
 楼主| zjwyczj 发表于 2014-9-4 17:36 | 显示全部楼层
楼主你好,要不你先把这个帖子结了,有问题你再创建新帖,我怕到时候你在这里更新我看不到~~ ...
好的
FSL_TICS_Rita 发表于 2014-9-5 15:36 | 显示全部楼层
好的
非常感谢您的支持~~
FSL_TICS_Rita 发表于 2014-10-9 14:28 | 显示全部楼层
楼主你好,麻烦帮忙结帖啊,非常感谢~~
