[STM32F2] stm32f2 spi和外部芯片通信的问题。
1985|5
 楼主| 程轩104 发表于 2014-9-23 17:25 | 显示全部楼层 |阅读模式
lz菜鸟,最近在想用spi和外部芯片通信,搞半天没弄出来。贴出代码,大家看看有什么问题。
  1. #include <spi.h>
  2. void Spi2_4438_Init(void)
  3. {
  4.   GPIO_InitTypeDef GPIO_InitStructure;
  5.   SPI_InitTypeDef SPI_InitStructure;
  6.   /* 使能gpio时钟和SPI2 */
  7.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  8.   /*  Enable SCK, MOSI, MISO and NSS GPIO clocks using RCC_AHB1PeriphClockCmd()*/
  9.   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);    //?
  10.   /* Connect PB12 to SPI2_SCK */
  11.   GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_SPI2);
  12.   /* Connect PB14 to SPI2_MISO */
  13.    GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_SPI2);
  14.   /* Connect PB15 to SPI2_MOSI */
  15.   GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_SPI2);
  16.
  17.
  18.   /* Configure SPI2 pins as alternate function (No need to
  19.   configure PB13 since NSS will be managed by software) */
  20.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_15;
  21.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  22.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  23.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  24.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  25.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  26.
  27.   /*spi CONFIGURATION*/
  28.   SPI_Cmd(SPI2, DISABLE);      //使能SPI2
  29.   SPI_InitStructure.SPI_Direction =SPI_Direction_2Lines_FullDuplex; //双线输入输出全双工模式
  30.   SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置为SPI的主机模式
  31.   SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //SPI数据大小:发送8位帧数据结构
  32.   SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;   //设备空闲状态时同步时钟SCK的状态,High表示高电平,Low表示低电平
  33.   SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;  //时钟相位,1表示在同步时钟SCK的奇数沿边采样,2表示偶数沿边采样
  34.   SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;     //NSS由软件控件片选
  35.   SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;//时钟的预分频值
  36.   SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;  //MSB高位在前
  37.   SPI_InitStructure.SPI_CRCPolynomial = 7;     //CRC较验和的多项式
  38.   SPI_Init(SPI2, &SPI_InitStructure);   //初始化SPI2的配置项
  39.   SPI_Cmd(SPI2, ENABLE);      //使能SPI2
  40. }
  41. void main(void)
  42. {
  43. // init_gpled();   //亮灯
  44.
  45. //  初始化spi
  46.     uint16_t tmp;
  47.     tmp=5;
  48.     Spi2_4438_Init();
  49.
  50.     while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET)
  51.     {
  52.     }
  53.     SPI_I2S_SendData(SPI2,0);
  54.     while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET)
  55.     {
  56.     }
  57.     SPI_I2S_ReceiveData(SPI2);
  58.     while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET)
  59.     {
  60.     }
  61.     SPI_I2S_SendData(SPI2,0x0c);
  62.     while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET)
  63.     {
  64.     }
  65.     tmp=SPI_I2S_ReceiveData(SPI2);
  66.     if(tmp!=0)
  67.     {
  68.         init_gpled();
  69.     }
  70. }
单步调试到    while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET)
这步的时候就卡主了,也不知道是什么原因,不知道是不是初始化的时钟没有配置好还是什么地。求大神帮帮忙
 楼主| 程轩104 发表于 2014-9-23 17:29 | 显示全部楼层
提示: 该帖被管理员或版主屏蔽
mmuuss586 发表于 2014-9-23 19:24 | 显示全部楼层
第一句这个前面while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET)
加上这个SPI_I2S_SendData(SPI2,0);
airwill 发表于 2014-9-23 21:36 | 显示全部楼层
应该是卡在第二个
吧,因为接收的数据你没有处理, 一直处在 RXNE 状态。所以这个状态跳不过去了。
 楼主| 程轩104 发表于 2014-9-24 11:18 | 显示全部楼层
应该是卡在第二个
吧,因为接收的数据 ...
是啊。就是卡在这里啊,那要怎么做才能跳过去啊,有点晕了。
airwill 发表于 2014-9-24 13:21 | 显示全部楼层
那要怎么做才能跳过去啊,有点晕了!
不会吧, 这样还要问?           -----------读接受的数据就是了。
