9、使用DHCP client时,手动配置DNS的IP地址方法如下:必须在DHCP配置完成以后再手动增加DNS服务。
// Service Status Reports
static char *TaskName[] = { "Telnet","HTTP","NAT","DHCPS","DHCPC","DNS" };
static char *ReportStr[] = { "","Running","Updated","Complete","Fault" };
static char *StatusStr[] = { "Disabled","Waiting","IPTerm", "Failed","Enabled" };
static void ServiceReport( uint Item, uint Status, uint Report, HANDLE h )
printf( "Service Status: %-9s: %-9s: %-9s: %03d/n",
TaskName[Item-1], StatusStr[Status],
ReportStr[Report/256], Report&0xFF );
// Example of adding to the DHCP configuration space
// When using the DHCP client, the client has full control over access
// to the first 256 entries in the CFGTAG_SYSINFO space. Here, we want
// to manually add a DNS server to the configuration, but we can only
// do it once DHCP has finished its programming.
if( Item == CFGITEM_SERVICE_DHCPCLIENT &&
Status == CIS_SRV_STATUS_ENABLED &&
(Report == (NETTOOLS_STAT_RUNNING|DHCPCODE_IPADD) ||
Report == (NETTOOLS_STAT_RUNNING|DHCPCODE_IPRENEW)) )
IPN IPTmp;
// Manually add the DNS server when specified. If the address
// string reads "0.0.0.0", IPTmp will be set to zero.
IPTmp = inet_addr(DNSServer);
if( IPTmp )
CfgAddEntry( 0, CFGTAG_SYSINFO, CFGITEM_DHCP_DOMAINNAMESERVER,
0, sizeof(IPTmp), (UINT8 *)&IPTmp, 0 );
