HIP4081的datasheet里有两个电路图,第三页是AHI和BHI都接12V,第十三页是AHI和BHI都是外部控制。这两种方法我都试过了,还是不行。
HIP4081的数据手册关于八脚九脚延迟电阻说明:High-side turn-on DELay. Connect resistor from this pin to VSS to set timing current that defines the turn-on delay of both high-side drivers. The low-side drivers turn-off with no adjustable delay, so the HDEL resistor guarantees no shoot-through by delaying the turn-on of the high-side drivers. HDEL reference voltage is approximately 5.1V.
从上面这段看出:“延迟电阻保证高侧MOS打开时会延时不会直通。”那么高侧MOS在关断的时候并没有提前关断,而是PWM上升到一定电平时,高侧MOS才会关断,这就是高侧MOS的栅极波形下降沿与低侧MOS的栅极波形上升沿重叠的原因,即BHO下降沿与BLO上升沿重叠,造成MOS过热(空载)并且嗡嗡嗡的响。
