[i.MX] imx6q安卓启动失败显示Suspending console(s)(已解决)
8497|18
 楼主| fronzon 发表于 2014-10-23 15:37 | 显示全部楼层 |阅读模式
开发板imx6q,使用安卓系统为官网的android_jb4.3_1.1.0-ga_image_6qsabresd.tar.gz中的
u-boot-6q.bin
eMMC/boot.img
eMMC/system.img
eMMC/recovery.img
使用mfgtools下载到emmc,进行启动,但启动失败了:
到这句话的时候停止不往下进行了:
PM: Entering mem sleep
Suspending console(s) (useno_console_suspend to debug)
请教各位!谢谢
 楼主| fronzon 发表于 2014-10-23 15:40 | 显示全部楼层
root后的启动代码如下,供参考:
root@sabresd_6dq:/ # EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
ERROR: v4l2 capture: slave not found!
warning: `zygote' uses 32-bit capabilities (legacy support in use)
request_suspend_state: wakeup (3->0) at 23445312336 (1970-01-02 00:00:12.815642334 UTC)
cpufreq_interactive_input_connect: connect to max11801_ts
mma enable setting active
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
ADDRCONF(NETDEV_UP): eth0: link is not ready
acc_open
acc_release
ehci_fsl_bus_resume begins, Host 1
ehci_fsl_bus_resume ends, Host 1
ehci_fsl_bus_resume begins, DR
ehci_fsl_bus_suspend begins, Host 1
ehci_fsl_bus_suspend ends, Host 1
init: sys_prop: permission denied uid:1003  name:service.bootanim.exit
request_suspend_state: sleep (0->3) at 92603837345 (1970-01-02 00:01:21.974165343 UTC)
mma enable setting inactive
PM: Syncing filesystems ... done.
PM: Preparing system for mem sleep
suspend: start 1 suspend...
suspend: finish 1 suspend after:0.2603000 seconds...
Freezing user space processes ... (elapsed 0.01 seconds) done.
Freezing remaining freezable tasks ... (elapsed 0.01 seconds) done.
Suspending console(s) (use no_console_suspend to debug)
USB Host suspend begins
ehci_fsl_drv_suspend, pm event
host suspend ends
udc suspend begins
USB Gadget suspend ends
host suspend ends
add wake up source irq 101
add wake up source irq 99
add wake up source irq 103
add wake up source irq 51
PM: suspend of devices complete after 12.320 msecs
PM: late suspend of devices complete after 0.604 msecs
Disabling non-boot CPUs ...
CPU1: shutdown
CPU2: shutdown
CPU3: shutdown
Enabling non-boot CPUs ...
CPU1: Booted secondary processor
Calibrating delay loop (skipped) already calibrated this CPU
i.MXC CPU frequency driver
CPU1 is up
CPU2: Booted secondary processor
CPU2 is up
CPU3: Booted secondary processor
CPU3 is up
PM: early resume of devices complete after 0.424 msecs
wakeup wake lock: alarm_rtc
imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
imx-ipuv3 imx-ipuv3.1: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
remove wake up source irq 51
remove wake up source irq 103
remove wake up source irq 101
remove wake up source irq 99
ehci fsl drv resume begins: DR
ehci_fsl_drv_resume,pm event, wait for wakeup irq if needed
USB Gadget resume begins
fsl_udc_resume, Wait for wakeup thread finishes
dr_controller_run: udc enter low power mode
USB Gadget resume ends
ehci fsl drv resume begins: Host 1
PM: resume of devices complete after 97.620 msecs
PM: Finishing wakeup.
Restarting tasks ... done.
suspend: finish 1 suspend after:3.990689324 seconds...
suspend: exit suspend, ret = 0 (1970-01-02 00:01:26.212731333 UTC)
suspend: start 2 suspend...
suspend: finish 2 suspend after:0.2603333 seconds...
pm_op(): platform_pm_suspend+0x0/0x5c returns -16
PM: Device alarm failed to suspend: error -16
PM: Some devices failed to suspend
PM: resume of devices complete after 0.546 msecs
suspend: finish 2 suspend after:0.88187332 seconds...
suspend: exit suspend, ret = -16 (1970-01-02 00:01:27.041896666 UTC)
mmc0: Starting deferred resume
mmc0: Deferred resume completed
suspend: start 3 suspend...
suspend: finish 3 suspend after:0.2659000 seconds...
Freezing user space processes ... (elapsed 0.02 seconds) done.
FSL_TICS_Rita 发表于 2014-10-23 15:42 | 显示全部楼层
请问你开发板型号是哪个?飞思卡尔的开发板吗?还是自己设计的板子?
 楼主| fronzon 发表于 2014-10-23 15:47 | 显示全部楼层
飞思卡尔的开发板MCIMX6Q-SDB
感觉开发板启动后就一直想休眠,如果在启动过程中尽快的输入操作命令,例如ls、cd命令,那么会暂时的停留在安卓系统中一段时间,但一会又开始Suspendingconsole
FSL_TICS_Rita 发表于 2014-10-23 15:50 | 显示全部楼层
楼主你好,你能给我你串口上所有的打印信息吗?看这一句看不出来哪里的问题。
FSL_TICS_Rita 发表于 2014-10-23 15:52 | 显示全部楼层
感觉应该是起来了,进入休眠模式了,请问你在屏上看到显示了吗?
 楼主| fronzon 发表于 2014-10-23 16:03 | 显示全部楼层
楼主你好,你能给我你串口上所有的打印信息吗?看这一句看不出来哪里的问题。 ...
acc_open
acc_release
host suspend ends
udc suspend begins
host suspend ends
CPU1: shutdown
CPU2: shutdown
CPU3: shutdown
CPU1 is up
CPU2 is up
CPU3 is up
FSL_TICS_Rita 发表于 2014-10-23 16:19 | 显示全部楼层
楼主你好,启动过程没有什么问题,就是休眠时间设置的太短了,建议你板子起来后到setting里重新设置一下休眠时间。
FSL_TICS_Rita 发表于 2014-10-23 16:21 | 显示全部楼层
你也可以按一下sw3键。不过最好还是重新设置一下休眠时间比较好。
 楼主| fronzon 发表于 2014-10-23 16:21 | 显示全部楼层
控制台信息.pdf (153.81 KB, 下载次数: 33)
控制台打印的信息,已经以附件的形式上传。
 楼主| fronzon 发表于 2014-10-23 16:27 | 显示全部楼层
楼主你好,启动过程没有什么问题,就是休眠时间设置的太短了,建议你板子起来后到setting里重新设置一下休 ...
请教:板子起来后,怎么在setting里面设置,我没找到setting在哪里
FSL_TICS_Rita 发表于 2014-10-23 16:30 | 显示全部楼层
请问你使用的是哪个屏啊?
FSL_TICS_Rita 发表于 2014-10-23 16:34 | 显示全部楼层
在android的界面里的设置中设置的。
FSL_TICS_Rita 发表于 2014-10-23 17:17 | 显示全部楼层
Yes,Great. 你的理解是对的。:)
FSL_TICS_Rita 发表于 2014-10-24 16:13 | 显示全部楼层
楼主你好,本帖中的问题已经解决的话,麻烦帮忙结帖啊。欢迎有问题继续在本论坛中交流哈~~
FSL_TICS_Rita 发表于 2014-11-27 15:20 | 显示全部楼层
楼主你好,请问你本贴中的问题是否已经解决了?如果没有欢迎继续在这里讨论哈,如果已解决麻烦帮忙结帖哈,非常感谢~~
sugar1015 发表于 2015-7-6 14:57 | 显示全部楼层
最后怎么解决啊  系统进去不 怎么设置呢
esyintao 发表于 2015-10-8 16:11 | 显示全部楼层
界面进不去呢,可以在那里修改代码设置吗?
mini1986 发表于 2015-10-9 10:41 | 显示全部楼层
有个echo命令可以禁止系统进入休眠......具体记不住了,网上找找吧......
