[STM32F1] 程序烧到板子了没任何反应!!!!
1222|4
 楼主| 星夜之北 发表于 2014-10-27 21:46 | 显示全部楼层 |阅读模式
IO, pi, rc, GPIO, gp
/*Include---------------------------*/
#include"stm32f10x_lib.h"                //包含所有的头文件
#include<stdio.h>
//----------------函数声明--------------------
void Delay_MS(u16 dly);
void RCC_Configuration(void);
void GPIO_Configuration(void);
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
//int main(void)
//   GPIOC->CRL=0X33;
//   GPIOC->ODR=0x03;
int main(void)
        #ifdef DEBUG
        debug();
        #endif
        //------------初始化------------
        RCC_Configuration();
        GPIO_Configuration();
        while(1)
                GPIO_SetBits(GPIOC, GPIO_Pin_1);
                Delay_MS(500);
                GPIO_ResetBits(GPIOC, GPIO_Pin_1);
                Delay_MS(500);
* Function Name  : Delay_Ms
* Description    : delay 1 ms.
* Input          : dly (ms)
* Output         : None
* Return         : None
        u16 i,j;
        for(i=0;i<dly;i++)
                for(j=1000;j>0;j--);
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
        //----------使用外部RC晶振-----------
        RCC_DeInit();                        //初始化为缺省值
        RCC_HSEConfig(RCC_HSE_ON);        //使能外部的高速时钟
        while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET);        //等待外部高速时钟使能就绪
        FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);        //Enable Prefetch Buffer
        FLASH_SetLatency(FLASH_Latency_2);                //Flash 2 wait state
        RCC_HCLKConfig(RCC_SYSCLK_Div1);                //HCLK = SYSCLK
        RCC_PCLK2Config(RCC_HCLK_Div1);                        //PCLK2 =  HCLK
        RCC_PCLK1Config(RCC_HCLK_Div2);                        //PCLK1 = HCLK/2
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);        //PLLCLK = 8MHZ * 9 =72MHZ
        RCC_PLLCmd(ENABLE);                        //Enable PLLCLK
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);        //Wait till PLLCLK is ready
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);        //Select PLL as system clock
        while(RCC_GetSYSCLKSource()!=0x08);                //Wait till PLL is used as system clock source
        //---------打开相应外设时钟--------------------
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);        //使能APB2外设的GPIOA的时钟
* Function Name  : GPIO_Configuration
* Description    : 初始化GPIO外设
* Input          : None
* Output         : None
* Return         : None
        GPIO_InitTypeDef        GPIO_InitStructure;                //声明一个结构体变量
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;         //选择PA.3
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;         //管脚频率为50MHZ
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;         //输出模式为推挽输出
        GPIO_Init(GPIOA,&GPIO_InitStructure);                                 //初始化GPIOA寄存器
FAQ 发表于 2014-10-27 22:33 | 显示全部楼层
你想要啥反应
拿起书本 发表于 2014-10-29 15:12 | 显示全部楼层
建议楼主找一个别人的、成熟的程序写入单片机试一试。
LOVE_ELEC 发表于 2014-10-29 15:51 | 显示全部楼层
楼主你初始化的管腿与你主函数中使用的管腿好像不是一个哦!void GPIO_Configuration(void)
while(1)
                Delay_MS(500);
                Delay_MS(500);
 楼主| 星夜之北 发表于 2014-11-6 12:39 | 显示全部楼层
        GPIO ...
好像是哦 我再试试!!
