[STM32F3] STM32F302x openOCD怎么配置?居然与F303x不通用。
2911|0
 楼主| styleno1 发表于 2014-10-30 09:26 | 显示全部楼层 |阅读模式
  1. # This is an STM32F3 discovery board with a single STM32F303VCT6 chip.
  2. source [find interface/stlink-v2.cfg]
  3. source [find target/stm32f3x_stlink.cfg]
  4. # use hardware reset, connect under reset
  5. reset_config srst_only srst_nogate
上面是安装目录带的F303x配置,提示信息:
  1. Open On-Chip Debugger 0.8.0 (2014-04-28-08:42)
  2. Licensed under GNU GPL v2
  3. For bug reports, read
  4. Info : This adapter doesn't support configurable speed
  5. Info : STLINK v2 JTAG v21 API v2 SWIM v5 VID 0x0483 PID 0x374B
  6. Info : using stlink api v2
  7. Info : Target voltage: 3.250693
  8. Info : stm32f3x.cpu: hardware has 6 breakpoints, 4 watchpoints
  9. Info : accepting 'gdb' connection from 3333
  10. Info : device id = 0x10016439
  11. Warn : Cannot identify target as a STM32 family.
  12. Error: auto_probe failed
  13. Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
  14. Error: attempted 'gdb' connection rejected
注:我的板子是STM32F302 Nucleo,因无权限包含URL,删去了代码的链接。
