[STM32F1] 电压采样
1428|7
 楼主| wangpe 发表于 2014-10-30 11:39 | 显示全部楼层 |阅读模式
用AD1的通道15对温度传感器的上电压进行采样,通过WATCH窗口查看AD转换的结果发现采样的值总是一个大的范围的抖动,百思不得其解  温度传感的部分的电路如下 :AD部分的驱动如下:/****************ADC配置函数******************************/
void ConfigADC()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);      //打开ADC1的时钟
    ADC_InitStruct.ADC_Mode=ADC_Mode_Independent;                      /*!< Configures the ADC to operate in independent or
                                                       dual mode.
                                                      This parameter can be a value of @ref ADC_mode */
    ADC_InitStruct.ADC_ScanConvMode=DISABLE;             /*!< Specifies whether the conversion is performed in
                                                       Scan (multichannels) or Single (one channel) mode.
                                                       This parameter can be set to ENABLE or DISABLE */
    ADC_InitStruct.ADC_ContinuousConvMode=DISABLE;       /*!< Specifies whether the conversion is performed in
                                                        Continuous or Single mode.
                                                        This parameter can be set to ENABLE or DISABLE. */
    ADC_InitStruct.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;          /*!< Defines the external trigger used to start the analog
                                                        to digital conversion of regular channels. This parameter
                                                        can be a value of @ref ADC_external_trigger_sources_for_regular_channels_conversion */
    ADC_InitStruct.ADC_DataAlign=ADC_DataAlign_Right;                   /*!< Specifies whether the ADC data alignment is left or right.
                                                        This parameter can be a value of @ref ADC_data_align */
    ADC_InitStruct.ADC_NbrOfChannel=1;                     /*!< Specifies the number of ADC channels that will be converted
                                                        using the sequencer for regular channel group.
                                                        This parameter must range from 1 to 16. */
ADC_Init(ADC1,&ADC_InitStruct);
ADC_RegularChannelConfig(ADC1,ADC_Channel_11,1,ADC_SampleTime_239Cycles5);
ADC_Cmd(ADC1,ENABLE);
//初始化时开启一次自动校准
ADC_ResetCalibration(ADC1);
     while(ADC_GetResetCalibrationStatus(ADC1));
      // Start ADC1 calibaration
     ADC_StartCalibration(ADC1);
      // Check the end of ADC1 calibration
     while(ADC_GetCalibrationStatus(ADC1));
AD的时钟为12M   RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_ADCCLKConfig(RCC_PCLK2_Div6);
通道11的对应端口为PC1:GPIO_InitStruct.GPIO_Pin=GPIO_Pin_1;
GPIO_InitStruct.GPIO_Speed=GPIO_Speed_10MHz;
GPIO_InitStruct.GPIO_Mode=GPIO_Mode_AIN;     //模拟输入
GPIO_Init(GPIOC,&GPIO_InitStruct);
读取AD结果int16_t TemperSample()   //要关闭外部中断,启动一次AD转换,计算出温度值
uint16_t   T_Vaule,i;
// ADC_Cmd(ADC1,ENABLE);
   ADC_SoftwareStartConvCmd(ADC1,ENABLE);    //开启一次软件触发AD
   while(!ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC));
   T_Vaule=ADC_GetConversionValue(ADC1);  //取回转换值
return(T_Vaule);
 楼主| wangpe 发表于 2014-10-30 11:40 | 显示全部楼层
VEF+ VEF值也正常 ,搞了一天了 头疼死了
langgq 发表于 2014-10-30 11:41 | 显示全部楼层
1.什么芯片?
2.抖动是多大?
 楼主| wangpe 发表于 2014-10-30 11:41 | 显示全部楼层
STM32F107VC    从WATCH上看  大概从0x6b0到0x7e0    用万用表量过 当时温度传感上的电压为1.51V
wangzsa 发表于 2014-10-30 11:43 | 显示全部楼层
温度传感器是STM32F107VC  内部的吗?  从0x6b0到0x7e0  抖动太大。可以看看 Vref+和GND的PCB走线和滤波怎么样。
可以直接用2个1k电阻对Vref+进行分压、测量,看抖动如何。
 楼主| wangpe 发表于 2014-10-30 11:44 | 显示全部楼层
我用的是开发板上的AD口来检测外部的温度传感器,后来发现这个AD口本来就连接着其它东西,后来换了个AD口就好了!
多谢大家啦
