[i.MX] freescale imx6q 烧写linux出错
2605|6
 楼主| xuehuabang 发表于 2014-11-25 10:48 | 显示全部楼层 |阅读模式
U-Boot 2009.08 (Aug 16 2013 - 14:38:59)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 173
Temperature:   38 C, calibration data 0x5484b169
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [POR ]
Boot Device: MMC
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
Using default environment
/dev/ptyu7               /dev/ttyd9
/dev/disk:
by-id    by-path  by-uuid
/dev/input:
mice    uinput
/dev/pts:
/dev/shm:
/dev/snd:
timer
UTP: sending Success to kernel for command $ ls /dev/*.
UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16'
UTP: executing "dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16"
16+0 records in
16+0 records out
8192 bytes (8.0KB) copied, 0.002789 seconds, 2.8MB/s
UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16.
utp_poll: pass returned.
UTP: received command '$ echo 1 >mmc0: DO NOT switch the partitions that used to be
accessed in OS layer HERE. please following the
/sys/devices/platform/sdhci-esdh guidance of Documentation/mmc/mmc-dev-parts.txt.
c-imx.3/mmc_host/mmc0/mmc0:0001/boot_config'
UTP: executing "echo 1 > /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config"
sh: write error: Invalid argument
UTP: sending Non-success to kernel for command $ echo 1 > /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config.
utp_poll: exit with status 256
FSL_TICS_Rita 发表于 2014-11-25 14:44 | 显示全部楼层
楼主你好,请问你使用的是哪块板子?使用的是哪个版本的BSP,是要烧写到哪个flash中的呢?
 楼主| xuehuabang 发表于 2014-11-26 13:33 | 显示全部楼层
楼主你好,请问你使用的是哪块板子?使用的是哪个版本的BSP,是要烧写到哪个flash中的呢? ...
i.mx6q的板子,烧写BSP是L3.0.35_4.1.0_130816_source.gz的Linux,烧写工具是Mfgtools-Rel-4.1.0_130816_MX6Q_UPDATER,烧写到eMMC中
TriggerHuang 发表于 2014-11-26 14:52 | 显示全部楼层
i.mx6q的板子,烧写BSP是L3.0.35_4.1.0_130816_source.gz的Linux,烧写工具是Mfgtools-Rel-4.1.0_130816_ ...
建议FreeScale出一个发帖模板,里面加上一些必要的信息,比如 软件版本,硬件参考版,问题sync的步骤,等等!
