[i.MX] ubuntu 12.04 下安装QT时 make的错误提示
5497|5
 楼主| lqland 发表于 2014-12-1 13:16 | 显示全部楼层 |阅读模式
=========ubuntu 12.04 下安装QT时 make的错误提示==========哪位大神帮忙解答一下
qpaintervideosurface.cpp: In constructor ‘QVideoSurfaceGenericPainter:VideoSurfaceGenericPainter()’:
qpaintervideosurface.cpp:99:9: error: incomplete type ‘QOpenGLContext’ used in nested name specifier
qpaintervideosurface.cpp:99:47: error: incomplete type ‘QOpenGLContext’ used in nested name specifier
qpaintervideosurface.cpp: In member function ‘virtual QAbstractVideoSurface::Error QVideoSurfaceGenericPainter::start(const QVideoSurfaceFormat&)’:
qpaintervideosurface.cpp:140:13: error: incomplete type ‘QOpenGLContext’ used in nested name specifier
qpaintervideosurface.cpp:140:51: error: incomplete type ‘QOpenGLContext’ used in nested name specifier
make[3]: *** [.obj/qpaintervideosurface.o] Error 1
make[3]: Leaving directory `/home/ubuntu/myandroid/qt/qt-everywhere-opensource-src-5.4.0-rc/qtmultimedia/src/multimediawidgets'
make[2]: *** [sub-multimediawidgets-make_first] Error 2
make[2]: Leaving directory `/home/ubuntu/myandroid/qt/qt-everywhere-opensource-src-5.4.0-rc/qtmultimedia/src'
make[1]: *** [sub-src-make_first] Error 2
make[1]: Leaving directory `/home/ubuntu/myandroid/qt/qt-everywhere-opensource-src-5.4.0-rc/qtmultimedia'
make: *** [module-qtmultimedia-make_first] Error 2
root@ubuntu:/home/ubuntu/myandroid/qt/qt-everywhere-opensource-src-5.4.0-rc#
gaochy1126 发表于 2014-12-1 14:41 | 显示全部楼层
代码问题吧, 缺少opengl库吧
cloudsyncs 发表于 2015-1-12 17:24 | 显示全部楼层
我刚编译了也一样,这个有影响吗?
FSL_TICS_Rita 发表于 2015-1-12 17:40 | 显示全部楼层
楼主你好,编译QT的话,建议你参考一下我们英文论坛中的帖子:
https://community.freescale.com/docs/DOC-94066
FSL_TICS_Rita 发表于 2015-1-12 17:41 | 显示全部楼层
我刚编译了也一样,这个有影响吗?
楼主你好,建议你参考一下我们英文论坛中关于编译QT的帖子:
希望对你有帮助。
