我用的是STM32F4CubeF4的库文件,用SPI和一个芯片通讯。
通过SPI读回来的数据全是0x00,然后用Jlink仿真,发现待发送的数据根本就没有写到SPI_DR寄存器里去,SPI_DR寄存器里始终是0x00。
大家用过这个库文件里的SPI吗,能否给个例程?
初始化SPI的代码如下:
- void SPIx_Init(void)
- if(HAL_SPI_GetState(&hnucleo_Spi) == HAL_SPI_STATE_RESET)
- /* SPI Config */
- hnucleo_Spi.Instance = NUCLEO_SPIx; // SPI2
- /* SPI baudrate is set to 12,5 MHz maximum (PCLK2/SPI_BaudRatePrescaler = 100/8 = 12,5 MHz)
- to verify these constraints:
- - ST7735 LCD SPI interface max baudrate is 15MHz for write and 6.66MHz for read
- Since the provided driver doesn't use read capability from LCD, only constraint
- on write baudrate is considered.
- - SD card SPI interface max baudrate is 25MHz for write/read
- - PCLK2 max frequency is 100 MHz
- hnucleo_Spi.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_64;
- hnucleo_Spi.Init.Direction = SPI_DIRECTION_2LINES;
- hnucleo_Spi.Init.CLKPhase = SPI_PHASE_1EDGE;
- hnucleo_Spi.Init.CLKPolarity = SPI_POLARITY_LOW;
- hnucleo_Spi.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLED;
- hnucleo_Spi.Init.CRCPolynomial = 7;
- hnucleo_Spi.Init.DataSize = SPI_DATASIZE_8BIT;
- hnucleo_Spi.Init.FirstBit = SPI_FIRSTBIT_MSB;
- hnucleo_Spi.Init.NSS = SPI_NSS_SOFT;
- hnucleo_Spi.Init.TIMode = SPI_TIMODE_DISABLED;
- hnucleo_Spi.Init.Mode = SPI_MODE_MASTER;
- SPIx_MspInit(&hnucleo_Spi);
- HAL_SPI_Init(&hnucleo_Spi);
- static void SPIx_MspInit(SPI_HandleTypeDef *hspi)
- GPIO_InitTypeDef GPIO_InitStruct;
- /*** Configure the GPIOs ***/
- /* Enable GPIO clock */
- NUCLEO_SPIx_SCK_GPIO_CLK_ENABLE(); // Enable GPIOB RCC
- NUCLEO_SPIx_MISO_MOSI_GPIO_CLK_ENABLE(); // // Enable GPIOB RCC
- /* Configure SPI SCK */
- GPIO_InitStruct.Pin = NUCLEO_SPIx_SCK_PIN; // GPIOB_PIN_13
- GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
- GPIO_InitStruct.Alternate = NUCLEO_SPIx_SCK_AF; // 5
- HAL_GPIO_Init(NUCLEO_SPIx_SCK_GPIO_PORT, &GPIO_InitStruct);
- /* Configure SPI MISO and MOSI */
- GPIO_InitStruct.Pin = NUCLEO_SPIx_MOSI_PIN; // GPIOB_PIN_15
- GPIO_InitStruct.Alternate = NUCLEO_SPIx_MISO_MOSI_AF; // 5
- HAL_GPIO_Init(NUCLEO_SPIx_MISO_MOSI_GPIO_PORT, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = NUCLEO_SPIx_MISO_PIN; // GPIOB_PIN_14
- /* Configure SPI NSS */
- GPIO_InitStruct.Pin = GPIO_PIN_12;
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- HAL_GPIO_WritePin(NUCLEO_SPIx_SCK_GPIO_PORT, GPIO_PIN_12, GPIO_PIN_RESET);
- /*** Configure the SPI peripheral ***/
- /* Enable SPI clock */
- NUCLEO_SPIx_CLK_ENABLE();
另外,SPI2的时钟已经在库文件里的HAL层使能了。
请各位帮忙看看,多谢了!
