PICC16V9.50版本编译提示的Advisory怎么消除?<br />Clean: Deleting intermediary and output files.<br />Clean: Deleted file "E:program finishingHFT2HFT2_1.0.0.0main.obj".<br />Clean: Deleted file "E:program finishingHFT2HFT2_1.0.0.0main.cce".<br />Clean: Deleted file "HTFV1.0.0.0.cof".<br />Clean: Done.<br />Executing: "C:Program FilesHI-TECH SoftwarePICC9.50inpicc.exe" -C -E"main.cce" "main.c" -O"main.obj" -Zg9 -O -ASMLIST -ICD -Q -MPLAB -16F677<br />Advisory[1207] : some of the command line options you are using are now obsolete<br />Advisory[1208] : use --help option or refer to the user manual for option details<br />Executing: "C:Program FilesHI-TECH SoftwarePICC9.50BINPICC.EXE" -E"HTFV1.0.0.0.lde" "E:program finishingHFT2HFT2_1.0.0.0main.obj" -O"HTFV1.0.0.0.cof" -O"HTFV1.0.0.0.hex" -ICD -Q -MPLAB -16F677<br />Advisory[1207] : some of the command line options you are using are now obsolete<br />Advisory[1208] : use --help option or refer to the user manual for option details<br />-------------------------------------------------------------------------------------------------------------------------<br />Q:使用的PICC16V9.50版本、PIC16F677、MPLAB8.00,程序很简单,就一个空的主函数,编译提示BUILD SUCCEEDED: Tue Sep 30 22:14:28 2008,但在上面有一些Advisory提示,在以前8.05版本从来没遇到过,看Advisory以及后面的解释,似乎是有一些OPTION使用了老版本的命令,但我见项目的时候,都是用的MPLAB项目向导一路YES点下来的,自己从来没手工改动过这些编译的命令参数。<br /><br />代码就这么多。。。<br />//-----------------------------------------------------------------------------<br />//filename: <br />//Version: v1.0<br />//Designer: yezhen<br />//StartTime:<br />//EndTime: <br />//History: <br />//-----------------------------------------------------------------------------<br />#include "main.h"<br />//-----------------------------------------------------------------------------<br />BYTEBIT flag0;<br />//-----------------------------------------------------------------------------<br />void main(void)<br />{<br />//initsys();<br />while(1){<br />// clrwdt();<br />// OSCset();<br /> }<br />}<br />//-----------------------------------------------------------------------------<br />void interrupt ISR(void)<br />{<br />}<br />//-----------------------------------------------------------------------------<br /><br /><br />谁遇到过?这个问题如何解决? |
