freescale LTIB BSP 使用总结:
1.ltib BSP的简介(readme.bsp)
Freescale Linux(tm) Target Image Builder (ltib)
Board Support Package (BSP)
details
support
features(kernel,u-boot,Toolchain)
MPC8315E RDB Configuation File list
File Name Description
defconfig LTIB default Configuration
linux-2.6.29.6-mpc8315erdb.config Kernel default configuration
2.ltib安装(readme)
(1). As root, mount the ISO image of DVD #2 on your machine:
mount -o loop MPC8315ERDB_20090930-ltib.iso /mnt/cdrom
- or -
mount -o loop MPC8315ERDB_20090930-ltib.iso /media/cdrom
(2). As a non-root user, install the LTIB:
/mnt/cdrom/install
(3). Input the desired LTIB installation path when prompted.
The script will install LTIB into two different directories on your machine.
/opt/freescale/pkgs contains all the packages including Linux kernel, U-Boot and
application packages;
<install_path>/ltib contains the main LTIB scripts and spec files for MPC8315EMDS BSP.
There are no uninstall scripts. To uninstall LTIB, you need to run
ltib -m distclean
firstly to remove the /opt/freescale/pkgs, /opt/freescale/ltib
and <install_path>/ltib directories manually.
说明:安装的过程要装好多的库文件:
sudo apt-get install zlib1g-dev ncurses-dev rpm;
3.ltib的使用
(1) 修改内核或文件系统并编译时,一个比较简单的方法是利用自带的配置文件(defconfig)
$ ./ltib --preconfig config/platform/mpc8315erdb/defconfig
(2)ltib配置:
## 此配置默认不编译bootloader: [ ] Build a boot loader
## 若想修改此配置:
## 若需要编译bootloader,请找到并选中 Build a boot loader
## 此配置文件默认编译时不能修改配置内核:(X) Dont build the Linux kernel
## 若要编译内核,请找到并选中 kernel (linux 2.6.13.4) ---> (X) linux 2.6.13.4 ;其内核的默认配置文件为nas_linux-2.6.13.4-mpc8349itx.config
## 若要修改内核的默认文件为其他,请找到 kernel config file,回车输入相应的配置文件名,其默认目录为config/platform/mpc8349itx/
## 若想在编译时并修改内核,请找到并选中 Configure the kernel
## 若想修改文件系统,添加或删除程序包,请进入 Package list ---> 并选中相应的包
## 若想修改busybox选项配置,请进入并选中 Package list ---> Configure busybox at build time
## 其他目标系统配置、目标镜像生成选项配置类似。
## (解释)Load an Alternate Configuration File选项是选则一个已有的配置文件来自动配置各个选项
## Save Configuration to an Alternate File选项是将当前的配置信息保存为一个命名的文件名(eg:defconfig.liuby.today804)
## 最后退出时会弹出对话框,选择Yes保存,默认保存到config/platform/mpc8349itx/,名字是上面的命名
## 附注:同时生成的配置文件也会另存为 defconfig.dev(在config/platform/mpc8349itx/下),
(3)内核和busybox配置
上面的操作做完后开始编译,
假如选择了编译时配置内核,会弹出内核的配置对话框,可用用上面类似的方法修改配置
生成的内核配置文件为 nas_linux-2.6.13.4-mpc8349itx.config.dev(在config/platform/mpc8349itx/下)
内核编译完成后,开始选择程序包的编译,
如果选择了编译时配置busybox,会弹出 BusyBox Configuration 配置对话框
若不改文件名,生成的配置文件为busybox.config(在config/platform/mpc8349itx/下)
(4) 想看一下某些程序包的源码
busybox是linux常用命令工具集,可根据开发需要选择需要的命令工具
想看一下某些程序包的源码,比如kernel、uboot等这些看了有益于身心健康的程序源码,该怎么办呢? 还有一种情况就是这些源码中存放有板子的各种配置文件,比如内存映射分配,也需要看一下源码文件,其命令格式为 $ ./ltib -m prep -p <program_package_name>
## 下面这部分我是在large文件夹下操作,所写路径也是相对于/usr/local/mpc8349/large/来写的,而不是mytest文件夹下
## 例如我们要查看MPC8349ITX开发板上vsc7385的内存分配,或查找VSC7385的驱动模块部分,需要看uboot、内核源码,以下命令得到内核源码
$ ./ltib -m prep -p kernel
## 解压后的内核源码位于rpm/BUILD/linux-2.6.13/
$ ./ltib -m scbuild -p kernel ## 编译的镜像为rpm/BUILD/linux/arch/ppc/boot/images/uImage
以下命令可以得到uboot源码
$ ./ltib -m prep -p u-boot
## 解压后得到的uboot源码位于rpm/BUILD/u-boot-1.1.3
4.生成文件说明 :
rootfs.ext2.gz.uboot--ramdisk image that can be load with u-boot
rootfs.jffs2----jffs2 filesystem image
rootfs ---directory,the root file system that will be deployed on your Board
rootfs/boot/uImage -- kernel image that can be load with u-boot
rootfs/boot/u-boot.bin
u-boot binary image that can be programmed into mpc8315erdb board nor flash
rootfs/boot/u-boot-nand.binary--
u-boot binary image that can be programmed into mpc8315erdb board nand flash
rootfs/boot/mpc8315erdb.dtb
device tree binary(dtb)files for kernal boot up(support usb internal phy)
rootfs/boot/mpc8315erdb_uipi.dtb
device tree binary(dtb)files for kernal boot up (support usb external phy)
内核文件为 rootfs/boot/uImage,
根文件系统文件为 rootfs.ext2.gz.uboot
u-boot.bin u-boot
mpc8315erdb.dtb s
