[STM8] 请教为什么编译错误,谢谢!Error[Pe070]: incomplete type is not allowed
7766|4
zybyjj 发表于 2015-2-27 11:06 | 显示全部楼层 |阅读模式
#ifndef _FONT_GBK_CODE_H_
#define _FONT_GBK_CODE_H_
#include "iostm8s003f3.h"
typedef struct           // 汉字字模数据结构
  signed char Index[2];               // 汉字内码索引
  char Msk[32];                       // 点阵码数据
}typFNT_GB16;
// 汉字字模表                                                          //
// 汉字库: 宋体16.dot 纵向取模下高位,数据排列:从左到右从上到下         //
struct typFNT_GB16 GB_16[] =          // 数据表,新宋体
  "当",0x00,0x40,0x42,0x44,0x58,0x40,0x40,0x7F,0x40,0x40,0x50,0x48,0xC6,0x00,0x00,0x00,
       0x00,0x40,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0xFF,0x00,0x00,0x00,
  "前",0x08,0x08,0xE8,0x29,0x2E,0x28,0xE8,0x08,0x08,0xC8,0x0C,0x0B,0xE8,0x08,0x08,0x00,
       0x00,0x00,0xFF,0x09,0x49,0x89,0x7F,0x00,0x00,0x0F,0x40,0x80,0x7F,0x00,0x00,0x00,
  "设",0x40,0x40,0x42,0xCC,0x00,0x40,0xA0,0x9E,0x82,0x82,0x82,0x9E,0xA0,0x20,0x20,0x00,
       0x00,0x00,0x00,0x3F,0x90,0x88,0x40,0x43,0x2C,0x10,0x28,0x46,0x41,0x80,0x80,0x00,
  "定",0x10,0x0C,0x44,0x44,0x44,0x44,0x45,0xC6,0x44,0x44,0x44,0x44,0x44,0x14,0x0C,0x00,
       0x80,0x40,0x20,0x1E,0x20,0x40,0x40,0x7F,0x44,0x44,0x44,0x44,0x44,0x40,0x40,0x00,
  "微",0x10,0x88,0xC4,0x33,0x80,0x9E,0x90,0x9F,0x90,0x9E,0x20,0xD8,0x17,0xF0,0x10,0x00,
       0x01,0x00,0xFF,0x80,0x40,0x3E,0x02,0x02,0x3E,0x10,0x88,0x67,0x18,0x67,0x80,0x00,
  "粗",0x44,0x58,0xC0,0xFF,0x50,0x4C,0x00,0xFE,0x22,0x22,0x22,0x22,0xFE,0x00,0x00,0x00,
       0x08,0x06,0x01,0xFF,0x01,0x46,0x40,0x7F,0x42,0x42,0x42,0x42,0x7F,0x40,0x40,0x00,
  "调",0x40,0x42,0xCC,0x00,0x00,0xFE,0x82,0x92,0x92,0xFE,0x92,0x92,0x82,0xFE,0x00,0x00,
       0x00,0x00,0x3F,0x10,0x88,0x7F,0x00,0x1E,0x12,0x12,0x12,0x5E,0x80,0x7F,0x00,0x00,
  "模",0x10,0xD0,0xFF,0x50,0x90,0x04,0xF4,0x54,0x5F,0x54,0x54,0x5F,0xF4,0x04,0x00,0x00,
       0x03,0x00,0xFF,0x00,0x00,0x84,0x85,0x45,0x35,0x0F,0x15,0x25,0x65,0xC4,0x44,0x00,
  "式",0x00,0x08,0x88,0x88,0x88,0x88,0x88,0x08,0xFF,0x08,0x09,0x0E,0x0A,0x08,0x00,0x00,
       0x00,0x20,0x60,0x30,0x1F,0x10,0x08,0x08,0x00,0x07,0x18,0x20,0x40,0x80,0x70,0x00,
  ":",0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
       0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  "℃",0x00,0x00,0x78,0x48,0x78,0xC0,0xE0,0x10,0x08,0x08,0x08,0x08,0x10,0x38,0x00,0x00,
       0x00,0x00,0x00,0x00,0x00,0x03,0x0F,0x08,0x10,0x10,0x10,0x10,0x08,0x08,0x04,0x00,
#define GB_16_num sizeof(GB_16)/34        //汉字个数
#endif
mmuuss586 发表于 2015-2-27 12:08 | 显示全部楼层
这么多字符超出范围了吧;
搞IT的 发表于 2015-2-28 18:33 | 显示全部楼层
估计是超出范围了哦
yuqianao 发表于 2015-8-22 11:34 | 显示全部楼层
你这样写struct typFNT_GB16
       char Msk[32];
const struct typFNT_GB16   GB_16[] =
Harvard 发表于 2015-10-13 13:08 | 显示全部楼层
遇到同样 问题 求解中
