[Atmel] 跑一下SAM4N例程(六):时钟3重配时钟
645|0
ddllxxrr 发表于 2015-3-1 12:16 | 显示全部楼层 |阅读模式
在Atmle Studio6.2环境中插入开发板,则自动弹出开发板界面,这时可直接打开例程。
今天的例程是这样,让用户按键,每按下一个键输出的时钟都会改变,大概按四次左右,又恢复起始状态。
这里是判断按键按下和抬起的函数:
  1. static void wait_for_switches(void)
  3.         do {
  4.         } while (ioport_get_pin_level(GPIO_PUSH_BUTTON_1));
  5.         mdelay(1);
  6.         do {
  7.         } while (!ioport_get_pin_level(GPIO_PUSH_BUTTON_1));
  8.         mdelay(1);
  9. }
而所有的晶振的源宏定义,都在genclk.h中:
  1. enum genclk_source {
  2.         GENCLK_PCK_SRC_SLCK_RC       = 0, //!< Internal 32kHz RC oscillator as PCK source clock
  3.         GENCLK_PCK_SRC_SLCK_XTAL     = 1, //!< External 32kHz crystal oscillator as PCK source clock
  4.         GENCLK_PCK_SRC_SLCK_BYPASS   = 2, //!< External 32kHz bypass oscillator as PCK source clock
  5.         GENCLK_PCK_SRC_MAINCK_4M_RC  = 3, //!< Internal 4MHz RC oscillator as PCK source clock
  6.         GENCLK_PCK_SRC_MAINCK_8M_RC  = 4, //!< Internal 8MHz RC oscillator as PCK source clock
  7.         GENCLK_PCK_SRC_MAINCK_12M_RC = 5, //!< Internal 12MHz RC oscillator as PCK source clock
  8.         GENCLK_PCK_SRC_MAINCK_XTAL   = 6, //!< External crystal oscillator as PCK source clock
  9.         GENCLK_PCK_SRC_MAINCK_BYPASS = 7, //!< External bypass oscillator as PCK source clock
  10.         GENCLK_PCK_SRC_PLLACK        = 8, //!< Use PLLACK as PCK source clock
  11.         GENCLK_PCK_SRC_MCK           = 9, //!< Use Master Clk as PCK source clock
  12. };
而主函数的循环如下:
  1. //第一个输出时钟为PLL时钟
运行结果当我按下板子上的KEY0键时,PA6刚开始是系统时钟,然后减半,然后又是一个新时钟,接着又是外新时钟。然后回到开始。
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
