/*****************MSP130F149与1602LCD模块程序***********************/ /* */ /**************************Pins defination***************************/ /* RS P3.0 寄存器选择信号 H-数据寄存器 L-指令寄存器 */ /* RW P3.1 读写信号 H-读 L-写 */ /* E P3.2 片选信号 下降沿触发 */ /* DB0-DB7 P1.0-P1.7 数据线 数据传输 */ /**************************over*************************************/ #include "msp430x14x.h" #include "stdio.h" #define uchar unsigned char #define uint unsigned int uchar dis1[]=" Welcome to"; uchar dis2[]=" msp437"; void int_clk()//初始化时钟 { uchar i; BCSCTL1&=~XT2OFF; //打开XT2振荡器 BCSCTL2|=SELM1+SELS; //MCLK为8MHz,SMCLK为8MHz /********************************************* * 配置主时钟源的时钟源为XT2; SELMx Bits 7-6 Select MCLK. These bits select the MCLK source. 00 DCOCLK 01 DCOCLK 10 XT2CLK when XT2 oscillator present on-chip. LFXT1CLK when XT2 oscillator not present on-chip. 11 LFXT1CLK 配置子系统时钟的时钟源: SELS Bit 3 Select SMCLK. This bit selects the SMCLK source. 0 DCOCLK 1 XT2CLK when XT2 oscillator present on-chip. LFXT1CLK when XT2 oscillator not present on-chip. * **********************************************/ do { IFG1&=~OFIFG; //清除振荡错误标志 for(i=0;i<100;i++) _NOP(); //延时等待 } while((IFG1&OFIFG)!=0); //如果标志为1,则继续循环等待 IFG1&=~OFIFG; } void delay(int j)//延时程序函数延时为1ms { int i; while(j--) { for(i = 0; i< 2000; i++) { _NOP(); _NOP(); _NOP(); _NOP(); } } } /******************* 检查LCD忙状态 *********************/ /************* lcd_busy为1时,忙,等待 *****************/ /************* lcd-busy为0时,闲,可写指令与数据 *********/ int lcd_busy() //检测是否为忙?? { int busy; P1DIR=0x00;//p5作为输入 P3OUT &=~ BIT0 ; // RS = 0 P3OUT |= BIT1 ; // RW = 1 P3OUT |= BIT2 ; // EN = 1 _NOP(); busy =P1IN&0x80;//p4.7获取其中p4.7输入的值 _NOP(); P3OUT &=~ BIT2 ; // EN = 0 P3OUT &=~ BIT1 ; // RW = 0 P3OUT |= BIT0 ; // RS = 1 P1DIR=0XFF; return busy; } //写指令数据到LCD RS=L,RW=L,E=高脉冲,D0-D7=指令码。 void lcd_wcmd(uchar cmd) { while(lcd_busy()); P3OUT &=~ (BIT0 + BIT1) ; // RS = 0 RW = 0 写指令 P1OUT = cmd;//向P1写入数据 _NOP(); //等待 P3OUT |= BIT2 ; // E = 1 _NOP(); P3OUT &=~ BIT2 ;//E=0 } //写显示数据到LCD RS=H,RW=L,E=高脉冲,D0-D7=数据。 void lcd_wdat(uchar dat) { while(lcd_busy()); P3OUT |= BIT0 ; // RS = 1 P3OUT &=~ (BIT1 + BIT2) ; // RW = 0 E = 0 P1OUT = dat; _NOP(); P3OUT |= BIT2 ; // E = 1 _NOP(); P3OUT &=~ BIT2 ; // E = 0 } void lcd_pos(uchar pos)//设置显示初始位置 { lcd_wcmd(pos|0x80); //数据指针=80+地址变量 } void lcd_clr()//清除屏幕内容 { lcd_wcmd(0x01); //清除LCD的显示内容 delay(1); } void lcd_init()//初始化程序 { delay(10); //等待LCD电源稳定 lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据 delay(1); lcd_wcmd(0x38); delay(50); lcd_wcmd(0x38); delay(1); lcd_wcmd(0x0c); //显示开,关光标,关闭闪烁 delay(1); lcd_wcmd(0x06); //移动光标 往后移动一位 delay(1); lcd_wcmd(0x01); //清除LCD的显示内容 delay(1); } int main( void ) { // Stop watchdog timer to prevent time out reset WDTCTL = WDTPW + WDTHOLD;//关闭看门狗 int_clk();//初始化时钟 P3DIR |= BIT0 + BIT1 + BIT2 ;//将p3.0/1/2作为输出。 while(1) { int i; lcd_init(); lcd_pos(0x00); for(i=0;i<13;i++) {lcd_wdat(dis1[i]); delay(100); } lcd_pos(0x40); for(i=0;i<11;i++) {lcd_wdat(dis2[i]); delay(100); } delay(1000); } }
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
时间类勋章
55
176
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
