| 请到WWW.HJTAG.COM下载<br /><br />2007-01-30<br />Released new version H-JTAG V0.4.3 (Build 20070130)<br />1. Fixed a bug on the debug of ARM926EJ-S. Thank Xiangfeng and Sudarshana for pointing out this.<br />2. Fixed a bug in H-Flasher, which may cause overflow fatal error. Thank Hui for his help.<br />3. Corrected the flash ID of AT91SAM7S256.<br />4. Added the support to the programming of LPC2300. Thank ZLGMCU for providing the ev board.<br />5. Added the support to the programming of NOR flash from WINBOND.<br />6. Added the check for updates in H-JTAG. Now, user can use this to check for new version.<br /> |
