<br />下面是初始化程序,请大家帮我看看 为什么进不了中断??<br /><br />void InitUSART0(void)<br />{<br /><br /> AT91C_BASE_PIOA->PIO_PDR = DMX_RXD | DMX_TXD ; //Disables the PIO from controlling the corresponding pin (enables peripheral control of the pin).<br /> AT91C_BASE_PIOA->PIO_ASR = DMX_RXD | DMX_TXD; //Assigns the I/O line to the Peripheral A function.<br /> AT91C_BASE_PIOA->PIO_BSR = 0; //Assigns the I/O line to the Peripheral B function.<br /> <br /> //enable the clock of USART<br /> AT91C_BASE_PMC->PMC_PCER = 1<<AT91C_ID_US0;<br /> <br /> //Set the USART mode<br /> AT91C_BASE_US0->US_MR = AT91C_US_USMODE_NORMAL | //普通模式<br /> AT91C_US_CLKS_CLOCK & //时钟为MCK<br /> ~AT91C_US_SYNC | //异步模式<br /> AT91C_US_PAR_NONE | //无校验<br /> AT91C_US_NBSTOP_1_BIT | //一位停止位<br /> AT91C_US_MODE9 & //9位数据位<br /> ~AT91C_US_OVER //16 倍重采样。OVER=0<br /> ;<br /> <br /> //write the Timeguard Register<br /> AT91C_BASE_US0->US_TTGR = 0;<br /> <br /> //set baud rate divisor register<br /> AT91C_BASE_US0->US_BRGR = BAUD_CD; //((47923200)/(250000x16)) <br /> <br /> //Enable the RX and TX PDC transfer requests<br /> //AT91C_BASE_PDC_US0->PDC_PTCR = AT91C_PDC_TXTEN | AT91C_PDC_RXTEN;<br /><br /> //Enable usart<br /> AT91C_BASE_US0->US_CR = AT91C_US_RXEN | AT91C_US_TXEN; // 0x50;<br /> <br /> //使能接收结束中断&发送结束中断<br /> AT91C_BASE_US0->US_IMR = AT91C_US_ENDRX | AT91C_US_ENDTX ;<br /> <br /> //在AIC中设置US0中断优先级、中断入口、中断方式<br /> AT91F_AIC_ConfigureIt ( AT91C_BASE_AIC, <br /> AT91C_ID_US0, <br /> US0_INTERRUPT_LEVEL,<br /> AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL, <br /> US0_irq_handler<br /> );<br /> //在AIC中使能US0中断<br /> AT91F_AIC_EnableIt (AT91C_BASE_AIC, AT91C_ID_TC0); <br /> <br /><br />} |
