我在flash中就下了vivi,和kernel zImage然后<br />重启2410开发平台,结果如下,为何呢?<br />VIVI version 0.1.4 (root@localhost.localdomain) (gcc version 2.95.2 20000516 (release) <br />[Rebel.com]) #0.1.4 三 4月 25 10:49:26 PHT 2007<br />Evacuating 1MB of Flash to DRAM at 0x33F00000<br />MMU table base address = 0x33DFC000<br />Map flash virtual section to DRAM at 0x33F00000<br />Succeed memory mapping.<br />S3C2410 flash: probing 16-bit flash bus<br />S3C2410 amd flash: Probing for AMD compatible flash...<br />S3C2410 amd flash: Found 1 x 2MiB AMD AM29LV160DB at 0x0<br />Could not found stored vivi parameters. Use default vivi parameters.<br />Press Return to start the LINUX now, any other key for vivi<br />Copy linux kernel from 0x00030000 to 0x30008000, size = 0x000c0000 ... done<br />Warning: this binary is not compressed linux kernel image<br />zImage magic = 0xc76a0125<br />Setup linux parameters at 0x30000100<br />linux command line is: "noinitrd root=/dev/mtdblock/3 init=/linuxrc console=ttyS0"<br />MACH_TYPE = 193<br />NOW, Booting Linux...... <br />是否必须下载了文件系统候,才能看到镜像文件的解压,linux的运行呢? |
