怎么malloc经常会返回NULL?(keil lpc23xx)
4985|0
 楼主| shkliu 发表于 2007-2-11 17:38 | 显示全部楼层 |阅读模式
compiler:&nbsp;keil&nbsp;arm<br />cpu:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;lpc2378<br />在startup.s<br />;/*****************************************************************************<br />;*&nbsp;&nbsp;&nbsp;startup.s:&nbsp;startup&nbsp;file&nbsp;for&nbsp;NXP&nbsp;LPC230x&nbsp;Family&nbsp;Microprocessors<br />;*<br />;*&nbsp;&nbsp;&nbsp;Copyright(C)&nbsp;2006,&nbsp;NXP&nbsp;Semiconductor<br />;*&nbsp;&nbsp;&nbsp;All&nbsp;rights&nbsp;reserved.<br />;*<br />;*&nbsp;&nbsp;&nbsp;History<br />;*&nbsp;&nbsp;&nbsp;2006.09.01&nbsp;&nbsp;ver&nbsp;1.00&nbsp;&nbsp;&nbsp;&nbsp;Prelimnary&nbsp;version,&nbsp;first&nbsp;Release<br />;*<br />;*****************************************************************************/<br />&nbsp;&nbsp;&nbsp;&nbsp;PRESERVE8<br /><br />;/*<br />;&nbsp;*&nbsp;&nbsp;The&nbsp;STARTUP.S&nbsp;code&nbsp;is&nbsp;executed&nbsp;after&nbsp;CPU&nbsp;Reset.&nbsp;This&nbsp;file&nbsp;may&nbsp;be&nbsp;<br />;&nbsp;*&nbsp;&nbsp;translated&nbsp;with&nbsp;the&nbsp;following&nbsp;SET&nbsp;symbols.&nbsp;In&nbsp;uVision&nbsp;these&nbsp;SET&nbsp;<br />;&nbsp;*&nbsp;&nbsp;symbols&nbsp;are&nbsp;entered&nbsp;under&nbsp;Options&nbsp;-&nbsp;ASM&nbsp;-&nbsp;Define.<br />;&nbsp;*<br />;&nbsp;*&nbsp;&nbsp;REMAP:&nbsp;when&nbsp;set&nbsp;the&nbsp;startup&nbsp;code&nbsp;initializes&nbsp;the&nbsp;register&nbsp;MEMMAP&nbsp;<br />;&nbsp;*&nbsp;&nbsp;which&nbsp;overwrites&nbsp;the&nbsp;settings&nbsp;of&nbsp;the&nbsp;CPU&nbsp;configuration&nbsp;pins.&nbsp;The&nbsp;<br />;&nbsp;*&nbsp;&nbsp;startup&nbsp;and&nbsp;interrupt&nbsp;vectors&nbsp;are&nbsp;remapped&nbsp;from:<br />;&nbsp;*&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000000&nbsp;&nbsp;default&nbsp;setting&nbsp;(not&nbsp;remapped)<br />;&nbsp;*&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x40000000&nbsp;&nbsp;when&nbsp;RAM_MODE&nbsp;is&nbsp;used<br />;&nbsp;*<br />;&nbsp;*&nbsp;&nbsp;RAM_MODE:&nbsp;when&nbsp;set&nbsp;the&nbsp;device&nbsp;is&nbsp;configured&nbsp;for&nbsp;code&nbsp;execution<br />;&nbsp;*&nbsp;&nbsp;from&nbsp;on-chip&nbsp;RAM&nbsp;starting&nbsp;at&nbsp;address&nbsp;0x40000000.&nbsp;<br />;&nbsp;*/<br /><br /><br />;&nbsp;Standard&nbsp;definitions&nbsp;of&nbsp;Mode&nbsp;bits&nbsp;and&nbsp;Interrupt&nbsp;(I&nbsp;&&nbsp;F)&nbsp;flags&nbsp;in&nbsp;PSRs<br /><br />Mode_USR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x10<br />Mode_FIQ&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x11<br />Mode_IRQ&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x12<br />Mode_SVC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x13<br />Mode_ABT&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x17<br />Mode_UND&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x1B<br />Mode_SYS&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x1F<br /><br />I_Bit&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x80&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;when&nbsp;I&nbsp;bit&nbsp;is&nbsp;set,&nbsp;IRQ&nbsp;is&nbsp;disabled<br />F_Bit&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x40&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;when&nbsp;F&nbsp;bit&nbsp;is&nbsp;set,&nbsp;FIQ&nbsp;is&nbsp;disabled<br /><br /><br />;//&nbsp;&lth&gt&nbsp;Stack&nbsp;Configuration&nbsp;(Stack&nbsp;Sizes&nbsp;in&nbsp;Bytes)<br />;//&nbsp;&nbsp;&nbsp;&lto0&gt&nbsp;Undefined&nbsp;Mode&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&lt0x0-0xFFFFFFFF:8&gt<br />;//&nbsp;&nbsp;&nbsp;&lto1&gt&nbsp;Supervisor&nbsp;Mode&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&lt0x0-0xFFFFFFFF:8&gt<br />;//&nbsp;&nbsp;&nbsp;&lto2&gt&nbsp;Abort&nbsp;Mode&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&lt0x0-0xFFFFFFFF:8&gt<br />;//&nbsp;&nbsp;&nbsp;&lto3&gt&nbsp;Fast&nbsp;Interrupt&nbsp;Mode&nbsp;&lt0x0-0xFFFFFFFF:8&gt<br />;//&nbsp;&nbsp;&nbsp;&lto4&gt&nbsp;Interrupt&nbsp;Mode&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&lt0x0-0xFFFFFFFF:8&gt<br />;//&nbsp;&nbsp;&nbsp;&lto5&gt&nbsp;User/System&nbsp;Mode&nbsp;&nbsp;&nbsp;&nbsp;&lt0x0-0xFFFFFFFF:8&gt<br />;//&nbsp;&lt/h&gt<br /><br />UND_Stack_Size&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000004<br />SVC_Stack_Size&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000100<br />ABT_Stack_Size&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000004<br />FIQ_Stack_Size&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000004<br />IRQ_Stack_Size&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000100<br />USR_Stack_Size&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00001000;modify&nbsp;by&nbsp;sliu<br /><br />Stack_Size&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(UND_Stack_Size&nbsp;+&nbsp;SVC_Stack_Size&nbsp;+&nbsp;ABT_Stack_Size&nbsp;+&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FIQ_Stack_Size&nbsp;+&nbsp;IRQ_Stack_Size&nbsp;+&nbsp;USR_Stack_Size)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;AREA&nbsp;&nbsp;&nbsp;&nbsp;STACK,&nbsp;NOINIT,&nbsp;READWRITE,&nbsp;ALIGN=3<br />Stack_Mem&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SPACE&nbsp;&nbsp;&nbsp;Stack_Size<br /><br />Stack_Top&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Stack_Mem&nbsp;+&nbsp;Stack_Size<br /><br /><br />;//&nbsp;&lth&gt&nbsp;Heap&nbsp;Configuration<br />;//&nbsp;&nbsp;&nbsp;&lto&gt&nbsp;&nbsp;Heap&nbsp;Size&nbsp;(in&nbsp;Bytes)&nbsp;&lt0x0-0xFFFFFFFF&gt<br />;//&nbsp;&lt/h&gt<br /><br />Heap_Size&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00002240<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;AREA&nbsp;&nbsp;&nbsp;&nbsp;HEAP,&nbsp;NOINIT,&nbsp;READWRITE,&nbsp;ALIGN=3<br />Heap_Mem&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SPACE&nbsp;&nbsp;&nbsp;Heap_Size<br /><br />;&nbsp;Area&nbsp;Definition&nbsp;and&nbsp;Entry&nbsp;Point<br />;&nbsp;&nbsp;Startup&nbsp;Code&nbsp;must&nbsp;be&nbsp;linked&nbsp;first&nbsp;at&nbsp;Address&nbsp;at&nbsp;which&nbsp;it&nbsp;expects&nbsp;to&nbsp;run.<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;AREA&nbsp;&nbsp;&nbsp;&nbsp;RESET,&nbsp;CODE,&nbsp;READONLY<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ARM<br /><br />;&nbsp;Exception&nbsp;Vectors<br />;&nbsp;&nbsp;Mapped&nbsp;to&nbsp;Address&nbsp;0.<br />;&nbsp;&nbsp;Absolute&nbsp;addressing&nbsp;mode&nbsp;must&nbsp;be&nbsp;used.<br />;&nbsp;&nbsp;Dummy&nbsp;Handlers&nbsp;are&nbsp;implemented&nbsp;as&nbsp;infinite&nbsp;loops&nbsp;which&nbsp;can&nbsp;be&nbsp;modified.<br /><br />Vectors&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PC,&nbsp;Reset_Addr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PC,&nbsp;Undef_Addr<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PC,&nbsp;SWI_Addr<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PC,&nbsp;PAbt_Addr<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PC,&nbsp;DAbt_Addr<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;NOP&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;Reserved&nbsp;Vector&nbsp;<br />;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PC,&nbsp;IRQ_Addr<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PC,&nbsp;[PC,&nbsp;#-0x0120]&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;Vector&nbsp;from&nbsp;VicVectAddr<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PC,&nbsp;FIQ_Addr<br /><br />Reset_Addr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Reset_Handler<br />Undef_Addr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Undef_Handler<br />SWI_Addr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SWI_Handler<br />PAbt_Addr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PAbt_Handler<br />DAbt_Addr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DAbt_Handler<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;0xB9206E28&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;Reserved&nbsp;Address&nbsp;<br />IRQ_Addr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;IRQ_Handler<br />FIQ_Addr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FIQ_Handler<br /><br />Undef_Handler&nbsp;&nbsp;&nbsp;B&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Undef_Handler<br />SWI_Handler&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;B&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SWI_Handler<br />PAbt_Handler&nbsp;&nbsp;&nbsp;&nbsp;B&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;PAbt_Handler<br />DAbt_Handler&nbsp;&nbsp;&nbsp;&nbsp;B&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DAbt_Handler<br />IRQ_Handler&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;B&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;IRQ_Handler<br />FIQ_Handler&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;B&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FIQ_Handler<br /><br /><br />;&nbsp;Reset&nbsp;Handler<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;Reset_Handler<br />Reset_Handler&nbsp;&nbsp;&nbsp;<br /><br />;&nbsp;Setup&nbsp;Stack&nbsp;for&nbsp;each&nbsp;mode<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R0,&nbsp;=Stack_Top<br /><br />;&nbsp;&nbsp;Enter&nbsp;Undefined&nbsp;Instruction&nbsp;Mode&nbsp;and&nbsp;set&nbsp;its&nbsp;Stack&nbsp;Pointer<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MSR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CPSR_c,&nbsp;#Mode_UND:OR:I_Bit:OR:F_Bit<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOV&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SP,&nbsp;R0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SUB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R0,&nbsp;R0,&nbsp;#UND_Stack_Size<br /><br />;&nbsp;&nbsp;Enter&nbsp;Abort&nbsp;Mode&nbsp;and&nbsp;set&nbsp;its&nbsp;Stack&nbsp;Pointer<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MSR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CPSR_c,&nbsp;#Mode_ABT:OR:I_Bit:OR:F_Bit<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOV&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SP,&nbsp;R0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SUB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R0,&nbsp;R0,&nbsp;#ABT_Stack_Size<br /><br />;&nbsp;&nbsp;Enter&nbsp;FIQ&nbsp;Mode&nbsp;and&nbsp;set&nbsp;its&nbsp;Stack&nbsp;Pointer<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MSR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CPSR_c,&nbsp;#Mode_FIQ:OR:I_Bit:OR:F_Bit<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOV&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SP,&nbsp;R0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SUB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R0,&nbsp;R0,&nbsp;#FIQ_Stack_Size<br /><br />;&nbsp;&nbsp;Enter&nbsp;IRQ&nbsp;Mode&nbsp;and&nbsp;set&nbsp;its&nbsp;Stack&nbsp;Pointer<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MSR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CPSR_c,&nbsp;#Mode_IRQ:OR:I_Bit:OR:F_Bit<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOV&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SP,&nbsp;R0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SUB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R0,&nbsp;R0,&nbsp;#IRQ_Stack_Size<br /><br />;&nbsp;&nbsp;Enter&nbsp;Supervisor&nbsp;Mode&nbsp;and&nbsp;set&nbsp;its&nbsp;Stack&nbsp;Pointer<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MSR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CPSR_c,&nbsp;#Mode_SVC:OR:I_Bit:OR:F_Bit<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOV&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SP,&nbsp;R0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SUB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R0,&nbsp;R0,&nbsp;#SVC_Stack_Size<br /><br />;&nbsp;&nbsp;Enter&nbsp;User&nbsp;Mode&nbsp;and&nbsp;set&nbsp;its&nbsp;Stack&nbsp;Pointer<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MSR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CPSR_c,&nbsp;#Mode_USR<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MOV&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SP,&nbsp;R0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SUB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SL,&nbsp;SP,&nbsp;#USR_Stack_Size<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;BL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;__user_initial_stackheap<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;IMPORT&nbsp;&nbsp;&nbsp;&nbsp;TargetResetInit<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;TargetResetInit<br /><br />;&nbsp;Enter&nbsp;the&nbsp;C&nbsp;code<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;IMPORT&nbsp;&nbsp;__main<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R0,&nbsp;=__main<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BX&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R0<br /><br /><br />;&nbsp;User&nbsp;Initial&nbsp;Stack&nbsp;&&nbsp;Heap<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;AREA&nbsp;&nbsp;&nbsp;&nbsp;|.text|,&nbsp;CODE,&nbsp;READONLY<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;IMPORT&nbsp;&nbsp;__use_two_region_memory<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;__user_initial_stackheap<br />__user_initial_stackheap<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R0,&nbsp;=&nbsp;&nbsp;Heap_Mem<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R1,&nbsp;=(Stack_Mem&nbsp;+&nbsp;USR_Stack_Size)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R2,&nbsp;=&nbsp;(Heap_Mem&nbsp;+&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Heap_Size)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LDR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;R3,&nbsp;=&nbsp;Stack_Mem<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BX&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;LR<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;END<br />我已经给了heapsize.<br />谢谢!
