| 我遇到了两个符号:一个是[],一个|(竖线),前一个不知道,后一个不太清楚。请大家帮助,谢谢。<br /><br />如:<br /><br />        GBLL    THUMB<br />        GBLL    ARM<br />    [ {CONFIG} = 16<br />THUMB   SETL    {TRUE}<br />ARM     SETL    {FALSE}<br /><br />; If assembling with TASM go into 32 bit mode as the Armulator will<br />; start up the program in ARM state.<br /><br />        CODE32<br />    |<br />THUMB   SETL    {FALSE}<br />ARM     SETL    {TRUE}<br />    ]<br /><br /><br />还有一个是双竖线:<br /><br />   AREA |C$$data|, DATA, READWRITE<br /> |
