如题:
主程序如下
int main(void)
#ifdef DEBUG
debug();
#endif
/* System Clocks Configuration */
RCC_Configuration();
GPIO_Configuration();
NVIC_Configuration();
USART3_Configuration();
TIM_Configuration();
TIM1_Configuration();
GPIO_Deint();
TXD_EXTENSION_ADDRESS = READ_adderss();
GPIO_WriteBit(GPIOB, GPIO_Pin_5, Bit_RESET); //LED1 LIGHT
RX_485;
while(1)
//Send_DATA_RS485();
中断程序如下
void USART3_IRQHandler(void)
if(USART_GetITStatus(USART3, USART_IT_RXNE) == SET)
USART_ClearITPendingBit(USART3,USART_IT_RXNE);
GPIO_WriteBit(GPIOD, GPIO_Pin_2, Bit_RESET); //LED1 LIGHT
RXDBUFFER[RxBufferSize_connter] = USART_ReceiveData(USART3);
RxBufferSize_connter = RxBufferSize_connter + 1;
if(RxBufferSize_connter == 26)
RxBufferSize_connter = 0;
if((RXDBUFFER[5] == 0XFF) && (RXDBUFFER[6] == 0X55) && (RXDBUFFER[7] == 0X5A)
&& (RXDBUFFER[8] == 0XA5) && (RXDBUFFER[9] == 0XAA) && (RXDBUFFER[11] == 0X90))
RXD_FLAG = 1;
GPIO_WriteBit(GPIOD, GPIO_Pin_2, Bit_SET); //LED1 LIGHT
usart3配置如下
USART_InitTypeDef USART_InitStructure;
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
/* Configure the USARTx */
USART_Init(USART3, &USART_InitStructure);
/* Enable the USART Receive interrupt: this interrupt is generated when the USARTx receive data register is not empty */
USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
/* Enable USARTx */
USART_Cmd(USART3, ENABLE);
nvic 如下
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/* Configure the NVIC Preemption Priority Bits */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//USART3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_InitStructure.NVIC_IRQChannel = TIM1_UP_IRQChannel;//TIM1_IRQn;
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;//TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQChannel;//TIM3_IRQn;
NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQChannel;//TIM4_IRQn;
NVIC_Init(&NVIC_InitStructure);
rcc 如下
ErrorStatus HSEStartUpStatus;
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* PLLCLK = 8MHz * 9 = 72 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
/*Enble GPIOA、GPIOB、GPIOC、GPIOD*/
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB
| RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD
| RCC_APB2Periph_TIM1,
ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 | RCC_APB1Periph_TIM3
| RCC_APB1Periph_TIM4 | RCC_APB1Periph_USART3,
ENABLE);
gpio配置如下
/*Configure PB10 as output for USART3_TXD; RS485_TXD*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/*Configure PB11 as input for USART3_RXD; RS485_RXD*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/*Configure PB12 as output for USART3_DIR; RS485_DIR*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
请高手指点!! |
