关于MSP430与AT24C02的问题
2276|15
 楼主| asffsd 发表于 2015-4-6 22:08 | 显示全部楼层 |阅读模式
调了几天的存储芯片24C02,感觉程序上没有什么问题啊。可是程序总是卡在ACK()中的while里。不知道什么原因。望有经验的大神帮忙解决下。不胜感激。
#include "msp430x26x.h"
#define uchar unsigned char
#define uint  unsigned int
#define TRUE  1
#define FALSE 0
#define CPU_F ((double)16000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define SDA_H P4OUT |=BIT5
#define SDA_L P4OUT &=~BIT5
#define SCL_H P4OUT |=BIT6
#define SCL_L P4OUT &=~BIT6
#define SDA_TRUE  P4IN&BIT5
#define SDA_IN  P4DIR &=~BIT5
#define SDA_OUT P4DIR |=BIT5
void AT24C02_Init()          //初始化,需将时钟线和数据线拉高
  P4DIR |=BIT5+BIT6;            //AT24C02 SDA SCL
  SDA_H;
  SCL_H;
void AT24C02_START()        //起始条件,SCL高电平时候,SDA的一个下降沿
  SDA_OUT;
  SDA_H;
  delay_us(10);
  SCL_H;
  delay_us(10);
  SDA_L;
  delay_us(10);
  SCL_L;
void AT24C02_STOP()       //停止条件,SCL高电平时候,SDA的一个上升沿
  SDA_OUT;
  SDA_L;
  delay_us(7);
  SCL_H;
  delay_us(7);
  SDA_H;
  delay_us(7);
void ACK()
  //unsigned char i=0;
  SDA_H;
  delay_us(10);
  SCL_H;
  delay_us(10);
  SDA_IN;
  //while(SDA_TRUE&&(i<255)) i++;
  while(SDA_TRUE);
  SCL_L;
  delay_us(10);
  SDA_OUT;
void AT24C02_send_char(unsigned char data)  //IIC协议要求从高位开始传送,传送1字节
  unsigned char i=0;
  SDA_OUT;
  SCL_L;                                    //此时,SCL被拉低,才允许SDA变化
  SDA_H;
  delay_us(5);
  for(i=0;i<8;i++)
    if(data&(0x80>>i))
      SDA_H;
    else
      SDA_L;
    SCL_H;                        //拉高SCL,不允许SDA变化
    delay_us(10);
    SCL_L;
    delay_us(10);                 //拉低SCL,开始下1bit传送
  SDA_H;                         //释放数据线
  delay_us(5);
unsigned char AT24C02_receive_char()
    //SCL低电平 SDA高电平
  unsigned char temp=0,i=0;
  SCL_L;
  SDA_H;
  SDA_IN;
  for(i=0;i<8;i++)
    SCL_H;
    delay_ms(3);
    if(SDA_TRUE)
      temp=temp|(0x80>>i);
    SCL_L;
    delay_ms(2);
  SDA_OUT;
  return temp;
void AT24C02_write_byte(unsigned char address,unsigned char data)
  AT24C02_START();
  AT24C02_send_char(0xa0);
  ACK();
  AT24C02_send_char(address);
  ACK();
  AT24C02_send_char(data);
  ACK();
  AT24C02_STOP();
unsigned char AT24C02_read_byte(unsigned char address)
  unsigned val=0;
  AT24C02_START();
  ACK();
  ACK();
  AT24C02_START();
  AT24C02_send_char(0xa1);
  ACK();
  val=AT24C02_receive_char();
  AT24C02_STOP();
  return val;
void main()
  unsigned char r=0;
  WDTCTL =WDTPW+WDTHOLD;                                 //停止开门狗
  CLK_Init();
  AT24C02_Init();
  AT24C02_write_byte(0x10,0x12);
  Delay_ms(5);
  r=AT24C02_read_byte(0x10);
  while(1);
 楼主| asffsd 发表于 2015-4-6 22:09 | 显示全部楼层
坐等啊
dirtwillfly 发表于 2015-4-6 23:15 | 显示全部楼层
这个东西,就得用逻辑分析仪或者示波器,看着时序慢慢调
ccw1986 发表于 2015-4-8 22:28 | 显示全部楼层
楼主,还是先看看时序对不对吧
yirongfu 发表于 2015-4-9 00:21 | 显示全部楼层
哪款24C02?先确认是5V的还是3.3V的24C02,印象中AT24C02是5V的。5V的不好说的,你懂的。
然后,如果是3.3V的EEPROM,因为你代码里头没有使能IO的内部上拉,那么外部上拉电阻接了吗?
shenmu2012 发表于 2015-4-9 20:09 | 显示全部楼层
这个先看下你的硬件上设计有设么没考虑到的吧。
这个很明显是死在whlie语句那了,跟硬件相关的。
yy_yanyu 发表于 2015-4-12 20:09 | 显示全部楼层
楼主调试好了没有?我最近调试这个程序也没成功,就继续向下进行了,加下QQ328550903   希望与楼主多交流,谢谢。
quray1985 发表于 2015-4-13 21:56 | 显示全部楼层
初始化未成功,先看看时序对不对
 楼主| asffsd 发表于 2015-4-15 10:38 | 显示全部楼层
我的硬件上有10k的上拉电阻,是没问题的。时序我也看了,好像也没什么问题
 楼主| asffsd 发表于 2015-4-15 10:39 | 显示全部楼层
然后,如果是3.3V ...
ATMEL AT24C02芯片。有上拉电阻10K
 楼主| asffsd 发表于 2015-4-15 10:41 | 显示全部楼层
这个确实死在while里了。很奇怪的是,发送0xA0后的ACK能收到。再然后发送器件写地址后ACK就收不到了,死在里面了
 楼主| asffsd 发表于 2015-4-15 16:47 | 显示全部楼层
初始化未成功,先看看时序对不对
阁下,能把24C02的程序,发给我参考一下吗?不胜感激。
quray1985 发表于 2015-4-15 21:41 | 显示全部楼层
不好意思啊,现在手头上没有,是以前用nxp单片机的时候用过
 楼主| asffsd 发表于 2015-4-15 22:51 | 显示全部楼层
恩,谢谢你啊,我现在搞出来了,虽然还有点迷糊。
 楼主| asffsd 发表于 2015-4-15 22:52 | 显示全部楼层
我把上拉电阻去掉了,然互启用内置上拉电阻,就可以了。
