| clear all; close all; clc;
 % filter specification:
 % sampling-rate conversion factor M=5.
 % passband edge at OMEGA_p = 0.09pi. stopband edge at OMEGA_s=pi/5.
 % passband and stopbands ripples are given in decibels with ap=0.1dB,
 % as=60dB.
 % step 1: determining the input parameters for FIR filter desgin
 ap = 0.1; as=60; Fp=0.09*pi/pi; Fs=pi/5/pi; % filter specifications
 dev=[(10^(ap/20)-1)/(10^(ap/20)+1), 10^(-as/20)]; % passband and stopband ripples
 F = [Fp,Fs]; % cutoff frequencies
 A = [1,0]; % desired amplitudes
 [Nord, Fo, Ao, W] = firpmord(F,A,dev); % estimating the filter order
 % increase Nord to match stopband ripple requirement
 Nord = Nord+4;
 h = firpm(Nord, Fo, Ao, W); % filter coefficients
 plot(h);
 figure(1);
 freqz(h,1,1024) % computes and plots the frequency response
 axis([0 1 -80.5 1]);
 figure(2);
 subplot(2,1,1); impz(h,1) % plots the impulse response
 subplot(2,1,2); zplane(h,1) % plots pole/zero
 fs = 48e3;  % sample rate
 f1 = 1e3;   % signal1: 1kHz
 f2 = 16e3;  % signal2: 16kHz
 N = 8192;   % signal length
 f = (0:N/2-1)/N*fs;
 x = 0.5*sin(2*pi*(0:N-1)*f1/fs)+0.5*sin(2*pi*(0:N-1)*f2/fs); % input signal
 y = filter(h,1,x);  % direct filtering using matlab function
 block_size = 128;   % split input signal into consequent 128-points block
 filter_size = length(h);    % fir filter tap
 N_b = N/block_size; % how many blocks of total input signal
 x_f = zeros(1,block_size+filter_size-1);    % block_size + history_size
 y_f = zeros(1,N_b*block_size);  % signal filterred
 for n=1:N_b     % for each 128-points block
 x_f(filter_size:end) = x((n-1)*block_size+1:n*block_size); % get a new block
 for i=1:block_size  % for each point in block
 sum = 0;
 for k=1:filter_size
 sum = sum+x_f(k+i-1)*h(k);  % h(k) is symmetrical,
 % if h(k) is not symmetrical, need to invert h
 end
 y_f((n-1)*block_size+i) = sum;  % output sample filterred
 end
 for i=1:filter_size-1
 x_f(i) = x_f(i+block_size); % update history for each block
 end
 end
 error = y-y_f;  % error of different filtering procedure
 figure(3);
 plot(error);    % error is close to zeros
 从第28行开始看。
