| 是啊,请大家帮帮看看,哪里有问题,谢谢。
 //打开USB端口
 int CUSBPrintDLL::Open()
 int i = 0;
 int iDeviceNum = 0;
 //获取设备数目
 iDeviceNum = m_pUSBDevice->DeviceCount();
 // make sure there is at lesat one device out there
 if (iDeviceNum == 0)
 return 1;
 // search for all connected devices
 for ( i = 0; i < iDeviceNum; i++)
 //Only Get the Bulkloop back compatinle device
 m_pUSBDevice->Open(i);
 //Get config descriptor
 USB_CONFIGURATION_DESCRIPTOR ConfDesc;
 m_pUSBDevice->GetConfigDescriptor(&ConfDesc);
 // Number of interface one
 if(ConfDesc.bNumInterfaces == 1)
 //Get Interface descriptor
 USB_INTERFACE_DESCRIPTOR IntfDesc;
 m_pUSBDevice->GetIntfcDescriptor(&IntfDesc);
 if(IntfDesc.bAlternateSetting == 0)
 // Number of endpoint is 2
 if(IntfDesc.bNumEndpoints == 2)
 m_DeviceIndex = i;
 break;
 }//if number
 }//for
 //无符合要求的设备
 if (i == iDeviceNum)
 return 1;
 m_pUSBDevice->Open(m_DeviceIndex);
 //获取所有端点
 int epts = m_pUSBDevice->EndPointCount();
 CCyUSBEndPoint *endpt;
 for (i=1; i<epts; i++)
 endpt = m_pUSBDevice->EndPoints[i];
 if (endpt->Attributes == 2)    // Bulk
 if (endpt->Address & 0x80)
 m_pInEndPt =  m_pUSBDevice->EndPoints[i];
 else
 m_pOutEndPt = m_pUSBDevice->EndPoints[i];
 //设置读、写超时时间
 m_pOutEndPt->TimeOut = 0;
 m_pInEndPt->TimeOut = 0;
 m_pOutEndPt->TimeOut = 2000;
 m_pInEndPt->TimeOut = 2000;
 //设置可用标记
 m_bEnable = true;
 return 0;
 //往USB端口发送数据
 LONG CUSBPrintDLL::Write( const char *buffer,LONG length )
 if (!m_bEnable || !m_pUSBDevice->Open(m_DeviceIndex))
 return 0;
 LONG lBufLen = length;
 if(!m_pOutEndPt->XferData((PUCHAR)buffer,lBufLen))
 m_pUSBDevice->Reset();
 return 0;
 return lBufLen;
 //从USB端口读取数据
 LONG CUSBPrintDLL::Read( char *buffer,LONG length )
 //未进行初始化
 if(!m_bEnable || !m_pUSBDevice->Open(m_DeviceIndex))
 return 0;
 if (!m_pInEndPt->XferData((PUCHAR)buffer,length))
 return 0;
 return length;
