UHF 865 MHz. Gen 2 Philips UCODE Harsh Environment RFID Tag
3241|2
 楼主| gaofrid 发表于 2008-8-1 10:49 | 显示全部楼层 |阅读模式
UHF&nbsp;865&nbsp;MHz.&nbsp;Gen&nbsp;2&nbsp;Philips&nbsp;UCODE&nbsp;Harsh&nbsp;Environment&nbsp;RFID&nbsp;Tag<br />Model:&nbsp;115005<br />&nbsp;<br />Type:&nbsp;&nbsp;&nbsp;&nbsp;Contactless&nbsp;Read/Write<br />Operating&nbsp;Frequency:&nbsp;&nbsp;&nbsp;&nbsp;EU&nbsp;(865&nbsp;~&nbsp;868&nbsp;MHz.)&nbsp;(UHF-Ultra&nbsp;High&nbsp;Frequency)<br />Capacity:&nbsp;&nbsp;&nbsp;&nbsp;96&nbsp;bit&nbsp;EPC&nbsp;ID<br />Data&nbsp;Coding&nbsp;Type:&nbsp;&nbsp;&nbsp;&nbsp;EPC&nbsp;Class&nbsp;1&nbsp;GEN2&nbsp;<br />Common&nbsp;Usage:&nbsp;&nbsp;&nbsp;&nbsp;High&nbsp;performance&nbsp;reading&nbsp;encapsulated&nbsp;tag&nbsp;designed&nbsp;for&nbsp;direct&nbsp;mounting&nbsp;on&nbsp;metallic&nbsp;objects&nbsp;<br />Standard&nbsp;Deployment:&nbsp;&nbsp;&nbsp;&nbsp;Rough&nbsp;and&nbsp;harsh&nbsp;service&nbsp;environments&nbsp;resistant&nbsp;to&nbsp;liquids&nbsp;and&nbsp;metals.<br />Tested&nbsp;Read&nbsp;Range:&nbsp;&nbsp;&nbsp;&nbsp;Maximum&nbsp;5.7&nbsp;M&nbsp;write&nbsp;8.2&nbsp;M&nbsp;read&nbsp;<br />Multi-Detection:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Yes<br />Max.&nbsp;read&nbsp;quantity:&nbsp;&nbsp;&nbsp;&nbsp;150&nbsp;tags/sec<br />Tag&nbsp;Size:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;150&nbsp;mm&nbsp;X&nbsp;25&nbsp;mm&nbsp;X&nbsp;4&nbsp;mm&nbsp;(5.905&nbsp;in&nbsp;X&nbsp;0.984&nbsp;in&nbsp;x&nbsp;.157&nbsp;in)&nbsp;<br />Substrate&nbsp;Material:&nbsp;&nbsp;&nbsp;&nbsp;ABS&nbsp;with&nbsp;3M&nbsp;adhesive&nbsp;strip<br />Color:&nbsp;&nbsp;&nbsp;&nbsp;Grey<br />Weight:&nbsp;&nbsp;&nbsp;&nbsp;16&nbsp;g<br />Compliance:&nbsp;&nbsp;&nbsp;&nbsp;Philips&nbsp;UCODE&nbsp;EPC&nbsp;1.19&nbsp;Inlay<br />Regulatory&nbsp;Specifications:&nbsp;&nbsp;&nbsp;&nbsp;ISO&nbsp;18000-6C<br />Operating&nbsp;Specifications:&nbsp;&nbsp;&nbsp;&nbsp;Waterproof&nbsp;and&nbsp;dustproof&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;Resistance&nbsp;to&nbsp;immersion&nbsp;in&nbsp;salt&nbsp;water,&nbsp;alcohol,&nbsp;oil,&nbsp;10%&nbsp;HCL,&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;Vibration&nbsp;–&nbsp;Dependant&nbsp;on&nbsp;packaging<br />&nbsp;&nbsp;&nbsp;&nbsp;Temperature&nbsp;–&nbsp;Storage&nbsp;–40°C&nbsp;to&nbsp;+85°C<br />&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;Operating&nbsp;-25°C&nbsp;to&nbsp;+&nbsp;70°C<br />&nbsp;&nbsp;&nbsp;&nbsp;Humidity&nbsp;–&nbsp;40&nbsp;~&nbsp;80&nbsp;%&nbsp;Relative<br /><br /><br />For&nbsp;further&nbsp;information&nbsp;on&nbsp;this&nbsp;product,&nbsp;or&nbsp;for&nbsp;assistance&nbsp;in&nbsp;finding&nbsp;a&nbsp;different&nbsp;RFID&nbsp;product&nbsp;to&nbsp;meet&nbsp;your&nbsp;specification,&nbsp;please&nbsp;Contact&nbsp;Us.<br /><br /><br />About&nbsp;GAO&nbsp;RFID&nbsp;Inc.<br />GAO&nbsp;RFID&nbsp;Inc.&nbsp;is&nbsp;a&nbsp;leading&nbsp;provider&nbsp;of&nbsp;Radio&nbsp;Frequency&nbsp;Identification&nbsp;(RFID)&nbsp;hardware&nbsp;and&nbsp;solutions&nbsp;to&nbsp;end&nbsp;users&nbsp;worldwide.&nbsp;GAO&nbsp;RFID&nbsp;combines&nbsp;best&nbsp;of&nbsp;breed&nbsp;with&nbsp;low&nbsp;cost&nbsp;RFID&nbsp;readers,&nbsp;RFID&nbsp;tags&nbsp;and&nbsp;enabling-RFID&nbsp;software.&nbsp;We&nbsp;have&nbsp;a&nbsp;wide&nbsp;variety&nbsp;of&nbsp;RFID&nbsp;readers,&nbsp;tags&nbsp;and&nbsp;antennas&nbsp;in&nbsp;all&nbsp;the&nbsp;RFID&nbsp;technologies,&nbsp;Low&nbsp;Frequency&nbsp;(LF),&nbsp;High&nbsp;Frequency&nbsp;(HF),&nbsp;Ultra&nbsp;High&nbsp;Frequency&nbsp;(UHF,&nbsp;Gen&nbsp;2)&nbsp;as&nbsp;well&nbsp;as&nbsp;Active&nbsp;and&nbsp;Semi-Passive.&nbsp;&nbsp;GAO&nbsp;RFID’s&nbsp;products&nbsp;and&nbsp;services&nbsp;are&nbsp;easily&nbsp;customized&nbsp;for&nbsp;use&nbsp;in&nbsp;Asset&nbsp;Tracking,&nbsp;&nbsp;Health&nbsp;care,&nbsp;Supply&nbsp;Chain&nbsp;&&nbsp;Logistics,&nbsp;Event&nbsp;Management,&nbsp;Access&nbsp;Control,&nbsp;Livestock&nbsp;Tracking,&nbsp;Inventory&nbsp;Control&nbsp;&&nbsp;Management,&nbsp;Field&nbsp;Service,&nbsp;Maintenance&nbsp;and&nbsp;Document&nbsp;Authentication.<br />For&nbsp;more&nbsp;information&nbsp;please&nbsp;visit&nbsp;http://www.GAORFID.com&nbsp;<br />
db10 发表于 2008-8-1 17:28 | 显示全部楼层
有读写器吗?
mr.king 发表于 2008-8-1 19:03 | 显示全部楼层
回二楼,有的,没有造出的标签就没用
