[Atmel] ATWINC1500-XSTK介绍
1545|0
 楼主| ddllxxrr 发表于 2015-6-6 19:54 | 显示全部楼层 |阅读模式
win, ST, TE, os, IO
The Atmel® ATWINC1500-XSTK Xplained Pro starter kit is a hardware platform for evaluating the Atmel ATWINC1500 low cost, low power 802.11 b/g/n WiFi network controller module. Supported by the Atmel Studio integrated development platform, the kit provides easy access to the features of the ATWINC1500 and explains how to integrate the device in a custom design. The Xplained Pro series of evaluation kits include an on-board Embedded Debugger, and no external tools are necessary to program or debug the SAMD21 host MCU that drives the ATWINC1500. The Xplained Pro extension kits offer additional peripherals to extend the features of the board and ease the development of custom designs.
What is in the box: SAMD21 Xplained Pro, WINC1500 Xplained Pro Extension board, I/O1 Xplained Pro Extension board, Two USB Type A to Micro B Cables (1.5m)
Key Features
  • Atmel ATWINC1500 module mounted on ATWINC1500 Xplained Pro Extension
  • ATSAMD21-XPRO host MCU board for driving the ATWINC1500 Xplained Pro Extension
  • Atmel I/O1 Xplained Pro for sensor and SD-card input to host MCU
  • Embedded debugger (EDBG) for programming SAMD21 host MCU
  • Virtual COM-port interface to host MCU via UART
  • Wired firmware updates for ATWINC1500 module via virtual COM-port interface
  • Atmel Data Gateway Interface (DGI) to host MCU via SPI and TWI
  • ATECC108 CryptoAuthentication device connected to host MCU
  • Two extension headers
  • Three possible power sources
  • External power
  • Target USB
  • 32KHz crystal
  • 16MHz crystal
  • Supported with application examples trough Atmel gallery
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
