- /*************************´Ë²¿·ÖΪ18B20µÄÇý¶¯³ÌÐò*************************************/
- #include <reg52.H>
- #include <intrins.h>
- #define NOP() _nop_() /* ¶¨Òå¿ÕÖ¸Áî */
- #define _Nop() _nop_() /*¶¨Òå¿ÕÖ¸Áî*/
- //else IO
- sbit LS138A=P2^2; //¹Ü½Å¶¨Òå
- sbit LS138B=P2^3;
- sbit LS138C=P2^4;
- sbit D1 =P1^5;
- sbit D18B20=P3^7;
- //´Ë±íΪ LED µÄ×ÖÄ£, ¹²ÒõÊýÂë¹Ü 0-9 -
- unsigned char code Disp_Tab[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40};
- unsigned long LedOut[4],LedNumVal;
- void TempDelay (unsigned char us);
- void Init18b20 (void);
- void WriteByte (unsigned char wr); //µ¥×Ö½ÚдÈë
- void read_bytes (unsigned char j);
- unsigned char CRC (unsigned char j);
- void GemTemp (void);
- void Config18b20 (void);
- void ReadID (void);
- void TemperatuerResult(void);
- void GetTemp(void); //ÉùÃ÷ÒýÓÃÍⲿº¯Êý
- unsigned int Temperature; // ÉùÃ÷ÒýÓÃÍⲿ±äÁ¿
- void delay(unsigned int i);
- bit flag;
- unsigned char temp_buff[9]; //´æ´¢¶ÁÈ¡µÄ×Ö½Ú£¬read scratchpadΪ9×Ö½Ú£¬read rom IDΪ8×Ö½Ú
- unsigned char id_buff[8];
- unsigned char *p,TIM;
- unsigned char crc_data;
- unsigned char code CrcTable [256]={
- 0, 94, 188, 226, 97, 63, 221, 131, 194, 156, 126, 32, 163, 253, 31, 65,
- 157, 195, 33, 127, 252, 162, 64, 30, 95, 1, 227, 189, 62, 96, 130, 220,
- 35, 125, 159, 193, 66, 28, 254, 160, 225, 191, 93, 3, 128, 222, 60, 98,
- 190, 224, 2, 92, 223, 129, 99, 61, 124, 34, 192, 158, 29, 67, 161, 255,
- 70, 24, 250, 164, 39, 121, 155, 197, 132, 218, 56, 102, 229, 187, 89, 7,
- 219, 133, 103, 57, 186, 228, 6, 88, 25, 71, 165, 251, 120, 38, 196, 154,
- 101, 59, 217, 135, 4, 90, 184, 230, 167, 249, 27, 69, 198, 152, 122, 36,
- 248, 166, 68, 26, 153, 199, 37, 123, 58, 100, 134, 216, 91, 5, 231, 185,
- 140, 210, 48, 110, 237, 179, 81, 15, 78, 16, 242, 172, 47, 113, 147, 205,
- 17, 79, 173, 243, 112, 46, 204, 146, 211, 141, 111, 49, 178, 236, 14, 80,
- 175, 241, 19, 77, 206, 144, 114, 44, 109, 51, 209, 143, 12, 82, 176, 238,
- 50, 108, 142, 208, 83, 13, 239, 177, 240, 174, 76, 18, 145, 207, 45, 115,
- 202, 148, 118, 40, 171, 245, 23, 73, 8, 86, 180, 234, 105, 55, 213, 139,
- 87, 9, 235, 181, 54, 104, 138, 212, 149, 203, 41, 119, 244, 170, 72, 22,
- 233, 183, 85, 11, 136, 214, 52, 106, 43, 117, 151, 201, 74, 20, 246, 168,
- 116, 42, 200, 150, 21, 75, 169, 247, 182, 232, 10, 84, 215, 137, 107, 53};
- *Function:ÑÓʱ´¦Àí
- *parameter:
- *Return:
- *Modify:
- while(us--);
- *Function:18B20³õʼ»¯
- *parameter:
- *Return:
- *Modify:
- D18B20=1;
- _nop_();
- D18B20=0;
- TempDelay(80); //delay 530 uS//80
- _nop_();
- D18B20=1;
- TempDelay(14); //delay 100 uS//14
- _nop_();
- _nop_();
- _nop_();
- if(D18B20==0)
- flag = 1; //detect 1820 success!
- else
- flag = 0; //detect 1820 fail!
- TempDelay(20); //20
- _nop_();
- _nop_();
- D18B20 = 1;
- *Function:Ïò18B20дÈëÒ»¸ö×Ö½Ú
- *parameter:
- *Return:
- *Modify:
- void WriteByte (unsigned char wr) //µ¥×Ö½ÚдÈë
- unsigned char i;
- for (i=0;i<8;i++)
- D18B20 = 0;
- _nop_();
- D18B20=wr&0x01;
- TempDelay(3); //delay 45 uS //5
- _nop_();
- _nop_();
- D18B20=1;
- wr >>= 1;
- *Function:¶Á18B20µÄÒ»¸ö×Ö½Ú
- *parameter:
- *Return:
- *Modify:
- unsigned char ReadByte (void) //¶ÁÈ¡µ¥×Ö½Ú
- unsigned char i,u=0;
- for(i=0;i<8;i++)
- D18B20 = 0;
- u >>= 1;
- D18B20 = 1;
- if(D18B20==1)
- u |= 0x80;
- TempDelay (2);
- _nop_();
- return(u);
- *Function:¶Á18B20
- *parameter:
- *Return:
- *Modify:
- unsigned char i;
- for(i=0;i<j;i++)
- *p = ReadByte();
- p++;
- *Function:CRCУÑé
- *parameter:
- *Return:
- *Modify:
- unsigned char i,crc_data=0;
- for(i=0;i<j;i++) //²é±íУÑé
- crc_data = CrcTable[crc_data^temp_buff[i]];
- return (crc_data);
- *Function:¶ÁȡζÈ
- *parameter:
- *Return:
- *Modify:
- read_bytes (9);
- if (CRC(9)==0) //УÑéÕýÈ·
- Temperature = temp_buff[1]*0x100 + temp_buff[0];
- // Temperature *= 0.625;
- Temperature /= 16;
- TempDelay(1);
- *Function:ÄÚ²¿ÅäÖÃ
- *parameter:
- *Return:
- *Modify:
- void Config18b20 (void) //ÖØÐÂÅäÖñ¨¾¯ÏÞ¶¨ÖµºÍ·Ö±æÂÊ
- Init18b20();
- WriteByte(0xcc); //skip rom
- WriteByte(0x4e); //write scratchpad
- WriteByte(0x19); //ÉÏÏÞ
- WriteByte(0x1a); //ÏÂÏÞ
- WriteByte(0x7f); //set 12 bit (0.125)
- Init18b20();
- WriteByte(0x48); //±£´æÉ趨ֵ
- Init18b20();
- WriteByte(0xb8); //»Øµ÷É趨ֵ
- *Function:¶Á18B20ID
- *parameter:
- *Return:
- *Modify:
- void ReadID (void)//¶ÁÈ¡Æ÷¼þ id
- Init18b20();
- WriteByte(0x33); //read rom
- read_bytes(8);
- *Function:18B20IDÈ«´¦Àí
- *parameter:
- *Return:
- *Modify:
- p = id_buff;
- ReadID();
- Config18b20();
- Init18b20 ();
- WriteByte(0x44); //Temperature convert
- Init18b20 ();
- WriteByte(0xbe); //read Temperature
- p = temp_buff;
- GemTemp();
- void GetTemp()
- if(TIM==100) //ÿ¸ô 1000ms ¶ÁȡζÈ
- { TIM=0;
- TemperatuerResult();
- [ t1 (10ms)ÖжÏ] ÖжÏ
- void T1zd(void) interrupt 3
- TH1 = 0xD8; //10
- TL1 = 0xF0;
- TIM++;
- void system_Ini()
- TMOD|= 0x11;
- TH1 = 0xD8; //10
- TL1 = 0xF0;
- IE = 0x8A;
- TR1 = 1;
- //ÑÓʱ³ÌÐò
- char j;
- for(i; i > 0; i--)
- for(j = 200; j > 0; j--);
- main()
- unsigned char i;
- system_Ini();
- while(1)
- GetTemp();
- LedNumVal=Temperature; //°Ñʵ¼ÊζÈË͵½LedNumVal±äÁ¿ÖÐ
- LedOut[0]=Disp_Tab[LedNumVal%10000/1000];
- LedOut[1]=Disp_Tab[LedNumVal%1000/100];
- LedOut[2]=Disp_Tab[LedNumVal%100/10]; //ʮλ
- LedOut[3]=Disp_Tab[LedNumVal%10]; //¸öλ
- for(i=0; i<4; i++)
- P0 = LedOut[i] ;
- switch(i)
- { //138ÒëÂë
- case 0:LS138A=0; LS138B=0; LS138C=0; break;
- case 1:LS138A=1; LS138B=0; LS138C=0; break;
- case 2:LS138A=0; LS138B=1; LS138C=0; break;
- case 3:LS138A=1; LS138B=1; LS138C=0; break;
- delay(300);
- P0=0;
