在LPC2200工程模板中,有IRQ.S的程序。<br />程序如下:<br /><br /><br /><br />NoInt EQU 0x80<br /><br />USR32Mode EQU 0x10<br />SVC32Mode EQU 0x13<br />SYS32Mode EQU 0x1f<br />IRQ32Mode EQU 0x12<br />FIQ32Mode EQU 0x11<br /><br /> CODE32<br /><br /> AREA IRQ,CODE,READONLY<br /><br /> MACRO<br />$IRQ_Label HANDLER $IRQ_Exception_Function<br /><br /> EXPORT $IRQ_Label ; The label for exports 输出的标号<br /> IMPORT $IRQ_Exception_Function ; The imported labels 引用的外部标号<br /><br />$IRQ_Label<br /> SUB LR, LR, #4 ; Calculate the returning address 计算返回地址<br /> STMFD SP!, {R0-R3, R12, LR} ; Protects the task environments 保存任务环境<br /> MRS R3, SPSR ; Protects the status variable 保存状态<br /> STMFD SP, {R3,LR}^ ; Protects SPSR and SP in user status, Notice: DO NOT write back.保存SPSR和用户状态的SP,注意不能回写<br /> ; If the SP is written back, it should be adjusted to its appropriate value later.如果回写的是用户的SP,所以后面要调整SP<br /> NOP<br /> SUB SP, SP, #4*2<br /><br /> MSR CPSR_c, #(NoInt | SYS32Mode) ; Switch to the System Mode 切换到系统模式 <br /> <br /> BL $IRQ_Exception_Function ; call the C interrupt handler funtion 调用c语言的中断处理程序<br /><br /> MSR CPSR_c, #(NoInt | IRQ32Mode) ; Switch bak to IRQ mode 切换回irq模式<br /> LDMFD SP, {R3,LR}^ ; Recover SPSR and SP in user status, Notic: DO NOT write back. 恢复SPSR和用户状态的SP,注意不能回写<br /> ; If the SP is written back, it should be adjusted to its appropriate value later.如果回写的是用户的SP,所以后面要调整SP<br /> MSR SPSR_cxsf, R3<br /> ADD SP, SP, #4*2 ; <br /><br /> LDMFD SP!, {R0-R3, R12, PC}^ ;<br /> MEND<br /><br /><br />我就是不太清楚其中的:<br />SUB SP,SP,#4*2是什么意思?<br />在这句之前不是有个STMFD SP, {R3,LR}^,它是满递减的,如果用SUB SP,SP,#4*2的话,不是SP指向一个空的地方吗?<br /><br />再后面LDMFD SP, {R3,LR}^,能得到之前保存的状态信息吗?<br /><br />希望高人指教!谢谢<br /> |
