-     <pre name="code" class="cpp"><pre name="code" class="cpp"></pre><pre name="code" class="cpp">//整个probe主要包含以下几步,与其它的ARM芯片很相似
-     //(1)填充三个结构体struct mxc_spi_master,struct spi_master,struct mxc_spi
-     //(2)申请IO资源,中断
-     //(3)SPI寄存器配置
-     //(4)spi_bitbang_start(即调用spi_register_master)
-     //(5)spi_new_device
-     static int mxc_spi_probe(struct platform_device *pdev)
-         //spi私有数据结构体,imx芯片独有,主要存储板级配置文件中设置的一些参数
-         //个人觉得这个结构体有点多余,还没弄清楚原因?
-         struct mxc_spi_master *mxc_platform_info;
-         //描述spi控制器结构体,spi驱动通用
-         struct spi_master *master;
-         struct mxc_spi *master_drv_data = NULL;
-         //一般的ARM控制器的SPI驱动都会包含以上三个结构体(具体名称不用)
-         struct resource *res;
-         unsigned int spi_ver, wml;
-         int ret = -ENODEV;
-         /* Get the platform specific data for this master device */
-         //为什么这里可以强制转换struct platform_data为struct mxc_spi_master?
-         //因为platform_data是一个void类型的指针
-         mxc_platform_info = (struct mxc_spi_master *)pdev->dev.platform_data;
-         if (!mxc_platform_info) {
-             dev_err(&pdev->dev, "can't get the platform data for CSPI\n");
-             return -EINVAL;
-         /* Allocate SPI master controller */
-         master = spi_alloc_master(&pdev->dev, sizeof(struct mxc_spi));
-         if (!master) {
-             dev_err(&pdev->dev, "can't alloc for spi_master\n");
-             return -ENOMEM;
-         /* Set this device's driver data to master */
-         //保存master到pdev
-         platform_set_drvdata(pdev, master);
-         /* Set this master's data from platform_info */
-         //主机控制器编号,如果板子上有多个spi总线,靠这个域区分
-         master->bus_num = pdev->id + 1;
-         //支持spi设备个数
-         master->num_chipselect = mxc_platform_info->maxchipselect;
-         //模式标志位
-         master->mode_bits = SPI_CPOL | SPI_CPHA | SPI_CS_HIGH;
-     #ifdef CONFIG_SPI_MXC_TEST_LOOPBACK
-         master->num_chipselect += 1;
-     #endif
-         /* Set the master controller driver data for this master */
-         //spi_master_get_devdata调用dev_set_drvdata获取设备私有数据
-         //读取保存在master->dev中的私有数据
-         //这个私有数据是在上面的spi_alloc_master中配置的。
-         master_drv_data = spi_master_get_devdata(master);
-         //mxc_bitbang是一个spi_bitbang结构体,struct spi_bitbang 是具体的负责数据传输的结构体
-         master_drv_data->mxc_bitbang.master = spi_master_get(master);
-         //把存储在mxc_platform_info中的一些参数(板级配置文件中设置)存储到master_drv_data
-         if (mxc_platform_info->chipselect_active)
-             master_drv_data->chipselect_active =
-                 mxc_platform_info->chipselect_active;
-         if (mxc_platform_info->chipselect_inactive)
-             master_drv_data->chipselect_inactive =
-                 mxc_platform_info->chipselect_inactive;
-         /* Identify SPI version */
-         //根据扳级配置文件中设置的版本
-         spi_ver = mxc_platform_info->spi_version;
-         if (spi_ver == 7) {
-             master_drv_data->spi_ver_def = &spi_ver_0_7;
-         } else if (spi_ver == 5) {
-             master_drv_data->spi_ver_def = &spi_ver_0_5;
-         } else if (spi_ver == 4) {
-             master_drv_data->spi_ver_def = &spi_ver_0_4;
-         } else if (spi_ver == 0) {
-             master_drv_data->spi_ver_def = &spi_ver_0_0;
-         } else if (spi_ver == 23) {
-             master_drv_data->spi_ver_def = &spi_ver_2_3;
-         dev_dbg(&pdev->dev, "SPI_REV 0.%d\n", spi_ver);
-         /* Set the master bitbang data */
-         //SPI传输的各个函数
-         master_drv_data->mxc_bitbang.chipselect = mxc_spi_chipselect;
-         master_drv_data->mxc_bitbang.txrx_bufs = mxc_spi_transfer;
-         //该函数做一些初始化的工作
-         master_drv_data->mxc_bitbang.master->setup = mxc_spi_setup;
-         master_drv_data->mxc_bitbang.master->cleanup = mxc_spi_cleanup;
-         master_drv_data->mxc_bitbang.setup_transfer = mxc_spi_setup_transfer;
-         /* Initialize the completion object */
-         //completion是内核中一个轻量级机制,允许一个线程告诉另一个线程工作已完成
-         init_completion(&master_drv_data->xfer_done);
-         /* Set the master controller register addresses and irqs */
-         //获取板级配置文件中设置的资源
-         master_drv_data->res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-         if (!master_drv_data->res) {
-             dev_err(&pdev->dev, "can't get platform resource for CSPI%d\n",
-                 master->bus_num);
-             ret = -ENOMEM;
-             goto err;
-         //检测申请的资源是否可用,并把资源标志为已用
-         if (!request_mem_region(master_drv_data->res->start,
-                     master_drv_data->res->end -
-                     master_drv_data->res->start + 1, pdev->name)) {
-             dev_err(&pdev->dev, "request_mem_region failed for CSPI%d\n",
-                 master->bus_num);
-             ret = -ENOMEM;
-             goto err;
-         //映射虚拟内存
-         master_drv_data->base = ioremap(master_drv_data->res->start,
-             master_drv_data->res->end - master_drv_data->res->start + 1);
-         if (!master_drv_data->base) {
-             dev_err(&pdev->dev, "invalid base address for CSPI%d\n",
-                 master->bus_num);
-             ret = -EINVAL;
-             goto err1;
-         //获取板级配置文件中设置的中断号
-         master_drv_data->irq = platform_get_irq(pdev, 0);
-         if (master_drv_data->irq < 0) {
-             dev_err(&pdev->dev, "can't get IRQ for CSPI%d\n",
-                 master->bus_num);
-             ret = -EINVAL;
-             goto err1;
-         /* Register for SPI Interrupt */
-         //注册中断函数mxc_spi_isr
-         ret = request_irq(master_drv_data->irq, mxc_spi_isr,
-                   0, "CSPI_IRQ", master_drv_data);
-         if (ret != 0) {
-             dev_err(&pdev->dev, "request_irq failed for CSPI%d\n",
-                 master->bus_num);
-             goto err1;
-         master_drv_data->dev = &pdev->dev;
-         /* Setup the DMA */
-         //如果设置了dma,(这个在我的板级配置文件中未配置)
-         master_drv_data->usedma = 0;
-         res = platform_get_resource(pdev, IORESOURCE_DMA, 0);
-         if (res) {
-             master_drv_data->dma_tx_id = res->start;
-             if (pdev->dev.dma_mask == NULL)
-                 dev_warn(&pdev->dev, "no dma mask\n");
-             else
-                 master_drv_data->usedma = 1;
-         if (master_drv_data->usedma) {
-             master_drv_data->dma_tx_ch =
-                 mxc_dma_request(master_drv_data->dma_tx_id, "mxc_spi");
-             if (master_drv_data->dma_tx_ch < 0) {
-                 dev_info(&pdev->dev, "Can't allocate RX DMA ch\n");
-                 ret = -ENXIO;
-                 goto err_no_txdma;
-             mxc_dma_callback_set(master_drv_data->dma_tx_ch,
-                     mxc_spi_dma_tx_callback,
-                     (void *)master_drv_data);
-             /* Allocate tmp_buf for tx_buf */
-             master_drv_data->tmp_buf = kzalloc(SPI_BUFSIZ, GFP_KERNEL);
-             if (master_drv_data->tmp_buf == NULL) {
-                 ret = -ENOMEM;
-                 goto err_tmp_buf_alloc;
-         /* Setup any GPIO active */
-         //配置SPI口IO,一般高级ARM芯片有多个SPI口,配置哪个由bus_num决定,bus_num是板级配置文件中设置
-         gpio_spi_active(master->bus_num - 1);
-         /* Enable the CSPI Clock, CSPI Module, set as a master */
-         //i.mx536的SPI控制器的寄存器配置
-         master_drv_data->ctrl_addr =
-             master_drv_data->base + master_drv_data->spi_ver_def->ctrl_reg_addr;
-         master_drv_data->dma_addr =
-             master_drv_data->base + master_drv_data->spi_ver_def->dma_reg_addr;
-         master_drv_data->stat_addr =
-             master_drv_data->base + master_drv_data->spi_ver_def->stat_reg_addr;
-         master_drv_data->period_addr =
-             master_drv_data->spi_ver_def->period_reg_addr;
-         master_drv_data->test_addr =
-             master_drv_data->base + master_drv_data->spi_ver_def->test_reg_addr;
-         master_drv_data->reset_addr =
-             master_drv_data->spi_ver_def->reset_reg_addr;
-         //开启SPI时钟
-         master_drv_data->clk = clk_get(&pdev->dev, "cspi_clk");
-         clk_enable(master_drv_data->clk);
-         //获取时钟频率
-         master_drv_data->spi_ipg_clk = clk_get_rate(master_drv_data->clk);
-         __raw_writel(master_drv_data->spi_ver_def->reset_start,
-                  master_drv_data->reset_addr);
-         udelay(1);
-         __raw_writel((master_drv_data->spi_ver_def->spi_enable +
-                   master_drv_data->spi_ver_def->master_enable),
-                  master_drv_data->base + MXC_CSPICTRL);
-         __raw_writel(MXC_CSPIPERIOD_32KHZ, master_drv_data->period_addr);
-         __raw_writel(0, MXC_CSPIINT + master_drv_data->ctrl_addr);
-             /* Set water mark level to be the half of fifo_size in DMA */
-             wml = master_drv_data->spi_ver_def->fifo_size / 2;
-             wml = wml << master_drv_data->spi_ver_def->tx_wml_shift;
-             __raw_writel((__raw_readl(master_drv_data->dma_addr)
-                     & ~master_drv_data->spi_ver_def->tx_wml_mask)
-                     | wml,
-                     master_drv_data->dma_addr);
-         /* Start the SPI Master Controller driver */
-         //启动SPI控制器
-         //最终调用spi_register_master来注册spi控制器
-         ret = spi_bitbang_start(&master_drv_data->mxc_bitbang);
-         if (ret != 0)
-             goto err2;
-         printk(KERN_INFO "CSPI: %s-%d probed\n", pdev->name, pdev->id);
-             int i;
-             struct spi_board_info *bi = &loopback_info[0];
-             for (i = 0; i < ARRAY_SIZE(loopback_info); i++, bi++) {
-                 if (bi->bus_num != master->bus_num)
-                     continue;
-                      "registering loopback device '%s'\n",
-                      bi->modalias);
-                 spi_new_device(master, bi);
-     #endif
-         clk_disable(master_drv_data->clk);
-         return ret;
-           err2:
-         gpio_spi_inactive(master->bus_num - 1);
-         clk_put(master_drv_data->clk);
-             kfree(master_drv_data->tmp_buf);
-     err_tmp_buf_alloc:
-             mxc_dma_free(master_drv_data->dma_tx_ch);
-     err_no_txdma:
-         free_irq(master_drv_data->irq, master_drv_data);
-           err1:
-         //最终调用free函数,释放内存
-         iounmap(master_drv_data->base);
-         release_mem_region(pdev->resource[0].start,
-                    pdev->resource[0].end - pdev->resource[0].start + 1);
-           err:
-         spi_master_put(master);
-         kfree(master);
-         platform_set_drvdata(pdev, NULL);
-         return ret;
-     }</pre><br>
-     <br>
-     <pre></pre>
-     <pre></pre>
-     <pre></pre>
-             <div style="padding-top:20px">
-                 <p style="font-size:12px;">版权声明:本文为博主原创**,未经博主允许不得转载。</p>
-             </div>
-     </pre>
