msp149 8通道AD采集辣手问题
1328|0
mingyuekd|  楼主 | 2010-7-13 16:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
片子是149型号,之前调单路P6.0通道ad采集,一切正常,
现在要采集8路ad,用P6脚 序列多通道多次转换,初始化如下。调试发现,AD1通道依旧正常,AD2...AD8采集数不正确。望哪位朋友赐教。谢谢
  P6DIR =0x00;                          //p6=input
     P6SEL = 0xff;                        // Enable A/D channel A0 A1 A2 A3 ....A7
      ADC12MCTL0 |=0x020;                    //  sel channel A0 Sref=1        OUT  VR+=VEREF
     ADC12MCTL1 |=0x020;                    //  sel channel A1 Sref=1        OUT  VR+=VEREF
     ADC12MCTL2 |=0x022;                    //  sel channel A2 Sref=1        OUT  VR+=VEREF
     ADC12MCTL3 |=0x023;                    //  sel channel A3 Sref=1        OUT  VR+=VEREF
     ADC12MCTL4 |=0x024;                    //  sel channel A4 Sref=1        OUT  VR+=VEREF
     ADC12MCTL5 |=0x025;                    //  sel channel A5 Sref=1        OUT  VR+=VEREF
     ADC12MCTL6 |=0x026;                    //  sel channel A6 Sref=1        OUT  VR+=VEREF
     ADC12MCTL7 |=0x027;                    //  sel channel A7 Sref=1        OUT  VR+=VEREF
     //ADC12MCTL7 |=0x080;                    // set channel A7 last time
    ADC12CTL0 = ADC12ON;//+SHT0_0;//+SHT1_0;
    ADC12CTL0 |= 0x0080;                   //MSC=1
      ADC12CTL1 = SHP;                      // Use sampling timer /ADC12OSC
    ADC12CTL1 |= 0x0008;                      // ADC12SSEL=1 Use sampling timer /ACLK
    ADC12CTL1 |= 0x0006;                      //mult channel conseq   continue ad
    ADC12CTL0 |= ENC;                     // Enable conversions
    ADC12CTL0 |= ADC12SC;                     // Start conversion
