[allegro]
allergo 导入DXF问题求助,显示如下信息
6532|3
dongchen|  楼主 | 2017-11-1 21:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Reading Layer Conversion File
Reading DXF file...
NOTE: Replacing illegal character * with X in *Model_Space.
NOTE: Replacing illegal character * with X in *Paper_Space.
NOTE: Replacing illegal character * with X in *D8.
NOTE: Replacing illegal character * with X in *D9.
NOTE: Replacing illegal character * with X in *D10.
NOTE: Replacing illegal character * with X in *D11.
NOTE: Replacing illegal character * with X in *D12.
NOTE: Replacing illegal character * with X in *D13.
NOTE: Replacing illegal character * with X in *D14.
ERROR: 3D data has been found in this dxf file.
  Most 3D data is not supported by dxf2a.
  For the special case of DXF code 230 = -1.0, ARC, CIRCLE
  and SOLID entities will be mirrored about the Y axis.
ERROR: 3D data (DXF code 30, value = 0.3658) detected on CIRCLE at line 5496
ERROR: 3D data (DXF code 30, value = 0.3658) detected on LINE at line 5706
ERROR: 3D data (DXF code 31, value = 0.3658) detected on LINE at line 5712
ERROR: 3D data (DXF code 30, value = 0.3658) detected on LINE at line 5734
ERROR: 3D data (DXF code 31, value = 0.3658) detected on LINE at line 5740
ERROR: 3D data (DXF code 30, value = 0.3658) detected on LINE at line 5790
ERROR: 3D data (DXF code 31, value = 0.3658) detected on LINE at line 5796
ERROR: 3D data (DXF code 30, value = 0.3658) detected on LINE at line 5818
ERROR: 3D data (DXF code 31, value = 0.3658) detected on LINE at line 5824
done.
ERROR: Opening file #Taaaaak03144.tmp.
ERROR: Opening #Taaaaak03144.tmp for incremental update failed.
Terminating program
jjjyufan| | 2017-11-2 08:39 | 只看该作者
DXF文件先处理下 把不需要的都删除
西电奋斗者| | 2017-11-2 20:18 | 只看该作者
里面包含有非法字符
liy1979| | 2019-2-16 13:15 | 只看该作者
能请教一下,俱体如何解决的吗???
