23885JTAG连接出现问题,麻烦大家看看怎么解决?
3340|13
晨会|  楼主 | 2017-12-20 15:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用的是CCS5.5,仿真器型号设置是正确的,烧写的板子是官方HVPM电机用的控制板。还试着用其他两片自己按官方控制板改造的板子,结果还是一样的错误。
仿真器应该是没有问题的。
connection test 的内容如下:
[Start]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\zejian\AppData\Local\.TI\1879930773\
0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioserdesusbv3.dll'.
The library build date was 'Aug 20 2013'.
The library build time was '22:56:19'.
The library package version is '5.1.232.0'.
The library component version is '35.34.40.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '4' (0x00000004).
The controller has an insertion length of '0' (0x00000000).
This utility will attempt to reset the controller.
This utility has successfully reset the controller.
-----[Print the reset-command hardware log-file]-----------------------------
The scan-path will be reset by toggling the JTAG TRST signal.
The controller is the FTDI FT2232 with USB interface.
The link from controller to target is direct (without cable).
The software is configured for FTDI FT2232 features.
The controller cannot monitor the value on the EMU[0] pin.
The controller cannot monitor the value on the EMU[1] pin.
The controller cannot control the timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '0' (0x0000).
An error occurred while hard opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-233' (0xffffff17).
The title is 'SC_ERR_PATH_BROKEN'.
The explanation is:
The JTAG IR and DR scan-paths cannot circulate bits, they may be broken.
An attempt to scan the JTAG scan-path has failed.
The target's JTAG scan-path appears to be broken
with a stuck-at-ones or stuck-at-zero fault.
[End]
不知道是什么问题,很烦现在,希望能够帮我解决一下问题,谢谢!
ghuca| | 2017-12-21 22:20 | 只看该作者
使用的是什么仿真器?
soodesyt| | 2017-12-21 22:20 | 只看该作者
这个告警是在什么地方出现的?
ghuca| | 2017-12-21 22:23 | 只看该作者
电脑是否识别了这个仿真器?
soodesyt| | 2017-12-21 22:23 | 只看该作者
连接的时候还是仿真的时候?
zhangmangui| | 2017-12-22 22:21 | 只看该作者
感觉像FT2232的配置模式了    类似于更新插件
zhangbo1985| | 2017-12-23 21:37 | 只看该作者
这是在说硬件引起的问题的哈
晨会|  楼主 | 2017-12-26 15:17 | 只看该作者
ghuca 发表于 2017-12-21 22:20
使用的是什么仿真器?
使用的是XDS100v3
晨会|  楼主 | 2017-12-26 15:18 | 只看该作者
ghuca 发表于 2017-12-21 22:23
电脑是否识别了这个仿真器?
插上去的时候可以在设备管理器里面看到这个设备,应该是可以识别的
soodesyt 发表于 2017-12-21 22:20
这个告警是在什么地方出现的?
CCS,调试的时候出现的
晨会|  楼主 | 2017-12-26 15:19 | 只看该作者
soodesyt 发表于 2017-12-21 22:23
连接的时候还是仿真的时候?
点击调试的时候
晨会|  楼主 | 2017-12-26 15:20 | 只看该作者
什么意思??
有什么解决的办法吗
zhangmangui| | 2017-12-26 22:40 | 只看该作者
晨会 发表于 2017-12-26 15:20
什么意思??
有什么解决的办法吗
首先接入仿真器   看看设备管理器下是否出现串口和JTAG两个设备
如果看到  说明仿真器基本没问题
接下来就看CCS这边对仿真器的驱动支持了
晨会|  楼主 | 2018-2-26 16:39 | 只看该作者
我的问题解决了,这边是jtag线损坏,换了一根jtag线就能用了。
