[嵌入式linux]
STM32 LED灯的另一种写法
1229|2
coffee1|  楼主 | 2018-1-29 15:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
[cpp] view plain copy
#ifndef __BSP_LED_
#define __BSP_LED_
#include <MM32x103.h> // 这个换成STM32的库文件就行
#include "type.h"
#define LED1_RUN_GRP      GPIOC
#define LED1_RUN_IDX      GPIO_Pin_6
#define LED1_RUN_OFF()    GPIO_ResetBits(LED1_RUN_GRP, LED1_RUN_IDX)
#define LED1_RUN_ON()     GPIO_SetBits(LED1_RUN_GRP, LED1_RUN_IDX)
#define LED1_RUN_IS_OFF() GPIO_ReadOutputDataBit(LED1_RUN_GRP, LED1_RUN_IDX)
#define LED2_RUN_GRP      GPIOA
#define LED2_RUN_IDX      GPIO_Pin_11
#define LED2_RUN_OFF()    GPIO_ResetBits(LED2_RUN_GRP, LED2_RUN_IDX)
#define LED2_RUN_ON()     GPIO_SetBits(LED2_RUN_GRP, LED2_RUN_IDX)
#define LED2_RUN_IS_OFF() GPIO_ReadOutputDataBit(LED2_RUN_GRP, LED2_RUN_IDX)
#define LED3_RUN_GRP      GPIOA
#define LED3_RUN_IDX      GPIO_Pin_12
#define LED3_RUN_OFF()    GPIO_ResetBits(LED3_RUN_GRP, LED3_RUN_IDX)
#define LED3_RUN_ON()     GPIO_SetBits(LED3_RUN_GRP, LED3_RUN_IDX)
#define LED3_RUN_IS_OFF() GPIO_ReadOutputDataBit(LED3_RUN_GRP, LED3_RUN_IDX)
#define LED_COUNT   3 // LED个数自己定义
typedef enum
  RED   = 0x04,
  GREEN = 0x02,
  BLUE  = 0x01
} led_t;
typedef struct
  GPIO_TypeDef *GPIOx;
  uint32_t pos;
} led_port_t;
void GPIOConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin, GPIOMode_TypeDef GPIO_Mode);
void LEDConfig((uint8_t value) // value:1/2/4 --- RED GREEN BLUE
void LEDSet(uint8_t value);
void LEDReset(uint8_t value);
void LEDToggle(uint8_t value);
#endif /* __BSP_LED_ */
#include "bsp_led.h"
static led_port_t led_port[LED_COUNT] =
  {LED1_RUN_GRP, LED1_RUN_IDX}, /*蓝灯*/
  {LED2_RUN_GRP, LED2_RUN_IDX}, /*绿灯*/
  {LED3_RUN_GRP, LED3_RUN_IDX}, /*红灯*/
// GPIO配置
  GPIO_InitTypeDef GPIO_InitStructure;//定义GPIO初始化结构体变量
  // 这个GPIO口需要改的,根据自己情况而定
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOA, ENABLE);  //开启GPIO时钟
  //配置连接LED的GPIO为推挽输出模式
  GPIO_InitStructure.GPIO_Pin  =  GPIO_Pin;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode;
  GPIO_Init(GPIOx, &GPIO_InitStructure);
// LED GPIO配置
  uint8_t i, mask = 1;
  for(i = 0; i < LED_COUNT; ++i)
    if(value & mask)
      GPIOConfig(led_port[i].GPIOx, led_port[i].pos, GPIO_Mode_Out_PP);
      GPIO_ResetBits(led_port[i].GPIOx, led_port[i].pos);
    mask <<= 1;
/* 根据参数来打开LED灯 */
    if(value & mask)
      GPIO_SetBits(led_port[i].GPIOx, led_port[i].pos);
    mask <<= 1;
/* 根据参数来关闭LED灯 */
    if(value & mask)
    mask <<= 1;
// 取反
    if(value & mask)
      if(GPIO_ReadOutputDataBit(led_port[i].GPIOx, led_port[i].pos) == 0)
      else
    mask <<= 1;
dirtwillfly| | 2018-2-4 18:04 | 只看该作者
感谢分享
Prry| | 2018-2-5 11:54 | 只看该作者
Linux的思想就是这样干的
