在合众达板子上,进入合众达提供的内核源码树目录下执行如下命令,配置内核为合众达出厂配置(这是一种考虑尽量多兼容性的配置)
$make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- SEED_DIM3517_defconfig
用如下命令编译出默认内核
$make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- uImage
现在你可以试用一下默认内核感受一下内核的启动速度
如果你觉得内核的启动速度已经可以接受,则可以跳过下面的内容。
如果你认为速度还需要进一步改善,请接着往下看。
这时打开内核的printktimes选项。按下面两个图操作始可
重新生成uImage, 并用新的uImage文件启动。
按照在7楼的说法得到内核中各个模块启动时间如下。
[975.592071 < 0.035187 >] bio: create slab <bio-0> at 0
[975.594665 < 0.002594 >] SCSI subsystem initialized
[975.596405 < 0.001740 >] usbcore: registered new interface driver usbfs
[975.596893 < 0.000488 >] usbcore: registered new interface driver hub
[975.597229 < 0.000336 >] usbcore: registered new device driver usb
[975.598419 < 0.001190 >] i2c_omap i2c_omap.1: bus 1 rev3.12 at 400 kHz
[975.600860 < 0.002441 >] regulator: VDCDC1: 1200 mV normal
[975.601531 < 0.000671 >] regulator: VDCDC2: 3300 mV normal
[975.602111 < 0.000580 >] regulator: VDCDC3: 1800 mV normal
[975.602691 < 0.000580 >] regulator: LDO1: 1800 mV normal
[975.603302 < 0.000611 >] regulator: LDO2: 3300 mV normal
[975.603790 < 0.000488 >] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
[975.615753 < 0.011963 >] pca953x 2-0021: failed reading register
[975.615814 < 0.000061 >] pca953x: probe of 2-0021 failed with error -5
[975.631347 < 0.015533 >] i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz
[975.646972 < 0.015625 >] tca6416-keypad 3-0020: failed reading register
[975.647003 < 0.000031 >] tca6416-keypad: probe of 3-0020 failed with error -5
[975.647369 < 0.000366 >] pca953x 3-0021: failed reading register
[975.647399 < 0.000030 >] pca953x: probe of 3-0021 failed with error -5
[975.649597 < 0.002198 >] Switching to clocksource 32k_counter
[975.652587 < 0.002990 >] musb_hdrc: version 6.0, cppi4.1-dma, otg (peripheral+host), debug=0
[975.673583 < 0.020996 >] AM3517 OTG revision 4ea41001, PHY f0036a2, control 00
[975.673980 < 0.000397 >] musb_hdrc: ConfigData=0x1e (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
[975.674011 < 0.000031 >] musb_hdrc: MHDRC RTL version 1.900
[975.674041 < 0.000030 >] musb_hdrc: setup fifo_mode 4
[975.674072 < 0.000031 >] musb_hdrc: 28/31 max ep, 16384/32768 memory
[975.674133 < 0.000061 >] musb_hdrc: USB OTG mode controller at c8810000 using DMA, IRQ 71
[975.674957 < 0.000824 >] NET: Registered protocol family 2
[975.675170 < 0.000213 >] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[975.675750 < 0.000580 >] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[975.675903 < 0.000153 >] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[975.675994 < 0.000091 >] TCP: Hash tables configured (established 4096 bind 4096)
[975.676025 < 0.000031 >] TCP reno registered
[975.676025 < 0.000000 >] UDP hash table entries: 256 (order: 0, 4096 bytes)
[975.676086 < 0.000061 >] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[975.676300 < 0.000214 >] NET: Registered protocol family 1
[975.676757 < 0.000457 >] RPC: Registered udp transport module.
[975.676757 < 0.000000 >] RPC: Registered tcp transport module.
[975.676788 < 0.000031 >] RPC: Registered tcp NFSv4.1 backchannel transport module.
[975.677612 < 0.000824 >] AM3517 Linux PSP version 03.00.01.06 (AM3517EVM)
[975.677642 < 0.000030 >] NetWinder Floating Point Emulator V0.97 (double precision)
[975.679718 < 0.002076 >] VFS: Disk quotas dquot_6.5.2
[975.679809 < 0.000091 >] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[975.681152 < 0.001343 >] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[975.681915 < 0.000763 >] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[975.682556 < 0.000641 >] yaffs Jul 21 2011 23:38:33 Installing.
[975.682647 < 0.000091 >] msgmni has been set to 234
[975.684478 < 0.001831 >] alg: No test for stdrng (krng)
[975.684570 < 0.000092 >] io scheduler noop registered
[975.684600 < 0.000030 >] io scheduler deadline registered
[975.684783 < 0.000183 >] io scheduler cfq registered (default)
[975.743713 < 0.058930 >] OMAP DSS rev 2.0
[975.743774 < 0.000061 >] OMAP DISPC rev 3.0
[975.743835 < 0.000061 >] OMAP VENC rev 2
[975.744262 < 0.000427 >] OMAP DSI rev 1.0
[976.093170 < 0.348908 >] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[976.115844 < 0.022674 >] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[976.136901 < 0.021057 >] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[976.157775 < 0.020874 >] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[976.640075 < 0.482300 >] console [ttyS2] enabled
[976.655975 < 0.015900 >] brd: module loaded
[976.665496 < 0.009521 >] loop: module loaded
[976.669799 < 0.004303 >] omap2-nand driver initializing
[976.674407 < 0.004608 >] NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bit)
[976.683166 < 0.008759 >] Creating 5 MTD partitions on "omap2-nand.0":
[976.688537 < 0.005371 >] 0x000000000000-0x000000080000 : "xloader-nand"
[976.696075 < 0.007538 >] 0x000000080000-0x000000240000 : "uboot-nand"
[976.703582 < 0.007507 >] 0x000000240000-0x000000280000 : "params-nand"
[976.710388 < 0.006806 >] 0x000000280000-0x000000780000 : "linux-nand"
[976.719055 < 0.008667 >] 0x000000780000-0x000020000000 : "jffs2-nand"
[976.934783 < 0.215728 >] vcan: Virtual CAN interface driver
[976.939331 < 0.004548 >] CAN device driver interface
[976.943206 < 0.003875 >] TI High End CAN Controller Driver 0.7
[976.948028 < 0.004822 >] failed to get can_stb
[976.952362 < 0.004334 >] ti_hecc ti_hecc.1: device registered (reg_base=c8870000, irq=24)
[976.960357 < 0.007995 >] usbcore: registered new interface driver hwa-rc
[976.966766 < 0.006409 >] usbmon: debugfs is not available
[976.971130 < 0.004364 >] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[976.977783 < 0.006653 >] ~~~~~~~~~~~~~~~~~~~~~0!!!!!!!!!!!~~~~~~~~~`
[976.983093 < 0.005310 >] ~~~~~~~~~~~~~~~~~~~~~1!!!!!!!!!!!~~~~~~~~~`
[976.988555 < 0.005462 >] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[976.994445 < 0.005890 >] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[977.002136 < 0.007691 >] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[977.016937 < 0.014801 >] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[977.023925 < 0.006988 >] hub 1-0:1.0: USB hub found
[977.027801 < 0.003876 >] hub 1-0:1.0: 3 ports detected
[977.056243 < 0.028442 >] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[977.062957 < 0.006714 >] usbcore: registered new interface driver hwa-hc
[977.069000 < 0.006043 >] usbcore: registered new interface driver wusb-cbaf
[977.074920 < 0.005920 >] Initializing USB Mass Storage driver...
[977.080230 < 0.005310 >] usbcore: registered new interface driver usb-storage
[977.086273 < 0.006043 >] USB Mass Storage support registered.
[977.091033 < 0.004760 >] g_ether gadget: using random self ethernet address
[977.096954 < 0.005921 >] g_ether gadget: using random host ethernet address
[977.103607 < 0.006653 >] usb0: MAC 2a:eb:77:58:8e:fb
[977.107482 < 0.003875 >] usb0: HOST MAC 8e:c8:d7:06:a7:9f
[977.111907 < 0.004425 >] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[977.118591 < 0.006684 >] g_ether gadget: g_ether ready
[977.122650 < 0.004059 >] musb_hdrc musb_hdrc: MUSB HDRC host driver
[977.127929 < 0.005279 >] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
[977.136474 < 0.008545 >] hub 2-0:1.0: USB hub found
[977.140289 < 0.003815 >] hub 2-0:1.0: 1 port detected
[977.145568 < 0.005279 >] mice: PS/2 mouse device common for all mice
[977.151184 < 0.005616 >] tsc2003 init
[977.153900 < 0.002716 >] tsc2003 probe
[977.156585 < 0.002685 >] mux: Setting signal mcspi1_cs2.gpio176 0x0114 -> 0x011c
[977.156616 < 0.000031 >] tsc2003 begin
[977.159454 < 0.002838 >] GPIO176 irqqq :336
[977.162963 < 0.003509 >] input: tsc2003 as /class/input/input0
[977.212280 < 0.049317 >] tsc2003 x:-5 y:-5 z:-5 bate:-5
[977.419555 < 0.207275 >] rtc-s35390a 1-0030: error resetting chip
[977.426361 < 0.006806 >] rtc-s35390a: probe of 1-0030 failed with error -5
[977.432525 < 0.006164 >] Linux video capture interface: v2.00
[977.437622 < 0.005097 >] vpfe_init
[977.440124 < 0.002502 >] vpfe-capture vpfe-capture: v4l2 device registered
[977.446350 < 0.006226 >] vpfe-capture vpfe-capture: video device registered
[977.452911 < 0.006561 >] tvp514x 3-005c: tvp514x 3-005c decoder driver registered !!
[977.459655 < 0.006744 >] vpfe-capture vpfe-capture: v4l2 sub device tvp5146 registered
[977.466827 < 0.007172 >] vpfe_register_ccdc_device: DM6446 CCDC
[977.471832 < 0.005005 >] DM6446 CCDC is registered with vpfe.
[977.477508 < 0.005676 >] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[977.484954 < 0.007446 >] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card detect
[977.493164 < 0.008210 >] usbcore: registered new interface driver usbhid
[977.498840 < 0.005676 >] usbhid: USB HID core driver
[977.503112 < 0.004272 >] Advanced Linux Sound Architecture Driver Version 1.0.21.
[977.512542 < 0.009430 >] No device for DAI AD73311
[977.516479 < 0.003937 >] Asahi Kasei AK4104 ALSA SoC Codec Driver
[977.521820 < 0.005341 >] No device for DAI AK4535
[977.526000 < 0.004180 >] Cirrus Logic CS4270 ALSA SoC Codec Driver
[977.531311 < 0.005311 >] No device for DAI PCM3008 HiFi
[977.536804 < 0.005493 >] No device for DAI SSM2602
[977.540588 < 0.003784 >] No device for DAI tlv320aic23
[977.657623 < 0.117035 >] mmc0: new high speed SD card at address 6919
[977.663635 < 0.006012 >] mmcblk0: mmc0:6919 SD02G 1.83 GiB
[977.668487 < 0.004852 >] mmcblk0: p1 p2
[977.993530 < 0.325043 >] No device for DAI tlv320aic3x
[977.998107 < 0.004577 >] No device for DAI UDA134X
[978.002105 < 0.003998 >] No device for DAI WM8510 HiFi
[978.007354 < 0.005249 >] No device for DAI WM8728
[978.011505 < 0.004151 >] No device for DAI WM8750
[978.016510 < 0.005005 >] No device for DAI WM8971
[978.021636 < 0.005126 >] No device for DAI WM8990 ADC/DAC Primary
[978.027679 < 0.006043 >] No device for DAI omap-mcbsp-dai-0
[978.032135 < 0.004456 >] No device for DAI omap-mcbsp-dai-1
[978.036712 < 0.004577 >] No device for DAI omap-mcbsp-dai-2
[978.041229 < 0.004517 >] No device for DAI omap-mcbsp-dai-3
[978.045684 < 0.004455 >] No device for DAI omap-mcbsp-dai-4
[978.050170 < 0.004486 >] OMAP3517 / AM3517 EVM SoC init
[978.056335 < 0.006165 >] asoc: tlv320aic3x <-> omap-mcbsp-dai-0 mapping ok
[978.063140 < 0.006805 >] Failed to add route IN1L->LINE1L
[978.067504 < 0.004364 >] dapm: tlv320aic3x: configuring unknown pin Line Out
[978.080322 < 0.012818 >] ALSA device list:
[978.083312 < 0.002990 >] #0: am3517evm (tlv320aic3x)
[978.087646 < 0.004334 >] TCP cubic registered
[978.090911 < 0.003265 >] NET: Registered protocol family 17
[978.095458 < 0.004547 >] NET: Registered protocol family 15
[978.099975 < 0.004517 >] can: controller area network core (rev 20090105 abi 8)
[978.106353 < 0.006378 >] NET: Registered protocol family 29
[978.110931 < 0.004578 >] can: raw protocol (rev 20090105)
[978.115203 < 0.004272 >] can: broadcast manager protocol (rev 20090105 t)
[978.121582 < 0.006379 >] Power Management for TI OMAP3.
[978.125976 < 0.004394 >] Disabling unused clock "emac_fck"
[978.125976 < 0.000000 >] Disabling unused clock "emac_ick"
[978.126007 < 0.000031 >] Disabling unused clock "mcbsp_fck"
[978.126037 < 0.000030 >] Disabling unused clock "mcbsp_fck"
[978.126037 < 0.000000 >] Disabling unused clock "mcbsp_fck"
[978.126068 < 0.000031 >] Disabling unused clock "mcbsp_ick"
[978.126098 < 0.000030 >] Disabling unused clock "mcbsp_ick"
[978.126098 < 0.000000 >] Disabling unused clock "mcbsp_ick"
[978.126129 < 0.000031 >] Disabling unused clock "gpt2_ick"
[978.126129 < 0.000000 >] Disabling unused clock "gpt3_ick"
[978.126159 < 0.000030 >] Disabling unused clock "gpt4_ick"
[978.126159 < 0.000000 >] Disabling unused clock "gpt5_ick"
[978.126190 < 0.000031 >] Disabling unused clock "gpt6_ick"
[978.126220 < 0.000030 >] Disabling unused clock "gpt7_ick"
[978.126220 < 0.000000 >] Disabling unused clock "gpt8_ick"
[978.126251 < 0.000031 >] Disabling unused clock "gpt9_ick"
[978.126251 < 0.000000 >] Disabling unused clock "wdt3_ick"
[978.126281 < 0.000030 >] Disabling unused clock "wdt3_fck"
[978.126342 < 0.000061 >] Disabling unused clock "gpio2_dbck"
[978.126373 < 0.000031 >] Disabling unused clock "gpio3_dbck"
[978.126373 < 0.000000 >] Disabling unused clock "gpio4_dbck"
[978.126403 < 0.000030 >] Disabling unused clock "gpio5_dbck"
[978.126403 < 0.000000 >] Disabling unused clock "gpio6_dbck"
[978.126434 < 0.000031 >] Disabling unused clock "gpt9_fck"
[978.126464 < 0.000030 >] Disabling unused clock "gpt8_fck"
[978.126464 < 0.000000 >] Disabling unused clock "gpt7_fck"
[978.126495 < 0.000031 >] Disabling unused clock "gpt6_fck"
[978.126495 < 0.000000 >] Disabling unused clock "gpt5_fck"
[978.126525 < 0.000030 >] Disabling unused clock "gpt4_fck"
[978.126525 < 0.000000 >] Disabling unused clock "gpt3_fck"
[978.126556 < 0.000031 >] Disabling unused clock "gpt2_fck"
[978.126556 < 0.000000 >] Disabling unused clock "gpt12_ick"
[978.126586 < 0.000030 >] Disabling unused clock "wdt1_ick"
[978.126617 < 0.000031 >] Disabling unused clock "gpio1_dbck"
[978.126617 < 0.000000 >] Disabling unused clock "mcbsp_ick"
[978.126647 < 0.000030 >] Disabling unused clock "mcbsp_ick"
[978.126678 < 0.000031 >] Disabling unused clock "gpt10_ick"
[978.126678 < 0.000000 >] Disabling unused clock "gpt11_ick"
[978.126708 < 0.000030 >] Disabling unused clock "mcspi_ick"
[978.126708 < 0.000000 >] Disabling unused clock "mcspi_ick"
[978.126739 < 0.000031 >] Disabling unused clock "mcspi_ick"
[978.126770 < 0.000031 >] Disabling unused clock "mcspi_ick"
[978.126770 < 0.000000 >] Disabling unused clock "hdq_ick"
[978.126800 < 0.000030 >] Disabling unused clock "hdq_fck"
[978.126800 < 0.000000 >] Disabling unused clock "mcspi_fck"
[978.126831 < 0.000031 >] Disabling unused clock "mcspi_fck"
[978.126831 < 0.000000 >] Disabling unused clock "mcspi_fck"
[978.126861 < 0.000030 >] Disabling unused clock "mcspi_fck"
[978.126861 < 0.000000 >] Disabling unused clock "mcbsp_fck"
[978.126892 < 0.000031 >] Disabling unused clock "mcbsp_fck"
[978.126922 < 0.000030 >] Disabling unused clock "gpt11_fck"
[978.126922 < 0.000000 >] Disabling unused clock "gpt10_fck"
[978.126953 < 0.000031 >] Disabling unused clock "dpll4_m6x2_ck"
[978.126983 < 0.000030 >] Disabling unused clock "dpll4_m5x2_ck"
[978.126983 < 0.000000 >] Disabling unused clock "dpll3_m3x2_ck"
[978.127014 < 0.000031 >] Disabling unused clock "sys_clkout1"
[978.127593 < 0.000579 >] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[978.151489 < 0.023896 >] Console: switching to colour frame buffer device 100x30
[978.239227 < 0.087738 >] omapdss DPI: Could not find exact pixel clock. Requested 35087 kHz, got 35086 kHz
[978.250549 < 0.011322 >] davinci_emac_probe: using random MAC addr: 4e:14:cb:c5:2f:c9
[978.260040 < 0.009491 >] emac-mii: probed
[978.263214 < 0.003174 >] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[978.269744 < 0.006530 >] omapdss DPI error: display already enabled
[978.274932 < 0.005188 >] omap_vout omap_vout: 'lcd' Display already enabled
[978.280822 < 0.005890 >] omapdss DPI error: display already enabled
[978.286010 < 0.005188 >] omap_vout omap_vout: 'lcd' Display already enabled
[978.291931 < 0.005921 >] omap_vout omap_vout: Buffer Size = 3686400
[978.298675 < 0.006744 >] omap_vout omap_vout: : registered and initialized video device 1
[978.305816 < 0.007141 >] omap_vout omap_vout: Buffer Size = 3686400
[978.312561 < 0.006745 >] omap_vout omap_vout: : registered and initialized video device 2
[978.823852 < 0.511291 >] eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ffffffff:00, id=221613)
[979.837310 < 1.013458 >] Sending DHCP and RARP requests ...... timed out!
[1054.362609 < 74.525299 >] IP-Config: Reopening network devices...
[1054.869781 < 0.507172 >] eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ffffffff:00, id=221613)
[1055.884124 < 1.014343 >] Sending DHCP and RARP requests ...... timed out!
[1131.878112 < 75.993988 >] IP-Config: Auto-configuration of network failed.
[1134.965942 < 3.087830 >] Empty flash at 0x00c5f3e4 ends at 0x00c5f800
[1137.241119 < 2.275177 >] Empty flash at 0x1ae5d108 ends at 0x1ae5d800
[1137.671966 < 0.430847 >] VFS: Mounted root (jffs2 filesystem) on device 31:4.
[1137.678161 < 0.006195 >] Freeing init memory: 168K
[1139.638549 < 1.960388 >] JFFS2 notice: (596) check_node_data: wrong data CRC in data node at 0x1ae5cfac: read 0x2efd2e64, calculated 0x5fa9cf47.
[1143.775421 < 4.136872 >] yaffs: dev is 187695104 name is "mmcblk0"
[1143.780517 < 0.005096 >] yaffs: passed flags ""
[1143.783996 < 0.003479 >] yaffs: Attempting MTD mount on 179.0, "mmcblk0"
[1143.938781 < 0.154785 >] yaffs: dev is 187695104 name is "mmcblk0"
[1143.944000 < 0.005219 >] yaffs: passed flags ""
[1143.947448 < 0.003448 >] yaffs: Attempting MTD mount on 179.0, "mmcblk0"
[1145.161468 < 1.214020 >] EXT2-fs (mmcblk0p2): warning: mounting ext3 filesystem as ext2
[1145.168579 < 0.007111 >] EXT2-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
首先我们发现最浪费时间的在试图动态获得网络IP那一块。然后第二多的就是各种文件系统初始化花费的时间。
作为一款Cortex-A8产品,TI的AM3517在基本的代码运行方面可以说表现得非常出色。不需要做太多的优化。
那前面提到的IP获取那一块,及文件系统方面问题怎么解决呢。
网络,请在内核配置里关掉相关的动态获取IP的选择,对于嵌入式产品通常这是用不到的,而这里的慢,也正是因为实质上没有提供DHCP服务器。
当然,如果能进一步优化一下网络PHY那一块的代码,使得驱动只汇报有一个PHY, 也会快不少。
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ffffffff:00, id=221613) (这是合众达优化前检测PHY的地址,导致系统后面按照32个PHY去做DHCP请求,显然会是超慢的)
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1:00, id=221613 (这是合众达优化后的情况,系统正确的识别了只有一个PHY,这样后面的检测自然会快很多)
文件系统,只保留你用得到的,其它的都关掉吧。比如上面的同时启用Flash的JFFS2和YAFFS2, 实际的产品中是不可能同时使用两种文件系统的,除非板子上即用了Nor Flash又使用了NAND Flash
这是内核方面的问题。
后面我们将继续讲述,UBoot加载内核时发生的情况。
——未完待续——
