接收一组数据
477|9
jlyuan|  楼主 | 2018-2-8 18:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
yszong| | 2018-2-8 18:16 | 只看该作者
什么呀?不明白你说的
jlyuan|  楼主 | 2018-2-8 18:20 | 只看该作者
#include
"DSP28x_Project.h"
// Device Headerfile and Examples Include File
#define CPU_FREQ
60E6
#define LSPCLK_FREQ CPU_FREQ/4
#define SCI_FREQ
100E3
#define SCI_PRD
(LSPCLK_FREQ/(SCI_FREQ*8))-1
// Prototype statements for functions found within this file.
interrupt void sciaTxFifoIsr(void);
interrupt void sciaRxFifoIsr(void);
interrupt void scibTxFifoIsr(void);
interrupt void scibRxFifoIsr(void);
void scia_fifo_init(void);
void scib_fifo_init(void);
void error(void);
// Global variables
Uint16 sdataA[8];
// Send data for SCI-A
Uint16 rdataA[8];
// Received data for SCI-A
Uint16 rdata_pointA; // Used for checking the received data
void main(void)
Uint16 i;
InitSysCtrl();
InitSciGpio();
DINT;
InitPieCtrl();
IER = 0x0000;
IFR = 0x0000;
InitPieVectTable();
EALLOW;
// This is needed to write to EALLOW protected registers
PieVectTable.SCIRXINTA = &sciaRxFifoIsr;
PieVectTable.SCITXINTA = &sciaTxFifoIsr;
EDIS;
// This is needed to disable write to EALLOW protected registers
for(i = 0; i<8; i++)
sdataA = i;
rdata_pointA = sdataA[0];
// Enable interrupts required for this example
PieCtrlRegs.PIECTRL.bit.ENPIE = 1;
// Enable the PIE block
PieCtrlRegs.PIEIER9.bit.INTx1=1;
// PIE Group 9, INT1
PieCtrlRegs.PIEIER9.bit.INTx2=1;
// PIE Group 9, INT2
IER = 0x100; // Enable CPU INT
EINT;
for(;;);
void error(void)
asm("
ESTOP0"); // Test failed!! Stop!
for (;;);
Uint16 i;
for(i=0; i< 2; i++)
SciaRegs.SCITXBUF=sdataA;
// Send data
for(i=0; i< 2; i++)
//Increment send data for next cycle
sdataA = (sdataA+1) & 0x00FF;
SciaRegs.SCIFFTX.bit.TXFFINTCLR=1;
// Clear SCI Interrupt flag
PieCtrlRegs.PIEACK.all|=0x100;
// Issue PIE ACK
Uint16 i;
for(i=0;i<2;i++)
rdataA=SciaRegs.SCIRXBUF.all;
// Read data
for(i=0;i<2;i++)
// Check received data
if(rdataA != ( (rdata_pointA+i) & 0x00FF) ) error();
rdata_pointA = (rdata_pointA+1) & 0x00FF;
SciaRegs.SCIFFRX.bit.RXFFOVRCLR=1;
// Clear Overflow flag
SciaRegs.SCIFFRX.bit.RXFFINTCLR=1;
// Clear Interrupt flag
// Issue PIE ack
void scia_fifo_init()
SciaRegs.SCICCR.all =0x0007;
// 1 stop bit,
No loopback
// No parity,8 char bits,
// async mode, idle-line protocol
SciaRegs.SCICTL1.all =0x0003;
// enable TX, RX, internal SCICLK,
// Disable RX ERR, SLEEP, TXWAKE
SciaRegs.SCICTL2.bit.TXINTENA =1;
SciaRegs.SCICTL2.bit.RXBKINTENA =1;
SciaRegs.SCIHBAUD = 0x0000;
SciaRegs.SCILBAUD = SCI_PRD;
SciaRegs.SCICCR.bit.LOOPBKENA =1; // Enable loop back
SciaRegs.SCIFFTX.all=0xC022;
SciaRegs.SCIFFRX.all=0x0022;
SciaRegs.SCIFFCT.all=0x00;
SciaRegs.SCICTL1.all =0x0023;
// Relinquish SCI from Reset
SciaRegs.SCIFFTX.bit.TXFIFOXRESET=1;
SciaRegs.SCIFFRX.bit.RXFIFORESET=1;
上述程序功能是在28035中运行,发送sdataA[0],sdataA[1]的数据,接收数据存放在rdataA[0],rdataA[1]中,运行没问题,
我将其改成发送sdataA[0]~sdataA[7],并将接收数据存放在rdataA[0]~rdataA[7]中,并修改以下代码:
for(i=0; i< 7; i++)//共四处
SciaRegs.SCIFFTX.all=0xC028;
SciaRegs.SCIFFRX.all=0x0028;
运行时就出错了。但是我用同样的更改在28335中运行,又是正常,请教是什么原因。如何解决才能在28035中运行正常。
dengdc| | 2018-2-8 18:23 | 只看该作者
虽然我不知道为什么,但是可以帮你顶啦
jlyuan|  楼主 | 2018-2-8 18:26 | 只看该作者
我看到28035的例程中,也只是发送两个数据,我把它改成发送八个数据,也是不行。不知道哪里还需要修改?
jlyuan|  楼主 | 2018-2-8 18:30 | 只看该作者
哦,算了,再说吧,多谢大家哈
lzmm| | 2018-2-9 22:18 | 只看该作者
串口中断吗?
xiaoyaodz| | 2018-2-9 22:20 | 只看该作者
是需要SCI的函数吗?
lzmm| | 2018-2-9 22:25 | 只看该作者
使用数组保存数据。
xiaoyaodz| | 2018-2-9 22:25 | 只看该作者
用的是什么处理器?
