[DSP编程]
28335与CAN设备进行通信
1949|6
小弟最近在做28335与CAN设备之间的通信,下面是CAN设备的通信协议
第一个疑问:如果波特率一致,然后ID也匹配,那么发送成功以后,是否会把我邮箱的数据送到CAN设备里?
目前的想象是我应该已经成功把我邮箱的数据发送给CAN设备了,但是无法从CAN设备接收数据。
还有一个问题,我的ID设置也与协议不同,但是也成功发送了,这是什么原因呢?
混子黄|  楼主 | 2018-4-21 13:38 | 只看该作者
发送代码
void InitECanb(void)                // Initialize eCAN-B module
/* Create a shadow register structure for the CAN control registers. This is
needed, since only 32-bit access is allowed to these registers. 16-bit access
to these registers could potentially corrupt the register contents or return
false data. This is especially true while writing to/reading from a bit
(or group of bits) among bits 16 - 31 */
struct ECAN_REGS ECanbShadow;
   EALLOW;                // EALLOW enables access to protected bits
/* Configure eCAN RX and TX pins for CAN operation using eCAN regs*/
    ECanbShadow.CANTIOC.all = ECanbRegs.CANTIOC.all;
    ECanbShadow.CANTIOC.bit.TXFUNC = 1;
    ECanbRegs.CANTIOC.all = ECanbShadow.CANTIOC.all;
    ECanbShadow.CANRIOC.all = ECanbRegs.CANRIOC.all;
    ECanbShadow.CANRIOC.bit.RXFUNC = 1;
    ECanbRegs.CANRIOC.all = ECanbShadow.CANRIOC.all;
/* Configure eCAN for HECC mode - (reqd to access mailboxes 16 thru 31) */
        ECanbShadow.CANMC.all = ECanbRegs.CANMC.all;
        ECanbShadow.CANMC.bit.SCB = 1;
        ECanbRegs.CANMC.all = ECanbShadow.CANMC.all;
/* Initialize all bits of 'Master Control Field' to zero */
// Some bits of MSGCTRL register come up in an unknown state. For proper operation,
// all bits (including reserved bits) of MSGCTRL must be initialized to zero
    ECanbMboxes.MBOX0.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX1.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX2.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX3.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX4.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX5.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX6.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX7.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX8.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX9.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX10.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX11.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX12.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX13.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX14.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX15.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX16.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX17.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX18.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX19.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX20.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX21.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX22.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX23.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX24.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX25.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX26.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX27.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX28.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX29.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX30.MSGCTRL.all = 0x00000000;
    ECanbMboxes.MBOX31.MSGCTRL.all = 0x00000000;
// TAn, RMPn, GIFn bits are all zero upon reset and are cleared again
//        as a matter of precaution.
        ECanbRegs.CANTA.all        = 0xFFFFFFFF;        /* Clear all TAn bits */
        ECanbRegs.CANRMP.all = 0xFFFFFFFF;        /* Clear all RMPn bits */
        ECanbRegs.CANGIF0.all = 0xFFFFFFFF;        /* Clear all interrupt flag bits */
        ECanbRegs.CANGIF1.all = 0xFFFFFFFF;
/* Configure bit timing parameters for eCANB*/
        ECanbShadow.CANMC.bit.CCR = 1 ;            // Set CCR = 1
    ECanbShadow.CANES.all = ECanbRegs.CANES.all;
    do
        } while(ECanbShadow.CANES.bit.CCE != 1 );                 // Wait for CCE bit to be  cleared..
    ECanbShadow.CANBTC.all = 0;
    #if (CPU_FRQ_150MHZ)                       // CPU_FRQ_150MHz is defined in DSP2833x_Examples.h
        /* The following block for all 150 MHz SYSCLKOUT (75 MHz CAN clock) - default. Bit rate = 1 Mbps
           See Note at end of file */
                ECanbShadow.CANBTC.bit.BRPREG = 39;
                ECanbShadow.CANBTC.bit.TSEG2REG = 2;
                ECanbShadow.CANBTC.bit.TSEG1REG = 10;
        #endif
        #if (CPU_FRQ_100MHZ)                       // CPU_FRQ_100MHz is defined in DSP2833x_Examples.h
        /* The following block is only for 100 MHz SYSCLKOUT (50 MHz CAN clock). Bit rate = 1 Mbps
            ECanbShadow.CANBTC.bit.BRPREG = 4;
                ECanbShadow.CANBTC.bit.TSEG2REG = 1;
                ECanbShadow.CANBTC.bit.TSEG1REG = 6;
        #endif
    ECanbShadow.CANBTC.bit.SAM = 1;
    ECanbRegs.CANBTC.all = ECanbShadow.CANBTC.all;
        ECanbShadow.CANMC.bit.CCR = 0 ;            // Set CCR = 0
    do
    } while(ECanbShadow.CANES.bit.CCE != 0 );                 // Wait for CCE bit to be  cleared..
/* Disable all Mailboxes  */
        ECanbRegs.CANME.all = 0;                // Required before writing the MSGIDs
    EDIS;
          ECanbMboxes.MBOX25.MSGID.all = 0x90200010; // Extended Identifier
/* Configure Mailbox under test as a Transmit mailbox */
   ECanbShadow.CANMD.all = ECanbRegs.CANMD.all;
   ECanbShadow.CANMD.bit.MD25 = 0;    ///  1: 接收邮箱  0:发送邮箱
   ECanbRegs.CANMD.all = ECanbShadow.CANMD.all;
/* Enable Mailbox under test */
   ECanbShadow.CANME.all = ECanbRegs.CANME.all;
   ECanbShadow.CANME.bit.ME25 = 1;     ///  1:使能    0:  不使能
   ECanbRegs.CANME.all = ECanbShadow.CANME.all;
/* Write to DLC field in Master Control reg */
   ECanbMboxes.MBOX25.MSGCTRL.bit.DLC = 8;
/* Write to the mailbox RAM field */
   ECanbMboxes.MBOX25.MDL.all = 0x00000000;
   ECanbMboxes.MBOX25.MDH.all = 0x00620000;
//  j=0x01;
混子黄|  楼主 | 2018-4-21 13:39 | 只看该作者
while(1)
  // for(i=0; i < TXCOUNT; i++)
   for(t = 0x00;t < 2;t++)
       InitECanb();
       ECanbShadow.CANTRS.all = 0;
       ECanbShadow.CANTRS.bit.TRS25 = 1;             // Set TRS for mailbox under test
       ECanbRegs.CANTRS.all = ECanbShadow.CANTRS.all;
       kk = 0;
       do
                 kk = kk + 1;
        //         ECanbShadow.CANTRS.all = 0;
      // ECanbShadow.CANTRS.bit.TRS25 = 1;             // Set TRS for mailbox under test
      // ECanbRegs.CANTRS.all = ECanbShadow.CANTRS.all;
              ECanbShadow.CANTA.all = ECanbRegs.CANTA.all;
                } while((ECanbShadow.CANTA.bit.TA25 == 0 ) && (kk < 10000));   // Wait for TA5 bit to be set..
         if( kk < 10000) break;
          if(kk<10000) j++;
                        //           loopcount ++;
   //   j++;
        //  ECanbMboxes.MBOX25.MDL.all = j;
    //  ECanbMboxes.MBOX25.MDH.all = j + 1;
       ECanbShadow.CANTA.all = 0;
       ECanbShadow.CANTA.bit.TA25 = 1;                      // Clear TA5
       ECanbRegs.CANTA.all = ECanbShadow.CANTA.all;
        //   delay();
混子黄|  楼主 | 2018-4-21 13:41 | 只看该作者
用KK来来表示是否发送成功了,发送成功的kk数值会小于10000,否则会是10000
我讲断点设置在   ECanbShadow.CANTA.bit.TA25 = 1;                      // Clear TA5
观察kk的数据,发现小于10000,表示应该发送成功了,但是明明ID与协议不同啊,很奇怪。
tdh03z| | 2018-4-22 07:59 | 只看该作者
ID是你自己填的,对于发送,即使你不填入ID,只要启动了发送,都会将数据发送到CAN上,发送的ID就是默认的估计是0x00
混子黄|  楼主 | 2018-4-23 11:34 | 只看该作者
tdh03z 发表于 2018-4-22 07:59
ID是你自己填的,对于发送,即使你不填入ID,只要启动了发送,都会将数据发送到CAN上,发送的ID就是默认的 ...
原来如此,我现在发现我可能发送失败了,原因是
我查看CANES.TM 发现这个位的值一直为0,这意味着CAN模块没有发送数据。
airwill| | 2018-4-23 21:46 | 只看该作者
看到一个初学者的进步历程, 不错啊, 自己搞定了.
加油.
