具有 MSP430 智能模拟组合并且由回路供电的 4mA 至 20mA RTD 温...
5835|4
dirtwillfly|  楼主 | 2018-6-23 15:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
This TI reference design provides a low-component count, low-cost solution for 4- to 20-mA loop-powered, resistance-temperature detector (RTD), temperature transmitter. The design takes advantage of the on-chip Smart Analog Combo module in the MSP430FR2355 MCU to control the loop current, so  the standalone DAC is no longer required. This design achieves a 12-bit output resolution with an output current resolution of 6 µA. The design incorporates reverse-polarity protection as well as IEC61000-4-2 and IEC61000-4-4 protection on the loop-power input.
特性
  • Sensor Input Compatible with 2-, 3- or 4-Wire Resistance Temperature Detector (RTD) Probes
  • Temperature range for RTD of –200°C to 850°C
  • Maximum Measured Error: <1°C
  • IEC61000-4-2: ESD: Air Discharge: ±8 kV Class A
  • Small Form Factor (L × W): 60mm × 8mm
  • Operating Temperature Range -40°C to 105°C
dirtwillfly|  楼主 | 2018-6-23 15:47 | 只看该作者
由回路供电的 4 至 20mA RTD 温度变送器参考设计:
用户指南
由回路供电的 4 至 20mA RTD 温度变送器参考设计.pdf (10.86 MB)
dirtwillfly|  楼主 | 2018-6-23 15:59 | 只看该作者
4- to 20-mA Loop-Powered RTD Temperature Transmitter Assembly Drawing.pdf (107.23 KB)
4- to 20-mA Loop-Powered RTD Temperature Transmitter BOM.pdf (44.36 KB)
4- to 20-mA Loop-Powered RTD Temperature Transmitter CAD Files.zip (490.34 KB)
4- to 20-mA Loop-Powered RTD Temperature Transmitter Gerber.zip (323.04 KB)
4- to 20-mA Loop-Powered RTD Temperature Transmitter PCB.pdf (506.79 KB)
4- to 20-mA Loop-Powered RTD Temperature Transmitter Schematic and Block Diagram.pdf (193.74 KB)
相关工具与软件TIDM-01000 Firmware
chenglcd| | 2021-9-9 23:23 | 只看该作者
这个是好资料
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
